Author Topic: To those of you who reverse your spacebars on your FC660Cs...  (Read 5939 times)
Offline daerid
    • Rossipedia
« on: Mon, 01 September 2014, 17:19:57 »
... I hate you guys.
Turns out you were right. This is muuuuuuch better. Especially since I don't use this thing raised.
God damnit...
Re: To those of you who reverse your spacebars on your FC660Cs...
« Reply #1 on: Mon, 01 September 2014, 18:03:10 »
Hwood34 was right all along.
I do it with some of my spacebars.
« Reply #2 on: Mon, 01 September 2014, 18:07:43 »
I was doing it before hwood :(
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #3 on: Mon, 01 September 2014, 18:32:37 »
welcome to da flipside
Offline RickyJ
« Reply #4 on: Mon, 01 September 2014, 18:33:27 »
I made the switch a while ago, haven't looked back.  I pulled out my Leopold FC200 to do some coding recently, and have had to make do with a non-flipped spacebar...
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline FrostyToast
  • Litshoard
« Reply #5 on: Mon, 01 September 2014, 18:58:22 »
I flipped my spacebars before I got my 660c and boy when I got mine it was quite the knife bar. Surprised that customs let such a deadly weapon through. :p
Quote from: elton5354
Offline Smasher816
  • HHKB Master
« Reply #6 on: Mon, 01 September 2014, 19:01:48 »
If you flip the space bar, why not flip the rest also of the bottom row also.
« Last Edit: Tue, 02 September 2014, 12:32:09 by Smasher816 »
Offline FrostyToast
  • Litshoard
« Reply #7 on: Mon, 01 September 2014, 19:03:23 »
If you flip the space bar, why not flip the rest also?
So tru. I should flip the whole keyboard while I am at it too.
Offline thestage
« Reply #8 on: Mon, 01 September 2014, 20:28:23 »
I think I would like the flipped bar, but it just looks so ugly. And the space bar is a massive pain in the ass to remove on the 660c. I'd probably end up breaking the keyboard if I took it off too many times
« Reply #9 on: Mon, 01 September 2014, 21:10:29 »
No,  nothing is so simple..
Some of the keys on the bottom row are accessed via _thumb_ such as =alt=,   but most are not... like the windows key, or right control /left control
only keys that uses the thumb benefit from the flip, due to the flipped contour conforming to the angle of the thumb pointing upwards.
Offline FrostyToast
  • Litshoard
« Reply #10 on: Mon, 01 September 2014, 21:12:58 »
I was making a joke about turning the entire keyboard upside down.  :p
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #11 on: Mon, 01 September 2014, 21:15:16 »
It's ok, I just do it cause it's trendy :p
« Reply #12 on: Mon, 01 September 2014, 21:45:03 »
I remember, but you don't have your user title set to that, so I had to mention him.
Preach it Hwood!
I agree with TP4. Just like the 0 key on the topre numberpad, only keys hit with your thumb benefit, and all thumb-accessed keys should have a lower angle. Usually only japanese keybaords get this right.
« Reply #13 on: Mon, 01 September 2014, 21:46:02 »
another one bites the dust.
flipped spacebar heathen
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #14 on: Mon, 01 September 2014, 22:21:23 »
oh no
Offline Smasher816
  • HHKB Master
« Reply #15 on: Tue, 02 September 2014, 12:35:07 »
I would agree. I meant to put a picture of my HHKB, but it doesn't show up well. On that there is no control key, and I find both the buttons usable with my thumb. For a normal layout keyboard I wouldn't flip left or right control since those are meant to be pressed with your pinkies not your thumb.
I think more keyboards could use a rounded curve on their thumb keys, like for instance the ultron. http://webwit.nl/input/utron/utron7.jpg
Offline eth0s
  • Peace & Love
« Reply #16 on: Tue, 02 September 2014, 12:45:47 »
I don't use the spacebar.  I use the force.
Don't judge me.  I like plaid.  And pajamas are okay during the day too.
Also:  did you guys know you can turn your wristwatch 180 degrees, so you view it palmside up?  So kewl.
« Reply #17 on: Tue, 02 September 2014, 13:03:18 »
That can't be you, not enough unicorns
Offline Novus
  • Mondai nothing~
« Reply #18 on: Tue, 02 September 2014, 15:25:00 »
#Year of the rainbow 2014
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #19 on: Tue, 02 September 2014, 15:39:47 »
Welcome to the club Daerid!
For me, it depends on the spacebar. Topre and SP's DCS feel better to me flipped, but SP's SA and DSA are good normal orientation. Guess I'm saying that I don't like sculpted spacebars?  :confused:
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #20 on: Tue, 02 September 2014, 16:43:12 »
Now all you have left to do is flip L Alt
Offline tbc
« Reply #21 on: Wed, 03 September 2014, 02:24:08 »
doesn't dsa only has one orientation?
