Author Topic: Cherry MX Keycap Stabilizer Insert  (Read 2503 times)
Offline vanatir
« on: Mon, 15 September 2014, 08:30:47 »
Hio, i destroyed a stabilizer of my Qpad keyboard. Now i have the problem that one key is not fixed and wiggle. I found this article here: http://www.wasdkeyboards.com/index.php/products/keyboard-parts/cherry-mx-keycap-stabilizer-insert-2pcs.html . As i live in Germany the small item dispatch feels really expensiv to me. Is there a cheaper alternative for germans?
Thanks in advance!
Re: Cherry MX Keycap Stabilizer Insert
« Reply #1 on: Mon, 15 September 2014, 08:38:17 »
I thought QWER was carrying Cherry and Costar (what you've posted) stabilizers now.
« Reply #2 on: Mon, 15 September 2014, 11:27:25 »
Um.. how destroyed is it.....  this is all low tech stuff.. if it's not warped, and just cracked or broken-clean.  you can probably just glue it back together, and it'll work fine..
« Reply #3 on: Mon, 15 September 2014, 23:25:10 »
The Keyboard Co. is at least in the UK - shipping from within Europe might be simpler.
http://www.keyboardco.com/product/4-filco-white-stabilizers.asp
