Author Topic: If you could only use one keyboard the rest rest of your life, why would it be Topre?  (Read 12688 times)
Kidding with the title, but I think I'm starting to get it, at least with the HHKB.  I just don't understand the fanaticism still.  What drives the almost religious fervor around it?
« Last Edit: Mon, 15 September 2014, 17:28:29 by nubbinator »
Rubberdomes, mechs are a waste of money
Offline jacobolus
With its reliance on a rubber sheet, the big advantage of lifetime use of a single Topre keyboard would be that the keyboard would age as you do. It would start out supple and over time get old and crotchety. By the time you hit retirement, your keyboard would basically be retired too, and just as your knees start giving out and your hands start uncontrollably shaking, your keyboard would start refusing to actuate some keys at all.
Better plan ahead by saving grandpa’s model M for your grandchildren to type on when you are stuck dictating everything because your Topre board won’t type.
Offline digi
  • elite af tbh
  • keyboard game on fleek
use them both =) cupped rubber at work, mx at home!
Offline Grim Fandango
1. Not as loud. So I can use it anywhere.
2. Feels nice.
Offline Hypersphere
Not sure I could do it. Might have to smuggle in my IBM XT once in a while to get my capacitive buckling spring fix.
But if it could be only one, and a Topre, I suppose it would have to be one of my HHKBs. With the HHKB, it is not so much the Topre switches as it is the form factor, style, elegance, symmetry, design, and layout of the board. I also like its dye-sub PBT keycaps. Strictly speaking the HHKB is not a Topre board, it is a Fujitsu with Topre switches.
So, if it had to be a Topre board through and through, my next choice would be my Topre RF 87u 55g. I like the simple classic elegance and the smooth, solid, quiet sound and feel of the board. It also has beautiful dye-sub PBT keycaps. It gets the job done with understated sophistication while at the same time being highly pleasurable to look at, hear, and feel under the fingertips.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
it wouldn't be..............sorry :rolleyes:
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
it would be the KUL
Offline jameslr
At this time it would have to be a realforce 55g. If they end up making a novatouch 55g with dip switches then I would use that.
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline FrostyToast
  • Litshoard
I like the tactile pop of the switches much more than clears.  The sound is so very audible which provides wonderful feedback, but it is a very nice "thock" compared to the click that you would have to get with other keys.
Quote from: elton5354
Offline ComradeSniper
  • HHKB Pro
For me it's a combo of the HHKB layout being awesome and also the switches feeling great. Now that I've put 55g domes in my HHKB, I would be content with it being my only keyboard.
Because when you get old and weak you will only be able to lift a cheap plastic keyboard instead of a real solid model with plenty of steel in it.
- D Trump 2026-10-24
Offline Polymer
I'd pick Cherry board..only because I hate using Topre for gaming and I'm perfectly fine with Cherry for typing..
BUT
I strongly prefer Topre for typing....which is why I use it for work, etc...and Cherry for gaming...
Offline kalrand
I think you misspelled "buckling spring".
My 122 key Model M was born on July 25th, 1988.
Offline cherpalla
I use an HHKB at work, because I much prefer typing on Topre over all of the Tactile cherry switches. For my home PC (gamebox basically), I use linear switches, so Cherry MX Reds/Blacks it is.
c h e r
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
cuz cherry mx peasants suck
Offline GL1TCH3D
Cherry mx is too mainstream.
Just need to get a converter and you're set
Offline bazh
Ergodox.. because I've already decided..
but, but... what if you can have ErgoThorpe      :(
HHKB Pro2 white
Newbie again
Offline HPE1000
  • Keycap Paparazzo
I do really like the 55g topre switches on my realforce because they are so snappy and soft, I can't really describe it. Although if I had to only use one keyboard/switch for the rest of my life, it would have to be some really nice broken in lubed black switches with ~65-70g springs in them.
Topre is too much hype, that isn't to say that they aren't nice, but that hype... (perhaps if I liked tactile switches a lot my opinion would be different)
Why would it be Topre?
Are you assuming that I would select Topre?  Or are you telling me that I have to use a Topre keyboard for the rest of my life and would I please invent something to justify it?
Actually I'd probably be quite happy to use RealForce 87U 55g uniform.
Offline Novus
  • Mondai nothing~
Why wouldn't it be?
Offline Oobly
Attempting to justify the fact that you spent so much on a rubber dome board? I don't know, I don't like Topre, so I certainly don't get it.
If you were to say "Model F" or "full custom with your favourite modified MX switch" instead, well... different story.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Novus
  • Mondai nothing~
Objection, argumentative.
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
I think it would be a Model F for me.
Offline paicrai
  • mindblank
because then i could get a hhkb type s and jerklecirc on gh and be absolved of all my sins by the elitists
THE FEMINIST ILLUMINATI
Offline strict
  • TKL Zealot
Holy annoying signature
Offline paicrai
  • mindblank
Offline Lurch
Quote from: Flyersfan1
Offline paicrai
  • mindblank
now go back to the topic i didnt post to derail with my sig i posted to derail with jabs at hhkb nerds
Offline Lurch
Herb life best life?
On topic, Grim Fandango put it well,  "feels nice"
Offline paicrai
  • mindblank
nice
true topre feels nice but imo topre would be my choice, it's too soft and quited
Offline Xowie
  • On Sabbatical
The good feeling of oneness with cup rubber.
RETIRED
Offline Hypersphere
Recently, there have been a number of different threads here on GH and over on DT about Topre boards and comparing Topre with others.
I saw one thread comparing and contrasting the HHKB Pro 2 with the Poker II. Poker II advocates were challenging HHKB Pro 2 aficionados who also owned Poker IIs to remap their Pokers to a HHKB layout. I did this on my Poker II with Karabiner remapping software for the Mac, remapping Right Control as Fn and setting up the HHKB pattern of arrow keys. This was imperfect, because it left two dead keys on the Poker: the original Fn and Pn keys. In any event, the remapping on the Poker II was not too bad. However, the feel and sound of the Poker II was just not as pleasing as the feel and sound of the HHKB (or the RF, for that matter). In my view, a Cherry mx board is just not in the same league as a Topre-switch board. It was a relief to get back to my HHKB Pro 2 and RF 87u 55g boards -- the typing experience with the Topres is much better. Moreover, I find that my speed and accuracy are better on the Topre boards than on any Cherry mx board that I own.
The layout is key with any keyboard.  I would feel really terrible using the same keyboard all the time unless somehow I found my prefect switch.  I'm really close with MX whites.
After getting into the ergo boards there isn't a cell in my body that wants staggered any longer.  When I did rock staggered layouts 24/7 the hhkb appealed to me greatly.  I love alphas, mods, fn, and all the desk space a 60% brings to the table.
So yeah I dunno if I could commit.  I do know I love lightweight and smart layouts which are best achieved with a fully programmable controller.
Offline jacobolus
What kind of ergo board do you use?
Edit: this one apparently:
Nice palmrest!
« Last Edit: Tue, 16 September 2014, 23:33:09 by jacobolus »
I turned signatures off - makes things a whole lot cleaner :p
Nice palmrest!
This the kinesis advantage and the truly ergonomic keyboard.
Noko makes the best wrist rests.
Offline Oobly
Binge brings up an important point. For an "endgame" keyboard I can't choose a standard layout board.
I use this (Mark II is a work-in-progress):
77374-0
It's not Topre.... Cherry MX is the king of "customisability". It use a mix of trampoline and latex modded Browns and 62g ErgoClears with medium thickness PBT and POM caps.
You can't fine tune the feeling of Topre switches to personal taste like you can with MX.
Offline ConscienceDrop
  • a-are these pbt?
Topre boards usually feel more quality in general; which goes with the cost. But that being said, they barely feel different than a high end rubber dome to me. They are barely mechanical(feedback) feeling at all when compared to buckling spring or MX greens.
I seriously can't understand the love for cupped rubber+.
The "thonk" sounds nice, I will give you that. But it's not enough for me.
Offline Hypersphere
Detractors of Topre-switch keyboards tend to use descriptions such as, "it seems like nothing more than a high-end rubber dome to me." I have often wondered what is meant by "high-end rubber dome". Are there any examples of such a keyboard other than those that employ Topre switches?
Having compared many different types of keyboard switches in addition to Topre, including Alps of various kinds, Cherry mx of various kinds, membrane buckling springs, capacitive buckling springs, beam springs, Hi-Tek space invaders (tactile and clicky), Matias tactile clicky, Honeywell Hall effect, various linear switches in terminal keyboards, and rubber dome keyboards packaged with modern PCs, I find that the aural and tactile feedback of Topre switches is distinctive. To me, the tactile feedback from a Topre switch might be likened to that of a weighted piano key on a "real" piano (as opposed to an electronic piano keyboard).
I happen to like Topre switches, especially the heavier variety in my RF 87ub 55g, but I would not expect everyone to like them. Moreover, Topre is not the only switch that I like.
Periodically, I do a reality check by rotating through various keyboards in my collection to see if my preferences have changed. I really want to like Cherry mx switches, because I wish to take advantage of the abundant styles, colors, and textures of keycaps for them. Unfortunately, each time I try or re-try a Cherry mx board I am disappointed, and returning to a Topre-switch board is refreshing. In fairness, returning to a buckling spring keyboard (especially a capacitive buckling spring, such as the IBM XT) is also refreshing. Despite the differences between my IBM XT and RF 87ug 55g, I like each of these equally well, and either one is greatly preferable to any Cherry mx board I have tried.
We keyboard enthusiasts are fortunate to live in the midst of many excellent choices among keyboards and switch types. There is also no accounting for taste, and advocates of one particular switch or another will likely continue to remain baffled by the contrasting preferences of others.
Offline jacobolus
You’re right, Topre switches are distinctive, and while they’re not for everyone (e.g. me), they do feel very solid and well made.
You’re also right, MX switches are pretty uninspiring to type on. They just happen to be more common because everyone else got pushed out of the mechanical keyboard switch game circa 1995.
Offline MJ45
  • HHKB Pro
Thanks, rowdy,
I'm glad you brought that option to my attention!!
Offline paicrai
  • mindblank
oobly shut the **** up we've seen your ergocock
Offline Novus
  • Mondai nothing~
QFT
Offline Oobly
QFT
Offline pbtforever
Because the keys are PBT.   :))
Offline Hypersphere
Yes, it is unfortunate sometimes how market forces operate. Regarding switches, I would rather type on Topre, IBM capacitive buckling spring, IBM membrane buckling spring, IBM beam spring, Alps blue Monterey, Matias tactile/clicky, or NMB Hi-Tek black space invader switches than on any Cherry mx switch I have tried.
However, I have yet to try Cherry mx clears -- I've ordered a Kul ES-87 with clears, and I am eager for it to arrive so that I can try it out.
Ergo  Clears and Ghost Blacks are love.
Err, I mean Topre 5ever.
Offline Hypersphere
@nubbinator: A "ghost black" is a black switch (linear) with a clear spring, correct? Therefore, a ghost black would be a lighter version of a black linear switch, whereas a clear is a tactile non-clicky switch. Although Topre and Cherry are not really comparable, I would suppose that a Cherry mx clear might be the closest Cherry mx switch to a Topre. In any event, I shall soon be able to test a keyboard with clears for myself.
