Author Topic: My Servers r Here !! Halp, I n00ber at this  (Read 8792 times)
« on: Wed, 01 October 2014, 09:56:50 »
Both servers arrived today, Proliant G5
4x intel x7460 150GB Ram
and
4x intel x7460 120GB Ram
How do I get molex power on this thing for say a graphics card..
I can probably split it from the single molex out , but I have no idea how many amps that's rated for..
I may be able to pull it from the second drive power out, but that requires splicing up my own SAS-power-cable..
And honestly..  nothing's labeled on this thing... ...
Is, DIY power supply the only way to go ?
________
DAMn... I don't have the fiber op cables.. not included.. Fffffffffffffffffffffff
Offline yasuo
  • spanengan puyeng newbie
Re: My Servers r Here !!
« Reply #1 on: Wed, 01 October 2014, 09:57:29 »
ngejunk
Logitech MK220 Colemak DH
« Reply #3 on: Wed, 01 October 2014, 17:36:07 »
Guys, why is P400 raid controller only like $20, but the newer P411  $400
That makes no sense.. they're nearly identical on the spec sheet.
Re: My Servers r Here !! Halp, I n00ber at this
« Reply #4 on: Wed, 01 October 2014, 20:18:44 »
I'm guessing the 411 has more cache and a battery?
« Reply #5 on: Wed, 01 October 2014, 20:30:26 »
the 400 has 512mb and battery just like 411  ..
« Reply #6 on: Wed, 01 October 2014, 20:32:36 »
Transfer rates the same?
« Reply #7 on: Wed, 01 October 2014, 20:33:36 »
yea
wait, nm.. I read it wrong.. says 6gb sas vs 3gb sas.. the 3gb sata connection is the same..
I don't see how 6gb sas is worth 20x the cost.. considering the whole connection is still limited by the 2.5Gb/s PCIE x8,
they both route to 8 drives.   so even if the 411 has the 6gb sas,  it can't take that rate from all drives simultaneously.
« Reply #8 on: Thu, 02 October 2014, 06:05:59 »
Question:
So.. This got 4x redundant PSU @ 900 watt output each..
And I can pretty much hit 850watt from the wall @ full CPU load... it says I can pull max 1034watt from the wall, it's 87% efficient..
Does that Mean.. I still have  (1- (850/1034)) * 900 = 160watts  left over to power other things ?
What is the maximum low wattage Graphics card I can put into this.. because the interface is kind of slow when I use a larger monitor..    I'm not playing games, I just want to see my stuff on a bigger screen.. and perhaps get opengl accel
Or can I pull like another 900watts. because i mean, it's got 4 of these things..
NM, says in manual.. 2+2 redundant.. so I can pull 1800 @ 2070 from the wall.. I guess this is going in the garage if I ever need 17.23amps
« Reply #9 on: Thu, 02 October 2014, 08:31:54 »
Question:
Can I use this as a heater ? it's 650 watts standing still.. LOL and I haven't added stuff to it yet
So basically this winter.. I might as well use it full time, instead of my regular electric-heater yea?
I'm assuming all the power used by the PC is dumped into heat correct ?
Offline JPG
  • Model F is my new passion!
« Reply #10 on: Thu, 02 October 2014, 08:34:31 »
What do you use this server for?
« Reply #11 on: Thu, 02 October 2014, 08:37:44 »
I'm probably gonna use one of them to host vpn for my buddies and my movies and potentially several cs-go server instances.. (once i get the game for $5)
The other one.. I've not yet decided... couple things in mind..
Offline JPG
« Reply #12 on: Thu, 02 October 2014, 08:41:09 »
So you got 2 massive servers just for fun? Stop dealing drugs man (or taking them and hallucinating that you just bought 2 servers).
« Reply #13 on: Thu, 02 October 2014, 08:44:24 »
Yea. I got um just for fun.. PR0blem..?? this is GH, people get Geek stuff for FUN ?
And these arn't that big, they're only 60% longer than normal desktops..
Also... I think I'm going to paint the front  a deep Royal Blue... for M0re speedness.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #14 on: Thu, 02 October 2014, 09:09:54 »
If you put some NOS stickers and come CCFL lighting with a window on the case you can get an extra 1GHz overclock.
« Reply #15 on: Thu, 02 October 2014, 09:19:05 »
There's not allota space on the front for big stickers...  it's not a 23, only 19..
« Reply #16 on: Thu, 02 October 2014, 09:25:43 »
Show us some pics TP!
Offline yasuo
« Reply #17 on: Thu, 02 October 2014, 09:28:17 »
Offline Fragil1ty
  • Abre los ojos.
« Reply #18 on: Thu, 02 October 2014, 09:42:03 »
What the...
你搞砸了
« Reply #20 on: Thu, 02 October 2014, 13:10:10 »
Um... ok.. question..
Offline RED-404
« Reply #21 on: Thu, 02 October 2014, 13:17:59 »
I will help you set one up if you give the other to GH so the board can be a little less flaky.
« Reply #22 on: Thu, 02 October 2014, 13:21:42 »
You guys want to split the power /repair bill on this antique..  Done Deal.. I'll pay for the internet but.. ah .. yea it's slowww prob real slow when I torrent
GH would be officially NOT-Green if we use this thing though..
What is GH currently Ran on. .
« Reply #23 on: Thu, 02 October 2014, 13:34:41 »
If I pull power from this... -the beige port
Will the Server shut off during power-up-test if it doesn't know where that power is going
Picture of Powersupply backplane,
the black slots is where the 4 power supplies converge.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #24 on: Thu, 02 October 2014, 14:01:39 »
Best bet would probably to get a light weight GPU that dosen't need additional pci-e power like a quadro FX1800. It's still a good enough card for workstation use and can be had for cheap. Or cheap low end cards like nvidia GT *20 or some such.
As far as SAS controller... most of the older 3GBPS have 2TB disk limit which is why they are so much cheaper now days used. Too many people want to build larger storage than that without using piles of drives and less drives in an array is usually a good thing.
« Reply #25 on: Thu, 02 October 2014, 14:19:37 »
Hi Ivan thx for the recs
I've considered using a less powerful card.. but my last no-cable card is already being used..
I only have available an ati5870, ati4890 and an nv 560ti , LOLOL...
But I may also require power for other things in the future, which is why I'd like to divert it from somewhere..
« Reply #26 on: Thu, 02 October 2014, 14:23:51 »
If it were me, I would consider pulling the boards and etc and putting them in smaller desktop style pedestal cases with 'normal' PSU... and getting whatever you can out of those rack cases and server PSU. Maybe do so one at a time so the cost doesn't get stupid.
« Reply #27 on: Thu, 02 October 2014, 14:25:29 »
Um... these boards are HUGE and there are MANY, they're pretty much specifically designed for this chassis..
and It's not exactly a standard ATX 24 pin we're talkin here. LOL, everything is proprietary, I'm trying to break that yes..  buhhh.. there's a limit, before the motherboard's built in diagnostic will go.. Fff you, what are you doing to me.. I'm not turning on..
« Reply #28 on: Thu, 02 October 2014, 14:26:53 »
Some are just standard EATX and it's hard to tell from the pics you posted. If you have 5.25 bays in the Chassis, perhaps one of those auxiliary GPU PSU may be the ticket? Like one of these kind of things.
« Last Edit: Thu, 02 October 2014, 14:29:43 by IvanIvanovich »
« Reply #29 on: Thu, 02 October 2014, 14:28:40 »
LOL n00....  this is not n00b gear... just N00b owner..
the board you can see is just the expansion board,  the vertical board is a daughter board for video/ usb/ storage array/ and ethernet
the 4x cpu and ram is all Under the front of the chassis..  on yet, another board.
Offline RED-404
« Reply #30 on: Thu, 02 October 2014, 14:30:15 »
So far can't seem to find the pin-outs, but a cheap multimeter can fix that in like 5min.
As for the GPU its a ****ing server, you don't need no stinking GUI.
« Reply #31 on: Thu, 02 October 2014, 14:32:11 »
well,, it has 24 cores.. so I could run server stuff, while I edit videos,  and I'd need a gpu for that..
but that's not the only thing..   there's other things I might want to power..
« Reply #32 on: Thu, 02 October 2014, 14:34:15 »
Fvk it..
Thx...  BOUGHT... problem solved.. spreciate the help Ivan..
« Reply #33 on: Thu, 02 October 2014, 14:38:01 »
GPU can do more than render pixels. There is lots of CUDA or OpenCL stuff these days... though if you're going that way loads of CPU power is usually not so needed as generally it's replaced by GPU.
Though you don't really need a GPU unless you are going to use it to multitask something where you can offload to GPU. Just need to use software that you can do send work to server, or just rdp and run applications that way instead.
« Reply #34 on: Thu, 02 October 2014, 14:46:59 »
This has a fiber card, but I'm pretty sure it's designed for primarily storage....
I'd definitely be using RDP during warm months, when these guys go in the basement...
« Reply #35 on: Thu, 02 October 2014, 14:52:19 »
You could always use the FC as a cluster interlink. Hook them all together and start FAH.
« Reply #36 on: Thu, 02 October 2014, 15:04:05 »
I plan to get some GOOD storage later to use the FC.. but not right now..  For now I'd just throw some consumer sata ssds in there on an old rocket raid card because i have so many laying around
But I don't think the onboard array supports TRIM, so I'll probably have to cough up the $300 later for the new HP-raid-card.. LOLOL
BTW Ivan.. how did you find that gpu power supply..  I don't see any other ones listed on newegg..  and couldn't search for it.
« Reply #37 on: Thu, 02 October 2014, 15:44:34 »
I googled for 5.25 PSU. If you want a decent 'cheap' controller that supports trim you can grab something with ASMEDIA 106x controller. I have one and it works well enough and has good speeds very close to native intel for SSD. There are some cool cards that have 4x msata too which are really nice to set up to be used for journaling in storage spaces with parity sets.
« Reply #38 on: Thu, 02 October 2014, 16:21:09 »
Hmmmmmmmm.... the Pcie ssd cards might be a good idea.. any talk on the reliability of the $70-80 ones..
www.amazon.com/Syba-Marvell-Chipset-Shared-SD-PEX40079/dp/B00KKO6N98/ref=sr_1_2?ie=UTF8&qid=1412284300&sr=8-2&keywords=msata+raid
« Reply #39 on: Thu, 02 October 2014, 16:27:36 »
I have a single msata single sata version with the asmedia controller for my boot drive. It's been working like a champ. I might get one of the 4x msata ones later on to use for journaling. Parity storage spaces writes are pretty heinous slow without that.
I got mine off ebay from Hong Kong... it's like 80% less that way.
Those with that marvell controller also supports trim but the throughput is not as good.
« Last Edit: Thu, 02 October 2014, 16:29:53 by IvanIvanovich »
« Reply #40 on: Thu, 02 October 2014, 16:30:58 »
I hadn't realized they had made pcie msata controllers..  This makes it much easier if I need to add SSD storage later, I got a bajillion pcie slots afterall.  Server FTW !!
« Reply #41 on: Thu, 02 October 2014, 16:36:10 »
Indeed, they are very nice since then you don't need to add more cables. Keeps it all nice and clean.
« Reply #42 on: Thu, 02 October 2014, 16:39:42 »
wow, this saves so much space.. INSANE...
Offline RED-404
« Reply #43 on: Thu, 02 October 2014, 16:46:15 »
So you are going to get some onion head case badges made for your servers?
« Reply #44 on: Thu, 02 October 2014, 16:59:49 »
I'm not really the type of guy who has to put a stamp on everything and pee-everywhere..
LOLolol...
I'm satisfied with just painting some of the front bezel blue.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #45 on: Thu, 02 October 2014, 17:18:56 »
They are a touch bigger than my RasPi servers...  :P
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #46 on: Thu, 02 October 2014, 17:23:31 »
Yes, lots of very cool things you can do with GPUs now days.
Offline Fire Brand
  • Keeper of Rainbows
  • BISCUITS!
« Reply #47 on: Thu, 02 October 2014, 17:25:16 »
Your doing it wrong, red makes it go faster :/
My Youtube Channel ~
Keyboards owned
My classified thread :3
« Reply #48 on: Sat, 04 October 2014, 21:00:52 »
Nearly Died carrying my servers downstairs by myself..
These guys are at least 75lbs each..
Pulled my left shoulder muscles as well..
