Author Topic: Best key switch type for ergonomics/arthritic fingers?  (Read 15239 times)
Offline supamesican
« on: Fri, 03 October 2014, 18:36:27 »
My mom has finger pain from slight arthritis and typing only makes it worse. Shes using a crappy slim rubber dome keyboard right now, yeah it needs to go.  What is the best key switch for arthritic fingers to type on?
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Re: Best key switch type for ergonomics/arthritic fingers?
« Reply #1 on: Fri, 03 October 2014, 19:01:11 »
I have arthritis in my thumbs and find MX Brown the easiest on the joints.
Good luck!
 - Ron | samwisekoi
« Reply #2 on: Fri, 03 October 2014, 19:05:33 »
I don't know firsthand, but I suspect that tactile feedback is very useful in clearly signalling when the stroke has registered.
- D Trump 2026-10-24
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #3 on: Fri, 03 October 2014, 19:18:06 »
speaking mx..............probably reds or browns, however if her fingers lose feeling or go numb sometimes the bump-click in blues works better because you can feel the switch. sometimes if you have problematic fingers (as i do-- from injury while on active military duty) you tend to bottom out more if you do not train your fingers.
if she does not mind a full size board get her a hi-tek, space invaders with black switches.......... NMB, etc.
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline supamesican
« Reply #4 on: Fri, 03 October 2014, 20:40:17 »
Thats all she'll use so thanks for the recommendations.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
Offline SonOfSonOfSpock
« Reply #6 on: Sat, 04 October 2014, 00:32:10 »
I don't know if there is a wrong answer. Maltron uses MX black switches in their boards.
There might be factors other than keyswitch that can help. Perhaps an ergonomic keyboard with split halves or tenting?
Offline Oobly
« Reply #7 on: Sat, 04 October 2014, 06:46:51 »
Trampoline modded or oring'ed MX Browns should be good. 62g ErgoClears would also work. Thwy're light but have decent feedback and the trampoline or oring reduces shock on bottom out. Also Matias quiet switches if you don't want to do mods. They have rubber pieces in the slider which reduce shock on bottom out and release.
With MX and Alps you can learn to type without bottoming out if you have enough sensitivity in your fingers which can help too.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline hoggy
  • * Ergonomics Moderator
« Reply #8 on: Sun, 05 October 2014, 15:31:19 »
Comfort keyboards do a fairly cheap split keyboard with a really light activation of about 20g.
I think you'll just have to find the keyboard she can get on with, and that will mean trying out a few.  You might find taking her to a normal computer store will help you get her thinking about what might work for her.
Offline supamesican
« Reply #9 on: Sun, 05 October 2014, 19:27:00 »
I think I'm gonna take her to microcenter, see what switch types work best for her since they have mechanical boards there, then probably come back here and see if anyone knows of a particularly good board with those switch types.
Thanks everyone,
« Reply #10 on: Sun, 05 October 2014, 23:54:01 »
Microcenter is a good choice for mechanical boards as far as brick and mortar stores. From my experiences at the one in Denver, they don't have any display models, but they are fine with opening up the boxes for you to try. Besides the Cherry MX boards in the gaming section, they had some Matias boards in the Mac department.
Offline davkol
  •  Post Editing Timeout
« Reply #11 on: Tue, 07 October 2014, 10:50:11 »
30g Topre. Period.
If you can't get Topre, Goldtouch rubber domes have very soft landing or you can mod linear Cherry MX switches (heavy keycaps with soft-landing pads from EK, Korean springs and lube).
That being said, does she type for living? Can she touch type? What's the budget? Is she seeing a professional?
There were two or three threads about this last year. You can try to find them.
« Reply #12 on: Tue, 07 October 2014, 12:02:45 »
How much motion can you accomplish prior to feeling pain.
is it the GRIP type motion when your fingers bend that causes pain..  OR is merely holding your finger firm enough to cause pain..
Offline notsonerd
  • Here for the secrets
  • Light My Fire
« Reply #13 on: Tue, 07 October 2014, 12:19:15 »
Blacks do seem to be the least harsh to bottom-out among the Cherry MX switches, but would the travel and increased pressure going farther down hurt her fingers?
If she can avoid bottoming-out, maybe she could try light touch-typing. It takes almost no effort to do using brown switches. With this, she could avoid any harsh feedback that might hurt her fingers. It would have to be learned, however. I'm still trying to find the right amount of pressure for every key so it's almost like I'm typing on reds at the moment with all the typos I've had typing this one message.
KBParadise V60 with Cherry MX Browns | Corsair K60 with Cherry MX Reds
Offline supamesican
« Reply #14 on: Tue, 07 October 2014, 13:50:33 »
Can't imagine black being worse than the rubber done and scissor switches keyboards she uses now. Though learning how to use the browns like that may be the best option, since it sounds like that would take the least amount of force and movement and still get the tactile feed back.
Offline davkol
« Reply #15 on: Tue, 07 October 2014, 14:44:25 »
The biggest issue is harsh landing, friction/sticking and possibly aggressive rebound. No Cherry MX switch will help with any of that (except sticking, if compared to a broken rubber dome), unless not bottomed out or modded (dampened at the very least).
« Reply #16 on: Tue, 07 October 2014, 14:49:12 »
What about the Matias Quiet or Dampened Cream Alps? They've got the nice cushioning in the switch.
« Reply #17 on: Tue, 07 October 2014, 14:52:18 »
If it's the LANDING that's causing pain... then the switch type doesn't really matter as long as it has 2mm actuation..
the rest comes down to technique, and not bottoming out harshly.
To clarify, you should still bottom out.. that just makes for good typing.
Offline davkol
« Reply #18 on: Tue, 07 October 2014, 14:53:17 »
I've always been curious about this; what's bottoming out on dampened Alps-like switches like? I've used only old salmon/cream dampened Alps and the impact has felt quite harsh to me, quite in contrast with the cushiony upstroke.
« Reply #19 on: Tue, 07 October 2014, 14:54:38 »
I don't recall the dampened cream Alps very well but I recall the Matias Quiet switch having that nice cushiony feeling on the upstroke on the bottom out too.
Offline jacobolus
« Reply #20 on: Tue, 07 October 2014, 16:08:08 »
I think that’s overly pessimistic. A Cherry MX switch actuates about halfway through the stroke, meaning that keypresses that go at least that far reliably actuate it; by contrast, most rubber dome switches actuate at the bottom and sometimes fails to actuate when not mashed hard all the way down.
Untrained typists routinely use more than twice as much force as required to press the keys. On some rubber domes, this is almost a requirement to avoid occasional skipped letters.
However, it’s possible to type on an MX switch (or other mechanical switch) with light springy keypresses, using just a bit more than the minimum required force. Even if the key ends up going all the way to the bottom of the stroke, it can at least be very low impact by that point.
Both Matias switches and dampened cream Alps switches are relatively stiff. If you modded them to use lighter springs they might be okay for someone with low finger strength. Otherwise, low-force Topre switches or brown MX switches might work. I don’t think O rings are necessary or even necessarily helpful.
Note that if switches get *too* light, then it’s no longer possible to rest the fingers on them without accidentally actuating some, which might also be undesirable.
« Last Edit: Tue, 07 October 2014, 16:10:49 by jacobolus »
Offline davkol
« Reply #21 on: Tue, 07 October 2014, 17:20:32 »
You're right that it's possible and I actually type like that, but it takes time and effort to get to this point.
Offline Oobly
« Reply #22 on: Wed, 08 October 2014, 01:18:16 »
Actually Clears have the best spring profile for softening the bottom out shock. Clear springs with Black sliders are a good choice for light actuation and learning to not bottom out. Add orings or trampolines and this is probable the best switch type (Ghost Blacks with orings). However, if you want tactile feedback, Clears are better, but the force required goes up a touch and can be fatiguing.
I still think Browns with orings is best. Light springs, some tactility so you know when the switches actuate and softened bottom out shock should all help.
Offline MKB
« Reply #23 on: Sun, 26 October 2014, 03:38:37 »
A reply to the OP.  I would start with blues or browns.  I would avoid blacks as they require a lot of force.
________________________________
Current:
Leopold Tenkeyless (Cherry Clears)
Leopold Tenkeyless (Cherry Reds)
Filco Tenkeyless Zero (White Fukkas)
Unicomp SpaceSaver 104 (Buckling Spring)
Past:
IBM Model F (Buckling Spring)
IBM Model M (Buckling Spring)
Northgate (White Alps)
Fujitsu (peerless)
HHKB Pro 2 (Topre)
Deck Legend (Cherry Blacks)
Deck 82 (Cherry Blacks)
Unicomp Customizer 104 (Buckling Spring)
