Author Topic: HHKB Pro2 typing lag  (Read 4905 times)
Offline daiyue
« on: Tue, 04 November 2014, 15:00:53 »
Hi, I noticed that when typing fast or when start off a application (e.g. Web browser like Chrome) and starting typing in any text input areas, there is a noticeable lag, sometimes it is even worse that the first few keystrokes did not get registered, as I saw no chars shown, it is sometimes also the case when like typing passwords. But hereafter, it is working fine. I don't know if anyone else experienced the same issue. I am wondering is it possible to remedy the situation or even solve the problem. I am on Windows.
cheers
Offline DasHHKBProM
Re: HHKB Pro2 typing lag
« Reply #1 on: Tue, 04 November 2014, 15:21:43 »
it maybe the computer catching up to your input
Offline jameslr
« Reply #2 on: Tue, 04 November 2014, 16:34:30 »
This doesn't sound like a problem with the board itself. Sounds like you might be having some performance issues with your PC. Is the hard drive cranking away when this is happening? What about cpu or memory usage?
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline daiyue
« Reply #3 on: Tue, 04 November 2014, 17:09:49 »
The CPU and memory usage is really low, and I am using SSD, so the hard drive shouldn't really be cranking away.
Offline oscillik
    • music podcasts
« Reply #4 on: Tue, 04 November 2014, 17:19:56 »
then there would seem to be some other issue with the computer here. What you're describing is totally a symptom of the computer lagging in receiving keystrokes, rather than the keyboard taking its sweet time to send the keystrokes to the computer.
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
« Reply #5 on: Tue, 04 November 2014, 18:30:22 »
1st problem.. you're using a silly weeaboo keyboard..
2nd problem.. chrome... firefox iz better
3rd.. you probably got a virus or malware
4th.. ur computer may be sux0rz..
Please post computer specs..
« Reply #6 on: Tue, 04 November 2014, 21:20:26 »
do you get the same issue with other keyboards?
Offline Coreda
« Reply #7 on: Tue, 04 November 2014, 21:35:30 »
Hi, I noticed that when typing fast or when start off a application (e.g. Web browser like Chrome) and starting typing in any text input areas, there is a noticeable lag, sometimes it is even worse that the first few keystrokes did not get registered, as I saw no chars shown.
In those cases it's likely some lag spike from the process of launching an app, especially it's a heavier one. I would occasionally get this on my older Macbook, but only if doing too many things at once or if the computer is too hot.
« Reply #8 on: Tue, 04 November 2014, 21:36:59 »
The only time I noticed something like that is after I wake up my computer with a keypress on the HHKB.  I cannot type in the password field first try.
But if I use the mouse to wake the computer, I can type in the password field.
« Reply #9 on: Tue, 04 November 2014, 21:51:49 »
what key do you press to wake it up? I always go for ctrl just in case. I think sometimes it also doesn't catch the first keypress after wakeup.
« Reply #10 on: Tue, 04 November 2014, 22:17:51 »
Usually space or Shift.
No keypresses worked until, IIRC, I pressed Return, then it would indicate an invalid password (because the field was blank, the first keypress recognised was Return).
The second attempt was successful - all key strokes were recognised.
One of the DIP switches changed that behaviour slightly, but caused other problems for me, so I just left it as it is, and use the mouse to wake the computer now.
Offline Premonition
  • HHKB Elite
« Reply #11 on: Tue, 04 November 2014, 23:11:02 »
Pls calm down tp. =(
Offline GL1TCH3D
« Reply #12 on: Wed, 05 November 2014, 09:00:33 »
Maybe you have a slow usb port? =O
I'm not sure what would cause that to change though. Does it work on different usb ports? Or do all of them have the same symptoms?
« Reply #13 on: Wed, 05 November 2014, 12:48:36 »
Yes, that must be it, the usb port's challenged, and or has been drinking... HAHAHAHHAHA
but this sounds way more like a software issue..
OP did you try that keyboard in other computers ?
