Author Topic: Nest Thermostat  (Read 2157 times)
Offline heedpantsnow
  • Old enough to know better
Nest Thermostat
« on: Sat, 29 November 2014, 19:51:45 »
It's on sale till the 1st ($200).
Do you guys have one?  Do you like it?  Does it actually save you money?
I'm back.
Re: Nest Thermostat
« Reply #1 on: Sun, 30 November 2014, 02:18:13 »
Is it cool..  YES..
but when was the last time you really wanted m0re from your thermalstat..
So...  I'd definitely file this under,  Impulse buy, Didn't need, Frivolous..
Yes the novelty is there for a few days..   but for most people,  thermostat is set and forget..
really consider what $200 will give you in OTHER gizmos that you would actually use WAY more often .
LIKE...  an Egdx..
Offline i3oilermaker
  • techkeys.us
    • TechKeys
Re: Nest Thermostat
« Reply #2 on: Sun, 30 November 2014, 15:56:36 »
I love mine - saves some money (not a ton) but it super convenient and works great.
Re: Nest Thermostat
« Reply #3 on: Sun, 30 November 2014, 17:37:07 »
Thanks. Do you know approximately how much it saves?  Like 5% or like 25%?
I've also been looking at the Ecobee, but I don't understand how it works and there's not as much info out there as there is for the Nest.
I'm back.
