Author Topic: How I Saved Grapefruitmas  (Read 2535 times)
« on: Tue, 16 December 2014, 15:28:51 »
Through shopping haste, Tp4 was cursed with a sub-par grapefruit that was parched inside..
However, Tp4 theorizes that if the content lost through evaporation is merely water.. then the grapefruit's essential essences should've remained intact..
And SO.. The withered fruit has been arduously peeled and placed in a blender.
Then using numerous internet cross-referencing for the average weight-to-volume ratio of the pomelo grapefruit..  A precise rehydration volume of dihydrogen monoxide was calibrated..
Ya'll be happy to know.. that It worked Perfectly.. and the juice is as delectable as fresh squeeze..
  • Live long and prosper
Re: How I Saved Grapefruitmas
« Reply #1 on: Tue, 16 December 2014, 15:31:23 »
Didn't you already have a grapefruit thread?
tp thread is tp thread
« Reply #2 on: Tue, 16 December 2014, 15:35:49 »
2.0 Update, much like Rice Part II
Offline heedpantsnow
  • Old enough to know better
« Reply #3 on: Tue, 16 December 2014, 22:25:45 »
So did you use an Asian pomelo (smaller and more tart) or a normal grapefruit (approx size of a softball)?  Asian pomelo is awful if you eat it straight. I make my own youzicha/柚子茶/youjuja with them though and that's yummy.
I'm back.
« Reply #4 on: Tue, 16 December 2014, 23:22:21 »
I can't believe I just read another one of these threads :))
« Reply #5 on: Wed, 17 December 2014, 06:11:15 »
Well at least it doesn't have that disturbing video
I'm back.
« Reply #6 on: Wed, 17 December 2014, 08:16:37 »
This month is all about adding the precise amount of water-to-stuff to make stuff better.
« Reply #7 on: Wed, 17 December 2014, 08:22:30 »
« Reply #9 on: Wed, 17 December 2014, 08:28:17 »
tp4, sometimes I absolutely hate your guts, mostly when you say stupid ****.
Other times, I can't help but appreciate your uniqueness.
This is an example of the latter.
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #10 on: Wed, 17 December 2014, 08:51:53 »
I commend your tenacity. I would have chucked it and bought a new one.
Offline azhdar
  • Praise the AZERTY god
« Reply #11 on: Wed, 17 December 2014, 09:17:35 »
I'm gonna help you onto this quest , don't had water to alcohol , unless it's pastis . But I think it's a french only alcohol .
Azerty Propagandiste
« Reply #12 on: Wed, 17 December 2014, 09:19:49 »
Tp4 is like moisture... you may be stone, but a few cold nights in addition to my condensat-ing goodness, and I shall carve through you.
