Author Topic: What video playback software do ya'll use..  (Read 6951 times)
« on: Mon, 22 December 2014, 20:42:37 »
I've been hardcore mpchc since madvr..
Before Madvr,  I was all into VLC,
and before VLC,  I was on that zoomplayer, because my cpu wasn't fast enough for 1080p, so I used my gpu for dxva..
Re: What video playback software do ya'll use..
« Reply #1 on: Mon, 22 December 2014, 20:53:05 »
I just use VLC.
Offline Lain1911
  • God of the Wired
« Reply #3 on: Mon, 22 December 2014, 20:55:23 »
Media Player Classic with cppp plays everything I ever need.
« Reply #4 on: Mon, 22 December 2014, 21:03:08 »
I just use VLC.
But don't you care about upscaling quality ??
Not on the old hardware I have.
« Reply #6 on: Mon, 22 December 2014, 21:07:41 »
I just use VLC.
what's ur cpu n gpu
Core 2 Duo 2.26 GHz.  Nvidia 9400M.
Try not to laugh too much.  My priorities are elsewhere these days.
« Reply #7 on: Mon, 22 December 2014, 21:11:46 »
I just use VLC.
what's ur cpu n gpu
This can't be your only-puter..  at least u got SSD righ ?
« Reply #8 on: Mon, 22 December 2014, 21:27:02 »
I just use VLC.
It has more to do with ****ty digital copies then the playback software. I can download a movie at 1080p and my 720p dvd version will always look better. No gross pixalation or shadow artifacts like you get from digital copies. Also, having a decent monitor helps.
« Reply #9 on: Mon, 22 December 2014, 21:31:05 »
I just use VLC.
dvds are 480p...
« Reply #10 on: Mon, 22 December 2014, 21:36:27 »
I just use VLC.
dvds are 480p...
Still look better than most of my 1080p downloads.
« Reply #11 on: Mon, 22 December 2014, 22:01:53 »
I just use VLC.
what's ur cpu n gpu
Nope, but the next best is roughly the same.
No SSD.
I know live in the dark ages.
Offline Coreda
« Reply #12 on: Mon, 22 December 2014, 22:29:24 »
PotPlayer.
Before that KMPlayer.
Before that GOMPlayer.
Before that a variety of players, including VLC.
(pic unrelated)
Offline ezrahilyer
« Reply #13 on: Mon, 22 December 2014, 22:31:36 »
VLC when on OSX or Windows
Mplayer when on Linux.
Offline user 18
« Reply #14 on: Mon, 22 December 2014, 22:52:44 »
VLC because it plays everything I throw at it, and I've never felt the need to look for anything better.
Avatar by ashdenej
Offline Smasher816
  • HHKB Master
« Reply #15 on: Mon, 22 December 2014, 23:29:37 »
Check out mpv.
It is mplayer2 but coded better, with an optional HUD, ipc commands (nice for scripting), and support for streaming videos (via youtube-dl).
« Last Edit: Tue, 23 December 2014, 19:03:17 by Smasher816 »
Offline azhdar
  • Praise the AZERTY god
« Reply #16 on: Tue, 23 December 2014, 01:50:48 »
I use Plex home Theather ever since I built my NAS .
Was using Vlc before .
Azerty Propagandiste
Offline Belfong
« Reply #17 on: Tue, 23 December 2014, 01:52:45 »
nobody talks about iTunes?
But funny thing, even watching Game of Thrones HD in iTunes on my PC stutters once a while (yes, I have SSD but Core 2 Quad and GTX something card)
Offline azhdar
« Reply #18 on: Tue, 23 December 2014, 01:54:42 »
Never used Itunes for video , but all my music go through it .
Offline yasuo
  • spanengan puyeng newbie
« Reply #19 on: Tue, 23 December 2014, 02:15:45 »
vlc, mpc also ive try KMP but back vlc i dont like video player connceted internet always show ad
the i dont like mpc is play/pause button separate
aimp for music
PotPlayer.
:thumb: i tried using it looks better than vlc
« Last Edit: Tue, 23 December 2014, 03:29:39 by yasuo »
Logitech MK220 Colemak DH
Offline paicrai
  • mindblank
« Reply #20 on: Tue, 23 December 2014, 06:19:38 »
media player classic w/ the k-lite codec pack
THE FEMINIST ILLUMINATI
Offline SavvyBird
  • Savvy Caps
« Reply #21 on: Tue, 23 December 2014, 06:58:36 »
Is there something better than VLC?  :-X
I use VLC btw :rolleyes:
hi
« Reply #22 on: Tue, 23 December 2014, 10:58:27 »
Well.. in terms of the best-playback quality (visually).. most enthusiast concur that MPC-HC + Madvr scalar does the best job..
VLC and MPC-HC by themselves alone will play all formats, but Madvr scalar is what makes sure your file is projected on your monitor Correctly..
madvr only works on MPC-hc
« Reply #23 on: Tue, 23 December 2014, 15:49:36 »
I was tempted to try Miro a few times, but VLC continues to suffice.
http://www.getmiro.com/
Offline pasph
« Reply #24 on: Tue, 23 December 2014, 16:07:33 »
madVR is not the easiest peice of sw you can find, for enthusiast only?
« Reply #25 on: Tue, 23 December 2014, 16:55:56 »
Find ?
it's free..  at the link below, first link, it's always updated to the latest version.
http://forum.doom9.org/showthread.php?t=146228
Offline pasph
« Reply #26 on: Tue, 23 December 2014, 16:58:28 »
I mean is not the easiest to configure
« Reply #27 on: Tue, 23 December 2014, 18:04:12 »
Um.. well.. there's a very slight learning curve, but almost always, the largest hurdle is the diversity of hardware that people have..
but... overall....  anything with 700+ gpubench score will work fine..  Preferably something with 3000 +  will be much better..
Offline Coreda
« Reply #28 on: Tue, 23 December 2014, 18:30:08 »
? I thought it being only a renderer it was compatible with any 32bit player.
Is there something better than VLC?  :-X I use VLC btw :rolleyes:
PotPlayer. Handles everything, loads of options, nice default UI, and has video/frame/audio capture built-in. AviSynth scripts are also supported, amongst other advanced options.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #29 on: Tue, 23 December 2014, 19:05:58 »
YouTube. Twitch.
I don't really watch videos otherwise. I always used VLC previously.
Offline pr0ximity
« Reply #30 on: Tue, 23 December 2014, 20:01:58 »
MPCHC4lyfe
« Reply #31 on: Tue, 23 December 2014, 21:53:13 »
MPCHC4lyfe
gotta use Madvr though.. otherwise, there's no real advantage to MPCHC over the other players
Offline eddie.patoni
  • Tapatalk User
« Reply #32 on: Wed, 24 December 2014, 21:55:27 »
Vlc.
