Author Topic: Action camera  (Read 2665 times)
Offline bear95
Action camera
« on: Thu, 08 January 2015, 02:15:41 »
Anybody have experience/advice about action cameras?
I'm mostly gonna use it while skiing and was thinking about getting the gopro hero3+ black. Has WiFi and high fps recording but a bit on thr expensive side.
Re: Action camera
« Reply #1 on: Thu, 08 January 2015, 03:03:50 »
Hahahahah..
I just imagined a g4m3r wearing a go-pro while playing starcraft..   and extreme action music playing in the background..
Re: Action camera
« Reply #2 on: Thu, 08 January 2015, 03:15:32 »
i wanted to get a gopro when i went on my bike, but it seems to have really ****ty battery life.
usually i'd be on my bike for 4-5 hours, and carrying 2-3 batteries is just unneeded weight added.
Re: Action camera
« Reply #3 on: Thu, 08 January 2015, 03:51:42 »
This guy has done a few (ha!) reviews of various cameras:
http://www.techmoan.com/
Offline bear95
Re: Action camera
« Reply #4 on: Thu, 08 January 2015, 03:52:46 »
Yeah. So I'm planning to carry a portable charger to plug in while I use it. Adds bulk but no camera out there lasts long AFAIK and there's no other option. I ski 6 hrs daily and changing batteries midski is gonna be a hastle
Offline byker
  • Literally Canada
Re: Action camera
« Reply #5 on: Thu, 08 January 2015, 14:12:00 »
I have a contour and it is pretty cool, I use it while biking mainly. Mine is a few years old, but they were a better deal then GoPro back then, and I prefer their streamlined look. Not sure how they stack up currently to the competition though.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Action camera
« Reply #6 on: Thu, 08 January 2015, 16:59:58 »
Maybe a Polaroid C3? They are super small so should be easy to mount somehow and are quite a bit cheaper than many others so as not to get too upset if you happen to crash and it gets broken.
Offline bear95
Re: Action camera
« Reply #7 on: Sat, 10 January 2015, 02:09:48 »
Did a bunch of looking around and I think I may settle on the replay xd prime x. Looks sleek, got high fps recording, and wifi... and cheaper too. Low light looks bad tho... hmm... I hope it doesn't cause a problem skiing at night.
