Author Topic: Compendium of Speed (Learn to type at least 135wpm) Guaranteed-!!  (Read 156562 times)
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
Re: Compendium of Speed (Learn to type at least 135wpm) Guaranteed-!!
« Reply #50 on: Thu, 04 February 2016, 19:16:29 »
im going to say that this mania produced thread was actually a contribution by tp4 for once to the keyboard part of geekhack, as crazy as it is, so i will deduct 10 sins from tp4
i still want proof you own a ergodox, or even own a mechanical keyboard, i was drunk years back and looked into past posts by tp4 and i remember the only proof i found was you joined a feng group buy for some pbt set i think. i swear, whatever, make more of these and less bs posts.
Offline bocahgundul
  • a seal
« Reply #51 on: Sat, 12 March 2016, 06:16:03 »
So what finger do I use for spacebar if I use dvorak layout?
« Reply #52 on: Sat, 12 March 2016, 10:37:11 »
technically if you count it up,  it's either one, because key load is about even between left and right..
HOWEVER,  in practice,  I'd still say -the right- because of where the shift key is on a regular keyboard.
On the regular keyboard, because all shifting is generally done on the left, due to the right shift being too far away, the only way to make up some time would be to add things to the right.
Offline Baddy126
« Reply #53 on: Sat, 12 March 2016, 13:40:51 »
There should be a type racer challenge on geekhack
Offline bocahgundul
  • a seal
« Reply #54 on: Wed, 16 March 2016, 04:11:22 »
so that means I'm goin to use ergodox
thanks mane
Offline ntw
« Reply #55 on: Wed, 17 August 2016, 01:46:42 »
thanks for linking this boca! now I can 60wpm with comfort
Offline letsjigsrocks
  • Don't you think its cute?
« Reply #56 on: Mon, 29 August 2016, 04:29:23 »
This is great.
VA87MR
Offline menuhin
« Reply #57 on: Wed, 07 September 2016, 14:50:12 »
I just notice this one YouTuber with 170+ WPM -- he doesn't use his pinkies that much in the traditional touch type way. And it seems that he's not the only fast typists doing it.
What do you think?
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline xondat
  • i'm not a star
« Reply #58 on: Wed, 07 September 2016, 14:52:29 »
What do you think?
Proof that Razer make the best keyboards.
« Reply #59 on: Wed, 07 September 2016, 15:54:20 »
the accuracy is ****ing atrocious though
« Reply #60 on: Wed, 07 September 2016, 17:35:40 »
What do you think?
OVERALL,  when I use Q or P on standard qwerty,  I do not use my pinky for those keys, because they're easier to reach using  Ring finger.
As far as letter frequency goes,  - A - is the only common letter that would be affected by not using the Pinky on qwerty.
- P - on the right hand isn't that common,  so it should not affect speed much..
For me personally though, I've moved -P- to where my -:- colon sign is, because the colon is less common than a letter..
Offline duszek
« Reply #61 on: Sat, 18 May 2019, 06:30:03 »
What if I need thumb fingernails for pushing Palm Centro buttons? Those are so small you need to use fingernails too.
Offline Sintpinty
  • Carbon Based Life Form
  • she/her/they/them/any except he him
    • My Roblox Profile
« Reply #62 on: Sat, 18 May 2019, 07:07:39 »
I mean, i can type 120 wpm, but with great amounts of errors.
bio.link/bitbat
Offline Sintpinty
    • My Roblox Profile
« Reply #63 on: Sat, 18 May 2019, 07:08:30 »
Personally, for my qwerty layout, i use my right pointer finger.  I also use the right pointer finger to type sentences once in a while.
bio.link/bitbat
Offline Sintpinty
    • My Roblox Profile
« Reply #64 on: Sat, 18 May 2019, 07:11:32 »
https://ibb.co/dmkW4m2
This is my typing speed over the years. I am noticing that myself, Sintpinty is getting faster but i don't want to reach a peak level for my typing speed.
bio.link/bitbat
Offline Sintpinty
    • My Roblox Profile
« Reply #65 on: Sat, 18 May 2019, 07:12:22 »
We all get it.
Rip my accuracy too. Don't you run into some slowdowns too?
bio.link/bitbat
Offline Sintpinty
    • My Roblox Profile
« Reply #66 on: Sat, 18 May 2019, 07:13:06 »
The solution? I have no fingernails  :))
« Last Edit: Sat, 18 May 2019, 07:16:15 by Sintpinty »
bio.link/bitbat
Offline Sintpinty
    • My Roblox Profile
« Reply #67 on: Sat, 18 May 2019, 07:15:38 »
To be honest, finding a good keyboard is what got me here anyways. Because i was a fast typist(am still today, but suffering from accuracy issues) , i needed a good quality keyboard that would be reliable and durable. I noticed people like Sifo and others were using mechanical keyboards when typing and they got extremely high scores.
I literally practiced every single day for four years in order to get the speed that i am today.
My highest , 123 wpm is not achieved on a mechanical keyboard, but rather a cheap dell keyboard.
I don't get as higher scores on Mechanical keyboards as much as Membrane keyboards simply because i am not used to the feel of typing on it.
bio.link/bitbat
Offline phinix
« Reply #68 on: Mon, 20 May 2019, 16:47:29 »
I always had a problem learning touch typing, but I will give it a try:)
12100 | 9070XT | 2TB SSD | ROG STRIX B760-I ITX | 32GB RAM | SFX 850W | NR200p | Ruark Audio MR1 Mark II | LG OLED 42C4
Realforce 87u55 | CM QuickFire Rapid MX Blacks | Filco TKL 85g Gateron Oil Kings | Tiger Lite 85g Oil Kings | Logitech Pro Superlight
GSA: Retro High-light  HSA: Hyperfuse  XDA: Canvas  PBS: MV Classic
Offline Sintpinty
    • My Roblox Profile
« Reply #69 on: Tue, 21 May 2019, 15:55:34 »
I highly reccomend typingclub or freetypinggame.net
Even though it's for kids, it really helped me in my younger years :)
bio.link/bitbat
Offline Sintpinty
    • My Roblox Profile
« Reply #70 on: Thu, 23 May 2019, 14:04:02 »
Ok, for further proof, i got 123 wpm on my last typing test.
bio.link/bitbat
Offline Sintpinty
    • My Roblox Profile
« Reply #71 on: Sun, 19 January 2020, 12:07:45 »
I have once typed 137 as my record
bio.link/bitbat
Offline duszek
« Reply #72 on: Thu, 07 May 2020, 16:21:34 »
I have a new idea for compendium: Make sure you don't have RSI. If you have RSI, you can definitely make this problem even worse by typing at all, more with your suggestions.
Offline Darthbaggins
  • PC Cannibal
« Reply #73 on: Fri, 08 May 2020, 13:24:08 »
due to this thread I will still work on improving my typing every evening (have been doing this for the past few months).    So far I can say working with lubed Gat Black Inks has aided in increase in my speed and accuracy (imo) could just be in my head but yeah I'll stick with it.
And the OP is a nut, but even nuts have good information from time to time, lol.
Offline Sintpinty
    • My Roblox Profile
« Reply #74 on: Tue, 12 May 2020, 11:09:33 »
141 reached as record. Finally satisfied.
Advanced needs to get better though. MX reds are wayyy too springy and i'll use them for gaming now. K63 has sh#t battery life too
bio.link/bitbat
Offline Shapey Fiend
« Reply #75 on: Fri, 15 May 2020, 09:02:12 »
I used be able to type like holy hell back in the early message board era but it feels a bit odd to write page long screeds on social media where most people are responding on phones with bullet point thoughts. There aren't many opportunities for me to practice or even think in a long form manner these days, because you can't really type faster than you think, unless we're talking about transcribing.
Offline Olumin
  • "Guy walks into a doctor's office..."
« Reply #76 on: Fri, 15 May 2020, 17:17:15 »
The real trick to increasing speed is ditching qwerty and using something efficient like dvorak.  ^-^
Don't go there.. please Quinn.... LOL....
sigh...
The Dvorak improvements have not been rigorously tested.. I've got my hopes set on that new guy with his new key analysis thingie in ergonomics forum..
But overall.. Pushing WPM speed is like opening the Eight-Gates, in Naruto..
Gate of Opening 開門:  This is where the user develops basic muscle memory of keys.
Gate of Healing 休門: This is where the user learns adaptive pacing and fast corrections.
Gate of Life 生門: This is where the user begins to forget everything else and focus concentration on transcription and decoding the information in front of him.
Gate of Pain 傷門: this is where the user overcomes the slight mental discomfort when employing such intense focus..
Gate of Limit 杜門:  this is where the user overcomes all technical limits by initiating high level techniques from advanced and advanced +
Gate of View 景門:  I don't think I've achieved this myself, it is definitely beyond the 135wpm barrier... Linkbane has achieved this gate to my knowledge... if only ya'll didn't ban him... he could tell us about it.
Gate of Wonder 驚門: To my knowledge only about 10 people has achieved this.. Sean Wrona being one of them..
Gate of Death 死門: No one has died yet..  But it has been posited that 500WPM is possible when this final gate is breached... No one has done it.. if they have, they did not live to tell about it..  Some genius sacrificed himself in commitment or in err, we may never know..
Offline Me
  • Location: Niskayuna, Capital Reigon, NY State, US, North America, The Atlantic, Earth, The Sun's Solar System, The Milky Way, The Quadrant of the Universe that the Milky Way is in, the known Universe, the whole Universe, the theoretical Multiverse, this dimens
« Reply #77 on: Sun, 02 May 2021, 21:20:06 »
I know this is super old, and probably no one will reply, but I'm in a slump. I switched over to colemak about 4 months ago, and progress was really fast, and I am now typing at about 70 WPM on average. But that is where it stopped. I have been practicing rigorously throughout the last month and my WPM has changed by maybe 5? Is there any really big thing that you need to think about to "ascend" to the next level? Maybe the "Burst Memory" will help me. I too play the piano and I know what you mean by it, but I feel like sometimes my fingers just aren't confident about a word and then I make a typing error. I am in the process of building a mech, so maybe the tactility and/or clickiness will help, but I really don't know.
"In the end...the keyboard's most grand form of existence is as an ethereal bridge between man and machine...Each depression of the keys, evanescent.. Our transitory thoughts crashing into the web, carving canyons through the internet wasteland such that life may once again flourish..."
tp4, compendium of speed, 2015
« Reply #78 on: Sun, 02 May 2021, 22:08:22 »
What are you typing on the measurement, and what was your speed before the change to colemk.
Offline Me
« Reply #79 on: Sun, 02 May 2021, 22:14:14 »
My speed before colemak was less, probably around 50-60 WPM though I never took a typing test. And I tried all sorts of membrane keyboards, from a chromebook to a lenovo laptop keyboard, but I have yet to type on a mechanical keyboard so far. I am building one though, so that might help.
« Reply #80 on: Sun, 02 May 2021, 22:34:38 »
Lenovo butterfly is the easiest to time when it comes to typing speed/ repetition.  The mechanical won't impact your performance mechanically, but it may serve as psychological motivation to push you into the next lvl.
Offline Me
« Reply #81 on: Sun, 02 May 2021, 22:53:09 »
Ok, so that's something, but I was wondering if there was some major thing that I am missing that will help get me to that 100 WPM mark(that is my goal for the next couple weeks or so).
« Reply #82 on: Sun, 02 May 2021, 23:01:19 »
Read the text, type it, don't try to comprehend it in any way, saves processing power, move faster.
Offline Me
« Reply #83 on: Sun, 02 May 2021, 23:12:04 »
About that. I noticed that I am alot faster when I am writing the text out of my brain rather than trying to replicate text off of, let's say, a typing test. Could this have something to do with the fact that you have to read the text or is it just normal? Also, I know that there isn't much to say about technique here since I can't really describe the way that my fingers move when typing, but after reading your original post, I was slightly confused by the fact that typing isn't all a string of text but rather, has a rhythm. Can you describe how you would move your fingers to a rhythm when typing?
« Reply #84 on: Sun, 02 May 2021, 23:24:59 »
i read a lot slower than my fingers can move, most of my mistakes are because i misread a word or inserted a word that wasn't actually there.
to the latter point try using a metronome while doing a test, just like practicing music or something, gradually increase the BPM starting from slow to fast. good way to practice rhythm typing. eventually it becoems second nature and you have an internal BPM that works for you. my preferred bpm is 173 for reference
Offline Me
« Reply #85 on: Sun, 02 May 2021, 23:34:59 »
Ok, that metronome idea sounds like something that I might try out. Is there a way that you found out to combat this reading slower than you type issue or is it still in the works.
« Reply #86 on: Mon, 03 May 2021, 00:54:19 »
don't think there's anything i can do to fix that other than to read more often which i don't really do
« Reply #87 on: Mon, 03 May 2021, 01:06:21 »
I don't think you could establish a fixed rhythm unless you're typing the same text each time.
If you reorder even a same set of words, it's a completely different rhythm because the transitions are different.
The use of the metronome in random text would have less to do with hand timing, and more to do with pacing your reading so you don't over/undershoot the synchronization window between hand / brain coordination.
« Reply #88 on: Mon, 03 May 2021, 01:07:18 »
yes exactly
Offline Me
« Reply #89 on: Mon, 03 May 2021, 08:59:44 »
ok, that makes some sense
Offline Me
« Reply #90 on: Mon, 03 May 2021, 09:02:13 »
Well I read quite a lot for a normal human being and the issue still persists, but I had an idea as to why and it was one of tp4's original answers to my query. Maybe I read the word, and I actually try to comprehend the word and then type it rather than just trying to type the word right off of the bat. Then, my fingers catch up to my eyes and I make an error.
