Author Topic: [GB] TMK Alps64 - 60% PCB for Alps  (Read 1564552 times)
Offline Hzza
Re: [GB] 60% ALPS PCB
« Reply #250 on: Wed, 27 May 2015, 05:20:43 »
I'll see what I can do. Do you need shots of the PCB as well or just from the top side?
Offline hasu
  • @tmk
« Reply #251 on: Wed, 27 May 2015, 05:52:19 »
Pic of top side is nice enough. Thanks.
Offline Applet
« Reply #252 on: Wed, 27 May 2015, 08:15:59 »
Applet, could you post pic of bottom of Matias keycap? I'd see its mount position.
Sure, here is a pic of the cap:
EDIT: Modded the PCB to fit my Matias-enter today, it's not pretty but works great (even the stabs) :)
« Last Edit: Wed, 27 May 2015, 11:53:42 by Applet »
Offline hasu
  • @tmk
« Reply #253 on: Wed, 27 May 2015, 20:00:24 »
I checked one of my Alps keyboard this morning, it is not an ISO and even not JIS keyboard but it has ISO/JIS type enter key and made by ALPS. This enter key has different mount position from Matias and it also doesn't mach with Rev.A PCB.
I'll fix PCB design for ISO enter key, I think it solves this problems. But if you have a plan to use ISO enter layout check your keyboard.
And post pics of your keycap and keyboard like my pics above.
Offline hasu
  • @tmk
« Reply #254 on: Wed, 27 May 2015, 22:34:17 »
Fixed. Rev.B supports three different locations for ISO Enter key(K23).
Rev.B
Rev.A
Offline DanielT
« Reply #255 on: Thu, 28 May 2015, 00:58:19 »
Rev.A users,
did anyone try other case? Currently PokerX and Pure CNC case were confirmed.
Aren't  there anyone with Poker 2 and Poker 3 case to try the PCB?
In particular Poker 3 has no tolerance on its connector hole, so I'd like to know if it can fit into the case.
From first post:
- Confirm case fitness
    - Poker X original plastic case OK OK
    - Pure CNC metal OK
    - Poker 2
    - Poker 3
    - V60
    - Other custom cases
I have on mine a Poker II case amd it works just fine, the USB connector has no clearance problems. Also the alu Hammer case works fine :)
Offline hasu
  • @tmk
« Reply #256 on: Thu, 28 May 2015, 01:09:03 »
Great.
Updated the list of confimed cases in the first post. Thanks.
Offline Hzza
« Reply #257 on: Thu, 28 May 2015, 03:16:14 »
Sorry for the delay in getting back, the light was gone when I got home so had to get these before work this morning :D.
Ignore the dirty plate, this has been on my "manky keyboard" shelf for a few years now, I'll give it some love now that it has a purpose in life :D.
edit - Just to clarify as well, the board is a Dell AT102W.
« Last Edit: Thu, 28 May 2015, 03:18:00 by Hzza »
Offline hasu
  • @tmk
« Reply #258 on: Thu, 28 May 2015, 06:09:21 »
Thanks for posting the pics.
Dell AT102W Enter looks like same as my Alps board.
Rev.B PCB will work with Dell and Matias ISO Enter key, while Rev.A doesn't work with both of those.
I'll send invoices to all participants tomorrow and order PCB and components before long.
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #259 on: Thu, 28 May 2015, 07:04:52 »
Really Appreciate for Your Great Job!    ;)
Alps boards have wide variety of caps' form factors,
So we know it's a real hard task!   :thumb:
Offline BlueBär
« Reply #260 on: Fri, 29 May 2015, 15:40:37 »
Did you receive my PM hasu? Don't see myself in the order list.
« Reply #261 on: Fri, 29 May 2015, 20:11:05 »
As soon as I get my Leeku stuff all paid for, I'll probably be grabbing another PCB.
Offline hasu
  • @tmk
« Reply #262 on: Fri, 29 May 2015, 21:28:01 »
Updated the order list. Invoices will sent soon.
I changed shipping cost calc a bit, please check it.
Price
Assembled PCB: $35
    includes unsoldered diodes(through hole device). You have to solder the diodes(and switches, of course) yourself.
    All SMT components except for the diodes are soldered on PCB by me.
UnAssembled PCB: $22
    This includes blank/empty PCB and compoenents including diodes. You have to solder all components yourself.
Raw PCB: $12
    Just blank/empty PCB only.
Shipping: $10   $8.5 + $1.5 * (# of PCB)
    Registered air mail with insurance. It takes 7-10 days to most of countries
    If you order two PCBs add $2.    Add $1.5 per PCB to base cost $8.5.
    Note that shipping cost for a PCB is $10, not $8.5.
For example,
    One Assembled PCB: 35+10=45
    Two Assembled PCB: 35*2+10+2=82 35*2 + 8.5 + 1.5*2 = 81.5
And what you have to know is ISO enter problem which found after this second round begun. Rev.A PCB doesn't work with ISO enter key from Matias and Dell 102W at least. To fix this ISO enter problem I updated PCB design and it became Rev.B now. See posts around this one for the detail.
https://geekhack.org/index.php?topic=69740.msg1760955#msg1760955
I expect Rev.B works with Matias and Dell 102W ISO enter key but not confrimed yet.
And check Caveat entries in the first post again before payment.
Caveat
- PCB design is not changed, quite same as first run(Rev.A). Changed to fix ISO enter problem and PCB is Rev.B now.
- Assembled PCB are soldered all electric components except for diodes and swtiches.
- You'll get unsoldered diodes(around 70) if you order 'Assembled PCB'. Diodes are for Through Hole, not for Surface Mount.
- Raw PCB($12) is available but components are not. Please buy them from digikey, mouser or etc. and you can take components for $10.
- Confirmed the PCB fits into Poker X, Poker II, Hammer Alu and Pure CNC case, but unclear about other cases including Pok3r and V60 at this time. See TODO section below.
- Most of layouts are confirmed but 'Infinity bottom row' and 'bigass enter' are not tried yet. See TODO section below.
- Order will be prioritized depending on the list.
Feel free to ask me if anything is unclear.
Offline jevvix
« Reply #263 on: Fri, 29 May 2015, 21:59:49 »
Can you please change me to 3 raw pcb please. I have to do a digikey order and I'll pick up the components myself.
Do you have a list of smd parts anywhere with package size? And do you have a precompiled .hex file anywhere?
Offline hasu
  • @tmk
« Reply #264 on: Fri, 29 May 2015, 22:29:00 »
jevvix, Here is BOM. No hex at the moment. No hex at the time.
Code: [Select]
BOM for Alps64 keyboard
Ref             Value           Footprint               Component
C1              4.7u            C_3216                  any
C2              1u              C_1608                  10%
C3              22p             C_1608
C4              22p             C_1608
C5              0.1u            C_1608
C6              0.1u            C_1608
J1              USB_mini_B      USB_miniB_hirose_new    UX60SC-MB-5S8 Hirose
R1              22              R_1608
R2              22              R_1608
R3              10K             R_1608
SW100           SW_PUSH         SW_ALPS_SKRP            ALPS tactile switch
U1              ATMEGA32U2      QFP32                   ATMega32u2 Atmel
X1              CRYSTAL         FA-238                  16MHz
D*64            DIODE           SOD-123 or Axial        1N4148
Offline hasu
  • @tmk
« Reply #265 on: Sat, 30 May 2015, 17:38:53 »
Thanks for your quick payments, all.
Updated the list in the first post, let me know if I missed your payment.
Offline jevvix
« Reply #266 on: Sun, 31 May 2015, 07:24:15 »
Paid just now. Thank you!
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #267 on: Sun, 31 May 2015, 12:41:59 »
Invoice  paid.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline sprit
« Reply #268 on: Sun, 31 May 2015, 13:27:39 »
Appreciate Your Great Job !   ;)
« Last Edit: Sun, 31 May 2015, 14:07:36 by sprit »
Offline wakko
« Reply #269 on: Sun, 31 May 2015, 13:56:37 »
Payment sent
NOOB
KUL ES-87
Offline badboybry9000
« Reply #270 on: Sun, 31 May 2015, 15:32:00 »
Payment sent. Thank you very much for all your hard work, everyone!
Offline hasu
  • @tmk
« Reply #271 on: Sun, 31 May 2015, 17:02:08 »
Updated again.
Offline limster
« Reply #272 on: Sun, 31 May 2015, 21:40:20 »
Paid, and PM sent.
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #273 on: Sun, 31 May 2015, 23:27:36 »
Payment and PM sent, thanks!
Offline cheddarbek
« Reply #274 on: Mon, 01 June 2015, 18:42:25 »
Payment and PM sent.
I'm excited!
The Alps cover 65% of Switzerland's surface area (41,285 km²), making it one of the most alpine countries. Despite the fact that Switzerland covers only 14% of the Alps total area (192,753 km²),[2][3] many alpine four-thousanders (48 of 82) are located in the Swiss Alps and practically all of the remaining few are within 20 km of the country's border.
Offline spoonypirate
« Reply #275 on: Mon, 01 June 2015, 18:56:23 »
I'm excited!
Me too!
Offline njbair
    • nickbair.net
« Reply #276 on: Mon, 01 June 2015, 19:56:36 »
I paid yesterday and still don't see my name updated. Did you get it, hasu?
My boards:
Offline jevvix
« Reply #277 on: Mon, 01 June 2015, 20:49:27 »
I have started an interest check for a small group buy of Apple M3501 keyboards at a https://geekhack.org/index.php?topic=72438.0 These would be perfect donors for this PCB. Please leave any comments in that thread to keep this one clean.
(thank you Hasu for permission to post this!)
Offline hasu
  • @tmk
« Reply #278 on: Tue, 02 June 2015, 01:24:34 »
Thanks all for making quick payments.
Closed second run and finally updated the list again, let me know if I missed your payment.
I'll place order for PCB and components in a few days.
njbair, yes got paid.
Offline hasu
  • @tmk
« Reply #279 on: Thu, 04 June 2015, 00:06:13 »
Placed an order for Rev.B PCB of second run. Turn around is around 10 days.
I ordered some extra PCBs and still have room to take extra order. PM me if you like to get the board.
Offline Karura
  • SKidata life.
« Reply #280 on: Thu, 04 June 2015, 01:00:56 »
Glad to hear it Hasu!
For those on the second run, does anyone want to organize a plate GB? I'm not located in the US, so it wouldn't be optimal for me to do it, but perhaps we could get help from the hosts of the first plate GB!
Offline jevvix
« Reply #281 on: Thu, 04 June 2015, 21:04:44 »
Where would you get the plate mounted stabilizers from?
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #282 on: Thu, 04 June 2015, 21:10:44 »
I think mainly from old ALPS boards.
WTB/WTS/WTT ---->
« Reply #283 on: Thu, 04 June 2015, 21:32:08 »
You would either get the stabilizers from old Alps boards, or use Costar stabilizers with the caps from the Infinity Alps GB.
What layout do people want for a round 2 of plates? nubbinator might be willing to run another round after the first round is complete, if we ask nicely. I would design the plate, if people can come to some consensus about which layout to make.
Offline njbair
    • nickbair.net
« Reply #284 on: Thu, 04 June 2015, 21:39:06 »
I saw some mention of interest in a dell layout in the AEK II plate IC thread. What are the differences between the two?
My boards:
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #285 on: Thu, 04 June 2015, 23:20:29 »
The bottom row. The Dell AT101w has all 1.25 modifiers on the bottom row (Like a Poker).
I would be down for a Dell plate. The only down side I can see is that the AT101W doesn't have the best keycaps (pad printed ABS).
WTB/WTS/WTT ---->
Offline Pyrelink
« Reply #286 on: Thu, 04 June 2015, 23:32:57 »
I would still be really interested in a Round 2 of the AEK 2 plate again.
Offline cheddarbek
« Reply #287 on: Fri, 05 June 2015, 00:27:02 »
I'd love a AEK 2 plate. I'd be much happier using a plate as opposed to further butchering an AEK 2 donor board.
Offline RickyJ
« Reply #288 on: Fri, 05 June 2015, 01:34:50 »
My goal is Poker-style ANSI, with either 1.5 or 1.25 mods. I have bigass-enter 1.5 mod sets, and joined the Infinity mod set group buy to modernize the layout and stabs (though I don't have any Costar).  Once upon a time, I had a nice ANSI doubleshot set, but I lost it during a move (must be hiding with some of my missing SMD tools).  So for me right now, my preference would be a plate that would accommodate the Infinity-style stab layout with either 1.5 Ctrl/Alt and 7x space, unless I can find 6.25x space somewhere to then use 1.25x mods.
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
« Reply #289 on: Fri, 05 June 2015, 08:31:52 »
I would also love an AEK 2 plate simply because the AEK 2 key caps are really nice.
Offline sprit
« Reply #290 on: Fri, 05 June 2015, 08:40:28 »
For me,  AEK2 Caps are The Best of the best caps for many years.    very comfy shape, nice type feeling & thick Dyesub.
Legend Colors vary from dark blue - dark Greenish - dark Purple -ish   :-*
No worries on the price and availability,  relaxed to enjoy typing Dyesub caps everyday.
« Last Edit: Fri, 05 June 2015, 21:03:26 by sprit »
Offline cheddarbek
« Reply #291 on: Fri, 05 June 2015, 12:18:43 »
I love the caps on the AEKII I use at work.
I'm planning on getting one as a donor for this build either from the AEK2 group buy, or on ebay.
Speaking of caps, does a AEK2 sized PBT alps spacebar exist anywhere? I'd love to replace the ABS one on my work board, as well as the one for this build.
Edit: alps
« Last Edit: Fri, 05 June 2015, 16:26:13 by cheddarbek »
Offline wakko
« Reply #292 on: Fri, 05 June 2015, 14:35:25 »
^^ what said.
NOOB
KUL ES-87
Offline Karura
  • SKidata life.
« Reply #293 on: Fri, 05 June 2015, 16:13:55 »
Speaking of caps, does a AEK2 sized PBT spacebar exist anywhere? I'd love to replace the ABS one on my work board, as well as the one for this build.
Is there a GB for AEK2? I would love to get one too for this 60% build. Link please!
« Reply #294 on: Fri, 05 June 2015, 16:20:57 »
Closed, though. https://geekhack.org/index.php?topic=71416.0
« Reply #295 on: Fri, 05 June 2015, 16:26:06 »
Mainly because I'm doing it out of pocket right now and they are obscenely slow and bad about communication.
Offline Karura
  • SKidata life.
« Reply #296 on: Thu, 11 June 2015, 07:23:27 »
Hopefully we can figure out a better way to proceed the second time around, and I'd not want you to do it out of pocket either.
Also do you guys think this case would be a good fit for this project?
https://www.massdrop.com/buy/tex-metal-case?utm_source=Sailthru&utm_medium=email&utm_campaign=Transactional%3A%20Drop%20Request%20Launched&mode=guest_open
« Reply #297 on: Thu, 11 June 2015, 08:15:49 »
Yes, that would be a good one.
You can get it without waiting for Massdrop, here.
Offline Karura
  • SKidata life.
« Reply #298 on: Thu, 11 June 2015, 17:41:53 »
That's also a nice case, but a little different from the one I linked! I prefer the Massdrop one with the uniform edge thickness (the MK one is thicker at the front) :)
« Reply #299 on: Thu, 11 June 2015, 18:48:07 »
The black version on MK has the uniform wall thickness. I personally really like the thicker front edge. But Tex confuses me...why change the design and have both floating around for sale without somehow differintiating one from the other?
