Author Topic: [GB] TMK Alps64 - 60% PCB for Alps  (Read 1564552 times)
Offline punkpc
Re: [GB] 60% ALPS PCB
« Reply #150 on: Sun, 19 April 2015, 08:54:17 »
Is there any of these boards left available to buy?
Offline Applet
« Reply #151 on: Wed, 22 April 2015, 11:29:57 »
Got my PCB in the mail today and it looks good! Can't wait to put it all together but probably wont have time until end of next week. Thanks for this project, I love it  ;D
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #152 on: Wed, 22 April 2015, 15:06:59 »
Everything arrived today safe-and-sound. Like Applet, it'll be a little bit before I have the time and the switches to build it up.
Thanks hasu for doing this and thank you for the lube!
Offline FrostyToast
  • Litshoard
« Reply #153 on: Wed, 22 April 2015, 15:23:16 »
Please do a video comparing blue ALPS to click molded orange.
I don't care if you wont have a full board but I do want to see what it's like.
Quote from: elton5354
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #154 on: Wed, 22 April 2015, 17:59:38 »
Alps switches  :  A limited personal opinion
*  The sliders are basically same shape, regardless of its material composition n smoothness variety, IMO.
*  The center coil springs are definitely different in each switch type.
*  the 1st contact leaf springs look similar, but differ in angles, shapes, etc
*  2nd leaf springs have obviously different angles, thickness, shapes in detail with each type of ALPS
*  You may get very similar feels with original leaf & coil springs, but limited feels w modded leaf springs.
*  There were Alps electronic parts OEM factories in Korea, Taiwan, Mexico, etc in '80-90's.
*  Reminds me a dozen of Cherry MX clone Factories in China at this moment.
*  Need to discuss n share infos among GH members.
Clicky  -  Blue, White clicky
Linear  -  Tee stem (as in Apple 0100, 0110, 0110a), Brown, Green linear
Tactile  -  Salmon(Pinky), Orange, White, White w rubber feet, Cream, Cream w rubber feet, Black Tactiles
Mod to Linears  -  take 2nd leaf springs off  :  blue linears,  salmon linears,  orange linears,  cream linears, white linears,  black linears  etc
Mod to Tactiles  -  Blue Tactiles w Orange(salmon)2nd leaf springs,  Green Tactiles w white leaf springs,  Black Tactiles w Salmon leaf springs  etc
Mod to Clickys  -   Vice versa   As far as i experimented
« Last Edit: Thu, 30 April 2015, 19:28:23 by sprit »
« Reply #155 on: Wed, 22 April 2015, 18:01:57 »
If I have any to spare, I'll look at doing it.
« Reply #156 on: Thu, 23 April 2015, 23:49:20 »
I just got my PCB today.  I'm debating between butchering my AEK II plate or making a new one for the PCB.  I've got a file made up for costar stabilized switches (you'd need to mod the wire) or if someone wants to edit it for Alps, that would be great.  I was looking at BigBlueSaw for plates.  If anyone is interested, let me know and the material you're interested in so I can get some made.  It only really is worth it if 5+ people want a plate made. I may have another source that can be cheaper, but I won't make any guarantees on that until it's confirmed.
Material and cost breakdown at 5-9 units, before additional shipping cost. Unless otherwise specified, pricing is with the standard waterjet not low-taper since it's a relatively thin piece of material:
  • 0.05in 5052 or 6061 Aluminum - $35.20 raw, $42.54 with basic finish; $46.48 low-taper waterjet cut, $52.82 basic finish, $57.62 bead blast
  • 0.06in laser cut acrylic - Clear $19.36
  • 0.063in Black Acetyl Plastic - $34.40
  • 0.063in Clear PETG Plastic - $21.96
  • 0.06in Clear Polycarbonate Plastic - $34.10
  • 0.0598 Cold Rolled Steel A366/1008 - $44.40
  • 0.048in Cold Rolled Steel A366/1008 - $40.88
  • 0.048in Stainless Steel T-304 - $41, $47.34 with basic finish
  • 0.06in Stainless Steel T-304 - $45.08, $51.42 with basic finishing
  • 0.06in Stainless Steel 316 - $44.64, $50.98 with basic finishing
There are other options, but most are outside the 0.05-0.06in thickness range you need for the stabilizers to fit.
« Reply #157 on: Fri, 24 April 2015, 11:08:30 »
I'd be interested in one of the stainless steel options.
« Reply #158 on: Fri, 24 April 2015, 11:18:04 »
I'd be interested in a 0.06 T-304 plate.
If you need me to make an exact replica of the AEKII plate, I can do that. Complete with Alps stab holes and everything. Let me know.
Offline mashby
    • Mashby
« Reply #159 on: Fri, 24 April 2015, 11:51:29 »
I'd follow CPTBadAss and jdcarpe lead. Whatever they get is what I'd go for as well and I'd like to get at least two.
Offline FrostyToast
  • Litshoard
« Reply #160 on: Fri, 24 April 2015, 12:05:05 »
A stainless steel plate would be great.
« Reply #161 on: Fri, 24 April 2015, 12:38:13 »
Looks like 0.06in T-304 stainless it is.  I'll see if I can find a cheaper option, if not, BBS it is.  So far we're looking at 6 or 7 plates since I'm probably going to grab two.  The next price break with BBS is at 10 but I'll have to wait until I get home to see what it is.
I'm assuming people might like powder coated as well as long as that doesn't mess up the cutout tolerances, so a raw plate should be fine.  I know it's not necessary with T-304, but it does change the aesthetics.  I can look at trying to find a place locally, seeing if a guy I know who does metalwork for boats can do it, or look at a cheap harbor freight gun and cheap toaster oven if people are interested in that.
Also that would be great JD.  I don't know if you want the one that swill's tool spat out with Costar stabilizers or if you'd prefer to make it from scratch, just let me know either way.
« Last Edit: Fri, 24 April 2015, 12:41:29 by nubbinator »
« Reply #162 on: Fri, 24 April 2015, 12:39:39 »
I've got no preference on the plate color. Whatever people want :)
Offline FrostyToast
  • Litshoard
« Reply #163 on: Fri, 24 April 2015, 12:40:53 »
For the colour we could go with something unique such as white seeing as how it's the only colour unattainable through anodized aluminum.
Or we could be baller and get gold powder coating.
Offline jou
« Reply #164 on: Fri, 24 April 2015, 19:12:22 »
No but if second run occurs I'll make contact with you and others who displayed their interest here.
*displays interest*
Offline henz
  • What?
« Reply #165 on: Sat, 25 April 2015, 15:17:24 »
for those who missed this, kin is making a tkl alps board, you can find it in the IC gb going to start beginning of may i belive. Same as here though, you need to slaughter a old kb to get a plate.
EDIT: And for the record, if round 2 happens, im in.
Offline echo0
« Reply #166 on: Sun, 26 April 2015, 10:34:45 »
Interested in getting one to two round 2 PCB.  Also interested in the plate, whichever would be decided.   :thumb:
« Reply #167 on: Sun, 26 April 2015, 18:44:45 »
Sent out a bunch of quote requests locally with the update file from JD.  BBS is $40.82 for 5-9 or $36.89 for 10-49 in 0.06in T-304 + shipping + reshipping.  Also looking into other possibilities.
« Reply #168 on: Mon, 27 April 2015, 20:13:44 »
One local quote came back at $21.50 per plate for laser cut and another came back at $29 for waterjet cutting.  I'm waiting to hear back from the others.
Personally, I'm willing to pay the extra $8.50 a plate for waterjet cutting since it tends to be a nicer finish even though the tolerances are marginally worse.
Here's a form so I can get an idea of numbers.  Plate price may go down if we get more.  I'm definitely getting 2 at $30 a pop, maybe some more as extras.
Also did a legit GB listing that's awaiting mod approval in case there are more people who want in outside of the group here.
« Last Edit: Mon, 27 April 2015, 20:32:07 by nubbinator »
Offline njbair
    • nickbair.net
« Reply #169 on: Mon, 27 April 2015, 20:16:03 »
If we had a commitment on a round 2 I would totally get in on the plate buy. Ugh.
My boards:
« Reply #170 on: Mon, 27 April 2015, 22:46:56 »
I'd get 2 plates at $30 nubbs
« Reply #171 on: Mon, 27 April 2015, 23:38:38 »
I noticed you wanted laser cut, I'm probably not well versed enough, but could you explain for those like me why you would take one over the other?  I'm game for other, but would love to hear the pros and cons of each from someone better versed in it than me.
Offline njbair
    • nickbair.net
« Reply #172 on: Tue, 28 April 2015, 00:45:13 »
Cheaper, more precise. That's probably it.
High volume stuff is still usually stamped for cost reasons.
My boards:
Offline rsadek
  • raging keyboard monkey
« Reply #173 on: Tue, 28 April 2015, 01:51:29 »
Same here! I signed up on the plate form anyway....but I need those PCBz!
❤️Keeboardz
Offline margo baggins
  • Dungeon Dweller
  • Get back to work!
« Reply #174 on: Tue, 28 April 2015, 05:00:21 »
I should come on forums more! v.sad I missed this one :(
I got boards.
Offline deci
« Reply #175 on: Thu, 30 April 2015, 15:30:23 »
Oh damn. Sad I missed this.
Hasu please put me on the list for an assembled PCB and plate if you ever do another run.
I really want to put some clicky alps into my Duck Eagle case.
Thanks
Offline hasu
  • @tmk
« Reply #176 on: Thu, 30 April 2015, 22:24:24 »
Anyone have problem on Rev.A PCB?
Let me know anything you found so that I can fix them before next order.
I want to know:
- USB connector fits in your cases?
- Diodes and other components doesn't interfere with inside of case?
- Screw holes are ok?
- Key switch position is proper for your layout?
Problem I found so far is:
- USB connector is misaligned a blt.
Thanks,
Offline sprit
« Reply #177 on: Thu, 30 April 2015, 23:53:27 »
Thanks,
USB position a bit to the left?   ;)   Seems Not a problem.    Thanks!
Offline ctm
  • Hello, world!
« Reply #178 on: Fri, 01 May 2015, 10:41:38 »
Just want to double check, the switch under 1.75u backspace will be installed backward compared to other switches right? I am asking because my Matias switches feel a little differently depending on where they are pressed. Pressing from upper part makes it more tactile while pressing on lower part makes it more linear. (btw is this common among all ALPS or is it just Matias?)
Coming:
Ellipse Model F F62.
Offline hasu
  • @tmk
« Reply #179 on: Fri, 01 May 2015, 14:18:25 »
Yeah, not big problem but it will be fixed in next revision.
With my Poker X case it looks like this. I'd like to know how it looks in other cases.
Offline Touch_It
« Reply #180 on: Fri, 01 May 2015, 14:22:23 »
I've heard other people say this specifically about Matias.  I will try to experiment with this tonight and let you know
Offline hasu
  • @tmk
« Reply #181 on: Fri, 01 May 2015, 17:35:14 »
I don't feel tactile weirdness of backspace and other keys on AEK layout of orange Alps switches but I'm not so picky and have no sensitive fingers. But I can hear different sound(of tacile spring?) from every switches when pressing upper and bottom edge. I think it comes from structure of Alps switch.
Tried Simpliefied black switches, ah yes, I could feel a bit difference of tactility but it won't be big problem to me. I don't have Matias at hand now but I think structure of Matias is similar to rather Simplified one than Complicated.
Offline ctm
  • Hello, world!
« Reply #182 on: Fri, 01 May 2015, 19:12:22 »
This tactile inconsistency is much less perceptible on keys with stabilizers. It's not very obvious if you don't pay attention to find it. Actually I never realize it until I read this thread https://geekhack.org/index.php?topic=54392.0. But when I pay attention to it, it's indeed there, especially easy to feel it on top rows like number row. When pressed near bottom, it's like a soft tactile, whereas near top edge, it almost like a click.
Coming:
Offline Heliosphere
« Reply #183 on: Fri, 01 May 2015, 21:08:53 »
I'm in for a possible round 2.
Offline FrostyToast
  • Litshoard
« Reply #184 on: Fri, 01 May 2015, 21:10:29 »
I don't have a board soldered up yet.
I will eventually so I will post pictures then.
Although if you want a picture of the usb positioning I guess I could provide that without assembly.
Offline sprit
« Reply #185 on: Fri, 01 May 2015, 21:55:39 »
The Poker 1, 2 PCB itself is not centered for the USB connector, a bit to the left.
Your Alps PCB looks nice w that issue!    ;)    Wonderful Job!    :thumb:
« Last Edit: Sat, 02 May 2015, 18:18:08 by sprit »
Offline hasu
  • @tmk
« Reply #186 on: Sat, 02 May 2015, 17:01:38 »
Yes, you don't have to solder, just try installing it into your case. Pic would be appreciated. Thnaks.
I found Pok3r has less tolerance in its new aluminum case. I think someone want to use it with the PCB, we need to check.
http://roastpotatoes.github.io/2015/04/29/pok3r-review/
Offline ctm
  • Hello, world!
« Reply #187 on: Sat, 02 May 2015, 17:10:47 »
KBP V60 case also have a pretty small tolerance on USB port.
99279-0
Coming:
Offline njbair
    • nickbair.net
« Reply #188 on: Sat, 02 May 2015, 18:36:31 »
Wow no kidding. Like zero.
My boards:
Offline DanielT
« Reply #189 on: Tue, 05 May 2015, 06:03:11 »
Today I picked up my PCB from the Customs Office, I'm the happy owner of PCB number 7  :cool:
Now is  time to butcher my Dell and build this board :D
Thanks Hasu  :thumb:
Offline Applet
« Reply #190 on: Tue, 05 May 2015, 15:05:14 »
Soldered and programmed my board yesterday, so far everything works great with the PCB. The plate I modded for this is not pretty and might need further modding (I don't have a ISO enter to try my stabs). This is how it looks now, I really need the new caps Matias is working on :P
Don't worry about my drawing on the keycaps, they are not great (from a rubber dome) and the ink rubs off with some effort.  ;D
Offline hasu
  • @tmk
« Reply #191 on: Tue, 05 May 2015, 15:56:58 »
Thanks for posting pic! Nice legends :D
ISO keys, HHKB Rshift and split Backspace seem to work somehow, good to know.
Offline Hzza
« Reply #192 on: Tue, 05 May 2015, 15:58:59 »
I'm also really happy they work :D.
« Reply #193 on: Tue, 05 May 2015, 16:11:48 »
Ugh I keep forgetting to do great fits on my pure stock case and pure cnc case.
Offline DanielT
« Reply #194 on: Wed, 06 May 2015, 02:00:14 »
That's one bad ass board the symbol of a prototype board :D Love seeing boards being built and I think this was the whole point of this project. I started working on mine, tomorrow I'm working from home just to finish this beauty  :cool:
Offline Applet
« Reply #195 on: Wed, 06 May 2015, 04:00:29 »
Did you not expect this configuration to work? :)
Glad you like it, I hope you all post pics of your boards when they are done, I'm looking forward to seeing them :D
Offline DanielT
« Reply #196 on: Thu, 07 May 2015, 06:16:04 »
I have finished my board. I'm more than happy, it looks and works amazing. I can confirm that Dell layout works 100%, more than that, you can cut the plate without affecting any of the stab mounts. Is perfect. Now I have to learn how to program it :). I have black Alps, which are quite nice, I didn't had any other choice anyway  :p I think I will mod them to linear Alps, but not today.
Thanks Hasu for this opportunity !  :thumb: You did a great job designing this PCB, for the first time I type on Alps on my favorite form factor 60%.
This is board Nr.7 , and I'm the proud owner  :cool:
99738-0
Offline DanielT
« Reply #197 on: Thu, 07 May 2015, 06:20:44 »
When I have some spare time I will upload the photos and make a thread with the build of this board, maybe it will be helpful for others. Now I have to learn how to use TMK firmware, because on the default layout I don't have Fn :( and I need my function layer  :p
Offline Hzza
« Reply #198 on: Thu, 07 May 2015, 06:21:08 »
Niiiiiiiiiiiiiiiiiiiice!
Speak to 7bit and get some Matias switches in there ;).
Offline sprit
« Reply #199 on: Thu, 07 May 2015, 06:22:35 »
Soldered and programmed my board yesterday, so far everything works great with the PCB. The plate I modded for this is not pretty and might need further modding (I don't have a ISO enter to try my stabs). This is how it looks now, I really need the new caps Matias is working on :p
Good Job!   :o :o   I guess You can get caps from Apple Extended anytime   :thumb:
