Author Topic: [GB] TMK Alps64 - 60% PCB for Alps  (Read 1551985 times)
Offline njbair
    • nickbair.net
Re: [GB] 60% ALPS PCB
« Reply #300 on: Thu, 11 June 2015, 18:52:05 »
That's also a nice case, but a little different from the one I linked! I prefer the Massdrop one with the uniform edge thickness (the MK one is thicker at the front) :)
The black version on MK has the uniform wall thickness. I personally really like the thicker front edge. But Tex confuses me...why change the design and have both floating around for sale without somehow differintiating one from the other?
Because a lot of these small companies don't understand product marketing. They never consider how confusing their own product offerings may seem to the uninitiated potential customer.
My boards:
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #301 on: Thu, 11 June 2015, 18:59:20 »
Personally I like the uniform side-walls but I can also appreciate why some may prefer the designs of the thicker front sidewall, as it looks great too.
The black case they're selling on MK is actually not the same case as the one offered on Massdrop:
The case on MD is made by TEX, CNC'd, and anodizing is performed by the factory that does anodizing for Lian-Li computer cases.
The case on MK is made by VORTEX, is not CNC'd but cast aluminum instead, not sure where the anodizing is done.
Profile is also a little different! Both have low bezels (floaty), but the TEX is flat and uses aluminum feet while VORTEX has the incline built into the case itself.
Not to be a stickler for details, but just hoping to educate and clarify the differences :) Cheers
P.S. Also, I would much prefer the VORTEX PURE case which is their 60% case but CNC'd instead, but they are rare these days :(
« Last Edit: Thu, 11 June 2015, 19:03:02 by Karura »
« Reply #302 on: Thu, 11 June 2015, 19:04:22 »
Are the vortex cases anodized or powder coated?  Cast aluminum is not easily anodized and is more expensive to anodize.
Offline hasu
  • @tmk
« Reply #303 on: Thu, 11 June 2015, 19:09:40 »
Those cases appear to have thicker PCB support fins than plastic Poker case does. I'm not sure this PCB has enough clearance for the thick fins, current clearance is around 2.3mm in design but it may depends on how you solder diodes too.
And you may want to note difference of plate height between Cherry and Alps when you case has shallow bezel like those cases.
Alps plate is 4.5mm high from PCB surface while Cherry is 5.0mm.
http://media.digikey.com/pdf/Data%20Sheets/Cherry%20PDFs/MX%20Series.pdf
http://deskthority.net/w/images/6/68/Forward_Electronics_--_spec_--_SKBMFA.pdf
« Last Edit: Thu, 11 June 2015, 19:18:05 by hasu »
« Reply #304 on: Thu, 11 June 2015, 19:25:37 »
Sorry, I should have given the link. The black Tex case I was referring to is this one: http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=630
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #305 on: Sat, 13 June 2015, 06:09:28 »
Any ideas about a plate gb yet, whether it be another round of AEK ll, or something else?
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
« Reply #306 on: Sat, 13 June 2015, 09:17:45 »
I think it would make sense to run the next one as a standard ANSI plate, for those with caps from the Dell AT101 or what have you. People could trade with others to get the AEK II ones, if some people ordered more than what they needed.
We will just have to wait until nubbinator is finished with the current plate buy, and see how he feels about running another one.
Offline hasu
  • @tmk
« Reply #307 on: Thu, 18 June 2015, 15:19:46 »
Got PCBs the other day. They are not great and typical for cheap PCB houses but good enough for our requirements. Every PCB has some tiny cosmetic scars and screw cutouts on edge are solder masked unlike Rev.A for some reason.
EDIT: This pic shows the cutout difference between Rev.A(bottom) and Rev.B(top).
Both are not big problem anyway. I started assembly process and will shipping them soon.
« Last Edit: Thu, 18 June 2015, 15:46:04 by hasu »
Offline badboybry9000
« Reply #308 on: Thu, 18 June 2015, 15:27:22 »
Great news! Thank you, hasu. I'm crossing my fingers for a round 2 of the plate group buy.
Offline cheddarbek
« Reply #309 on: Fri, 19 June 2015, 00:47:03 »
Me too, since you got Frostytoast's spot.  ;D
The Alps cover 65% of Switzerland's surface area (41,285 kmē), making it one of the most alpine countries. Despite the fact that Switzerland covers only 14% of the Alps total area (192,753 kmē),[2][3] many alpine four-thousanders (48 of 82) are located in the Swiss Alps and practically all of the remaining few are within 20 km of the country's border.
« Reply #310 on: Fri, 19 June 2015, 08:20:42 »
Hahaha. Sorry about that! I guess I'm not too worried about another plate buy now. I hope there are no hard feelings.
Offline cheddarbek
« Reply #311 on: Sat, 20 June 2015, 00:08:36 »
Nah, no worries. I figure there will be another buy, or I'll just harvest the plate from the board I got from the AEKII GB.
Offline Karura
  • SKidata life.
« Reply #312 on: Mon, 22 June 2015, 02:53:45 »
Hey guys, was just wondering if the SG keyboards would make for nice keycap donors?
Also, does it come with a plate and what is the material of the keycaps? Not sure if these are priced well, but they're new.
http://www.ebay.com/itm/NEW-Silicon-Graphics-RT6856T-062-0002-001-Grey-Keyboard-Granite-PS-2-SGI-/261912496815?pt=LH_DefaultDomain_0&hash=item3cfb338aaf
Offline hasu
  • @tmk
« Reply #313 on: Mon, 22 June 2015, 03:01:01 »
Today, some of the orders were shipped, some of you may receive an email with  tracking number from Japan Post.
Other orders will be posted in a week.
Offline Frizer
« Reply #314 on: Mon, 22 June 2015, 16:09:21 »
I think the SGI boards you want are the ones with the logo top left. The later ones are rubber dome.
Offline rsadek
  • raging keyboard monkey
« Reply #315 on: Mon, 22 June 2015, 21:59:48 »
I was very excited to get that email today! Thanks Hasu!! :)
❤️Keeboardz
Offline henz
  • What?
« Reply #316 on: Tue, 23 June 2015, 10:10:07 »
may i ask what switches ppl are going to use?
« Reply #317 on: Tue, 23 June 2015, 10:12:35 »
Discovered I've got 58 Brown Alps and nubbinator's plate takes 60 switches. Going to use 58 Brown Alps and two Matias Quiets unless I can find two extra Browns.
Offline henz
  • What?
« Reply #318 on: Tue, 23 June 2015, 10:18:46 »
I have some white alps clones. But im not sure i want something that clicky. Thinking of getting some matias switches or something else tactile.
Offline Hzza
« Reply #319 on: Tue, 23 June 2015, 10:19:06 »
It's still up in the air for me...I've got a M0116 with salmons which are awesome switches but I don't really want to kill the board for them so I think I'm either going black alps (maybe modded to linear, I'm not sure yet) or dampened creams (I haven't used them enough to decide if I like them yet :D).
Offline henz
  • What?
« Reply #320 on: Tue, 23 June 2015, 10:23:58 »
i have a m0116 too. which is handwired. Will not kill that :)
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #321 on: Tue, 23 June 2015, 10:38:17 »
I'll be using Orange ALPS.
WTB/WTS/WTT ---->
Offline cheddarbek
« Reply #322 on: Tue, 23 June 2015, 10:40:31 »
I'd like to get as close to the complicated whites in my AEKII at work as possible.
I really didn't care for the creams in the AEKII donor board I picked up(but the keycaps are in great condition). I'm planning on running Matias clicks for most of the keys. I am going to pull the lock switch from my AEKII donor for capslock, and I'm thinking I'll pick up another lock switch for fn - perhaps I'll find just the switch, or pick up a M0116 or another AEK donor to harvest from.
Offline Hzza
« Reply #323 on: Tue, 23 June 2015, 10:51:17 »
Nice, pics? I'm planning to do the same at some point, I've got a bit of time off at the end of the year so I'll probably crack it out then.
Offline henz
  • What?
« Reply #324 on: Tue, 23 June 2015, 10:53:40 »
the thread:
https://geekhack.org/index.php?topic=71890.0
Offline njbair
    • nickbair.net
« Reply #325 on: Tue, 23 June 2015, 18:29:28 »
Just finished gutting an old Apple IIGS with orange Alps. I'll be using those, as I prefer orange to the cream dampened Alps in my only other donor option right now (AEKII).
CPT, I don't suppose you have two more Matias Quiets you'd be willing to part with? I broke two while building my Infinity a few weeks ago and I've been using two oranges in their place.
My boards:
Offline cheddarbek
« Reply #326 on: Tue, 23 June 2015, 18:32:36 »
I have a bunch of matias clicks that'll be here tomorrow if you need.
Offline njbair
    • nickbair.net
« Reply #327 on: Tue, 23 June 2015, 18:37:49 »
Clicks or quiets? I'm looking for quiets.
My boards:
Offline cheddarbek
« Reply #328 on: Tue, 23 June 2015, 18:38:53 »
Clicks
Offline njbair
    • nickbair.net
« Reply #329 on: Tue, 23 June 2015, 18:46:48 »
Clicks
Thanks for the offer but I think I'm gonna hold out for some quiets.
My boards:
« Reply #330 on: Wed, 24 June 2015, 09:50:12 »
I currently don't have any Matias Quiets. I was going to order some.
Offline Pyrelink
« Reply #331 on: Wed, 24 June 2015, 14:50:53 »
I am going with Blue Alps for this board.
Offline hasu
  • @tmk
« Reply #332 on: Wed, 24 June 2015, 23:25:38 »
Confirmed bottom row and right shift part of Infinity layout.
Offline RickyJ
« Reply #333 on: Thu, 25 June 2015, 02:01:07 »
That model is rubber disappointment. :(
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline hasu
  • @tmk
« Reply #334 on: Thu, 25 June 2015, 03:58:52 »
All orders were shipped today!
Tracking number will be mailed to your PayPal email address in  several
hours or a day. PM me unless you don't receive it.
Offline ctm
  • Hello, world!
« Reply #335 on: Thu, 25 June 2015, 07:23:50 »
Thank you hasu! I am so excited and can't wait to see it in my mailbox!
Coming:
Ellipse Model F F62.
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #336 on: Thu, 25 June 2015, 07:37:41 »
Thanks hasu.
Now to figure out what I'm going to do about a plate.
WTB/WTS/WTT ---->
Offline Hzza
« Reply #337 on: Thu, 25 June 2015, 08:26:09 »
Thanks hasu.
Hack up an old AT101w? That's my plan :D.
https://geekhack.org/index.php?topic=73138.0
« Reply #338 on: Thu, 25 June 2015, 08:46:25 »
Thank you, hasu! You must have been working nonstop.
Offline limster
« Reply #339 on: Thu, 25 June 2015, 09:29:21 »
Thank you for your work and dedication, hasu! I received the tracking notice!
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #340 on: Thu, 25 June 2015, 15:53:57 »
Thanks hasu.
I don't have any of the tools to do anything like that  :(
Going to have to wait until a GB happens.
WTB/WTS/WTT ---->
« Reply #341 on: Thu, 25 June 2015, 17:11:02 »
Well, I'll be willing to do another plate buy next month for the AT101 layout since I think JD said he'd make the plate file.  I'll just have a GB MOQ of 25, the price will be a little higher than before, and all plates must be paid for before I order since the last set was out of pocket.
Offline hasu
  • @tmk
« Reply #342 on: Thu, 25 June 2015, 19:29:53 »
Thanks all for your support for this project!
Attached firmware binary file in the first post. It is same as a firmware uploaded to 'Assembled PCB' when shipped. Use this file if you have any trouble with compiling firmware yourself.
To define your keymap you have to edit and compile it from source code, anyway.
Enjoy!
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #343 on: Thu, 25 June 2015, 19:31:28 »
Okay, cool  :)
Will it be for the AT101, or AT101W? Would it be possible to make a plate that will work with both?
WTB/WTS/WTT ---->
Offline a-c
« Reply #344 on: Thu, 25 June 2015, 20:04:06 »
Received my two boards today!  ;D
Did a quick test and they show up fine as alps64 when plugged in.
Your toaster oven is awesome.
Thanks for the hard work!
Offline jevvix
« Reply #345 on: Thu, 25 June 2015, 20:36:23 »
Enjoy!
Thank you!
Offline Hzza
« Reply #346 on: Thu, 02 July 2015, 10:55:52 »
Lets try this again...
I got my PCBs a few days ago, thanks hasu :D.
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #347 on: Thu, 02 July 2015, 11:12:15 »
If anyone has an additional PCB I can buy I'm extremely interested.  Otherwise, if a round 3 might happen at some point count me in.
« Reply #348 on: Thu, 02 July 2015, 12:14:34 »
I received mine yesterday. Thank you, hasu!
Offline njbair
    • nickbair.net
« Reply #349 on: Thu, 02 July 2015, 12:45:56 »
I also received mine yesterday! I had all my orange alps switches harvested and ready to go, and having recently received my AEKII plate from Nubbinator, I jumped right in on the assembly.
Orange Alps Custom Keyboard
by Nick Bair, on Flickr
Everything's working fine so far as I've tested it. My keycaps have been cleaned and are drying. I'm still not sure on my plans for a case but I'll probably try something unique for this already very unique project.
My boards:
