Author Topic: Wow.. New tough decision UPDATED  (Read 2340 times)
« on: Thu, 19 March 2015, 13:23:24 »
OK..
New tough decision..
Do I need  Fujipoly... a $25 question..
OLD_____________________________
Ok.. shopping for 16gb sets of memory for my x220.. which I will be reliant on for 3 months.. (i only have 2x4gb right now)
1.35 volt   low voltage ram gives around 1-2% increased battery life..
1.50 volt   1866mhz ram gives around 2-5% boost in performance, up to 20-30% boost in igpu-performance..
So... do I want the performance, or the battery life.. Hrrrmmm...
Offline paicrai
  • mindblank
Re: Wow.. what a tough decision
« Reply #1 on: Thu, 19 March 2015, 13:24:25 »
THE FEMINIST ILLUMINATI
  • Live long and prosper
« Reply #2 on: Thu, 19 March 2015, 13:28:02 »
tp thread is tp thread
Offline JPG
  • Model F is my new passion!
« Reply #3 on: Thu, 19 March 2015, 13:29:57 »
Choose the one that has the best look/logo and most back lighting.
Offline vindaon
« Reply #4 on: Thu, 19 March 2015, 13:32:46 »
And make sure it's marketed for gamers.
« Reply #5 on: Thu, 19 March 2015, 13:39:55 »
You can always find a place to plug in. I doubt you can find somewhere to boost your CPU performance. :P
« Reply #6 on: Thu, 19 March 2015, 13:39:55 »
I say get one of each for the best of both worlds!
Offline user 18
« Reply #7 on: Thu, 19 March 2015, 13:41:19 »
How long is a 2% increase in battery life on that machine anyway? On something with 5hr battery life, it's 6 minutes.
My pick would be the performance in the majority of use cases.
Avatar by ashdenej
« Reply #8 on: Thu, 19 March 2015, 13:45:39 »
17 hours if I plug in both batteries simultaneously.. so +20 minutes..
sandy bridge uses a stupid amount of power compared to the new stuff..
But the New x250 doesn't have dual channel Ram,  LIKE WTF... WTFFFFFF
^^  I refuse to buy x250 for that reason
But.. alas.. thx 18-link,  you've reminded me how trivial the powersaving is..  the percentages looked much bigger than the 20 minutes..
I got the 1866
« Reply #9 on: Thu, 19 March 2015, 14:25:38 »
OK..
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
Re: Wow.. New tough decision UPDATED
« Reply #10 on: Thu, 19 March 2015, 16:24:51 »
Yes you do. Buy it now.
You need that jiggle for DOA 5
« Reply #11 on: Thu, 19 March 2015, 17:39:07 »
oh man.. I just realized.. My x220 won't run doa5 ... sigh............... it can't handle all that Bo-ing.
