Author Topic: How To Wire Up LEDs  (Read 1832 times)
Offline Davsmith4
How To Wire Up LEDs
« on: Mon, 23 March 2015, 23:47:33 »
So for my first custom made mechanical keyboard I would like to make it backlit. The only problem is I dont know the best way to wire them up. For context they keyboard Im making will be a hand wired matrix not a PCB with Cherry switches.
Thanks for the help,
           Davsmith4
Re: How To Wire Up LEDs
« Reply #1 on: Tue, 24 March 2015, 00:10:41 »
you need a driver circuit.. or a reliable dc source..
they usually have resistors to prevent overcurrent, but it's not absolutely necessary.
Offline Davsmith4
« Reply #2 on: Tue, 24 March 2015, 00:26:53 »
I would like to keep the wiring as simple as powerful so is there anyway I can wire it up so its powered by the same usb that connected to the teensy?
