Author Topic: Don't buy "Insert item here"  (Read 5012 times)
Offline Lain1911
  • God of the Wired
« on: Fri, 03 April 2015, 00:15:38 »
Thought I would share a bad experience with a product I just got. In the product description it didn't say "Ideal for low-drain devices". Needless to say two double A's took about 3-5 pictures with a camera before dying. I tried RMA but I would only get back about half what I paid for them.  :blank:
Anyone have any horror stories on bad products or pictures of things that aren't worth buying?
Re: Don't buy "Insert item here"
« Reply #1 on: Fri, 03 April 2015, 04:40:20 »
"Samsung 840 EVO" SSD. Google it!
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #2 on: Fri, 03 April 2015, 05:08:03 »
My EVO works great....
Offline baldgye
  • Will Smith Disciple
« Reply #3 on: Fri, 03 April 2015, 05:29:23 »
A games console
Ha
Offline paicrai
  • mindblank
« Reply #4 on: Fri, 03 April 2015, 16:09:13 »
dont buy destiny
dont buy drugs
dont buy nuclear warheads
dont buy slaves
THE FEMINIST ILLUMINATI
Offline ComradeSniper
  • HHKB Pro
« Reply #5 on: Fri, 03 April 2015, 16:37:51 »
Yup, same here. ¯\_(ツ)_/¯
Offline tigersharkdude
« Reply #6 on: Fri, 03 April 2015, 16:41:46 »
Offline trizkut
« Reply #7 on: Fri, 03 April 2015, 16:42:40 »
3 here ..
Here as well..  I've heard about slowdowns when reading older files, but I haven't experienced it.
« Reply #8 on: Fri, 03 April 2015, 16:51:55 »
3 here ..
I've got 3 and all of them work fine.
Offline Glissant
« Reply #9 on: Fri, 03 April 2015, 16:58:50 »
dont buy destiny
dont buy drugs
dont buy slaves
One of those are OK to me.
« Reply #10 on: Fri, 03 April 2015, 17:02:42 »
dont buy destiny
dont buy drugs
dont buy slaves
#LegalizeIt
Offline paicrai
  • mindblank
« Reply #11 on: Fri, 03 April 2015, 17:37:08 »
dont buy destiny
dont buy drugs
dont buy slaves
#LegalizeIt
#movetoadifferentstateufuqnstoner
Offline VinnyCordeiro
« Reply #12 on: Fri, 03 April 2015, 18:13:23 »
dont buy destiny
dont buy drugs
dont buy slaves
#LegalizeIt
1.21 gigawatts?!
Offline paicrai
  • mindblank
« Reply #13 on: Fri, 03 April 2015, 18:23:57 »
Offline mason
  • have fun with her, ryan
« Reply #14 on: Fri, 03 April 2015, 18:51:26 »
Kingston SSDNow V300
« Reply #15 on: Fri, 03 April 2015, 21:52:36 »
fleshlight
Offline jonathanyu
« Reply #16 on: Fri, 03 April 2015, 22:02:39 »
fleshlight
bought one last year, hated it.
Offline heedpantsnow
  • Old enough to know better
« Reply #17 on: Fri, 03 April 2015, 23:14:13 »
Nvm
« Last Edit: Fri, 03 April 2015, 23:33:34 by heedpantsnow »
I'm back.
« Reply #18 on: Sat, 04 April 2015, 00:32:37 »
fleshlight
You guys must be millionaire wankers, cuz that crap is expensive as hell.
« Reply #19 on: Sat, 04 April 2015, 00:34:40 »
The 840 EVO problem is very specific, only to OLD files..
So if you do a read test using hd Tune across the whole disk, You'll see areas with these dips
It should be almost a straight line across..
Offline GenKaan
  • Mer caps, mindre käbbel
« Reply #20 on: Sun, 05 April 2015, 06:20:21 »
dont buy destiny
dont buy drugs
dont buy slaves
Dont buy Func or Qpad mice, had a 3 of each break down for me
Dont buy cheap PSU's
Dont buy any of SteelSeries headsets that isnt the Siberia v2
Dont buy e-cig juice that has a "no name" brand, even mint can taste like burnt plastic
Dont buy into what politicians trying to sell, its on some lobby groups demand
Dont buy into what the papers write, they are corporations looking for profit and are selling you opinions
|| @Home:: Shine 3 TKL (Mx Red / Deep Space)  || @Work:: G2Pro (Mx Clear / Dye Sub PBT) ||
@Reserve:: HHKB (Topre 45g / Mixed PBT) // Das v3 (Mx Brown / Blank PBT)
Offline KatzenKinder
« Reply #21 on: Mon, 06 April 2015, 19:44:22 »
fleshlight
Millionaire Wankers has a nice ring to it.
« Reply #22 on: Mon, 06 April 2015, 20:38:30 »
fleshlight
brb starting a ska band called The Millionaire Wankers
