Author Topic: To Type S or not to Type S?  (Read 5877 times)
Offline chive_
« on: Wed, 06 May 2015, 13:14:02 »
I'm fortunate enough to have an internship this summer as a software engineer, and with a bit of cash coming my way I want to invest on a HHKB I can bring back and forth with me to work.
The question I have is concerning the noise of Topre switches. Is the sound of a Topre switch quiet enough for an office environment, or do I need to get a Type S?
Also, is the feeling of the two any different? I've never used a Topre switch before, so any opinions would be appreciated. Thanks! :thumb:
Offline lookitdisnub
Re: To Type S or not to Type S?
« Reply #1 on: Wed, 06 May 2015, 13:20:17 »
Non type-s is quiet enough for an office environment. Both are louder than a membrane board but aren't obnoxious.
Offline Lurch
« Reply #2 on: Wed, 06 May 2015, 13:23:23 »
YMMV. I've seen a few posts around saying that standard HHKB's are too loud for an office environment. Depends on where you work, and how sensitive your co-workers are. :rolleyes:
Quote from: Flyersfan1
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #3 on: Wed, 06 May 2015, 13:24:11 »
I never had a single bit of desire for a type s. Regular hhkb is so damn quiet as it is.
Offline rsadek
  • raging keyboard monkey
« Reply #4 on: Wed, 06 May 2015, 13:37:16 »
    I just faced the same choice; I chose not to Type-S for the following reasons:
    • the Type-S I played with was very quiet but somewhat squeaky
    • the sound of the standard HHKB is somewhat louder but more pleasing
    • standard HHKB is not that loud, esp if you don't pound...(which you shouldn't for your wrist health)
    • standard HHKB can be dampened or silenced later w/ various mods you can find on geek hack. Like placing the HHKB on a rubber mat or a bit of dish shelf-liner, etc. These mods are often reversible as well.
    Given all that it just didn't seem worth an extra $100 for the type-S; at least not for a first HHKB.
    -R
❤️Keeboardz
Offline Khers
  • Schrödinger's box
« Reply #5 on: Wed, 06 May 2015, 13:54:34 »
« Last Edit: Tue, 03 July 2018, 08:18:18 by Khers »
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #6 on: Wed, 06 May 2015, 13:58:13 »
There are TONS of office people with long fingernails, weird crappy keyboards, rough touch, etc that make WAY more noise than even mx blues. Even on a quality rubber dome they can be much louder. The solid, deeper "thock" of the HHKB is not noticeable. Just take your thumb and tap your desk with a tiny bit of force then take your fingernail and do the same... stock HHKB is more like the former than the latter.
« Reply #7 on: Wed, 06 May 2015, 14:00:29 »
I first got the standard HHKB, which I think is the sensible option given the extra investment required for a Type-S (unless you get it from Japan where the price difference is not quite as large). Although you can probably sell it off with minimal losses if you are not pleased...
Quite soon after receiving it though, I felt that it was perhaps a tad too loud to use in the office and tried my hand at dental banding it. While this silenced it somewhat, it's not as quiet as a Type-S is, moreover it changed the feel of the board for the worse. There are other methods out there though, such as ironed soft landing pads that might be better than dental bands.
Anyhow, I recently got myself a Type-S and I could not be happier. I've read a few people claiming that the Type-S whistles and whatnot, but I've not experienced anything like that - maybe there are different batches or something.
They might've solved the whistling recently but as far as I know it wasn't considered a problem worth fixing. My first Type-S had a lot of whistling and the one I exchanged it for had very little and it went away over time anyway.
Offline Wonko73
« Reply #8 on: Wed, 06 May 2015, 14:14:22 »
Hi,
I'm very pleased with my HHKB 2 Type S. I have an additional Realforce Topre TenKeyPad ... well - the sound should be similar to an usual HHKB 2.
In my opinion the Type S is great (altough I prefer klicky blue switches on my other keyboards).
Filco TKL MX Blue | Filco TKP brown | HHKB2 Type S | Realforce 23U
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #10 on: Wed, 06 May 2015, 14:57:06 »
I was a bit disappointed by the type-s, cause mine makes strange noises... wasn't really worth the additional money in my opinion.
Offline Sygaldry
  • Edema Ruh
« Reply #11 on: Wed, 06 May 2015, 15:02:16 »
Stock Topre is too load if you share an office with others.
null
« Reply #12 on: Wed, 06 May 2015, 15:02:16 »
I was disappointed in my 87u..
It's not really a bad keyboard or anything..
But the Geekhack hype was in extreme-excess to the natural merits of the device.
The biggest downer was how people would say, This is not Rubber Dome..
Then you go and type on it..  Feels exactly like rubber dome..
I'm not against rubber dome,  but hey,  why you gotta lie to me..
There are worse ways to burn $200...
I guess it's not too much to pay for "the experience"..
In my case it was the the experience of disappointment,  but I think if I didn't buy it because of the HYPE,     I would've been less disappointed..
But as it stands..  I'm still angry...
Offline sorijealut
    • steam
« Reply #13 on: Wed, 06 May 2015, 15:42:35 »
I recommend the Type S, but I do agree, my board is probably on the "stranger" side of normality scale, as there's more spring noise on some keys than others.
I did take out the spring under the space bar to make it quieter. Difference was pretty big ^-^
Of course, I recommend the now-popular way of ordering from Tenso, something I learned from my friend Syg.
« Last Edit: Wed, 06 May 2015, 15:44:44 by sorijealut »
Offline exitfire401
  • The Force is Re/\l
« Reply #14 on: Wed, 06 May 2015, 15:44:57 »
Original +O2dazone mod> Type-S any day of the week. (typed on my type-s)
Offline steve.v
« Reply #15 on: Wed, 06 May 2015, 21:33:45 »
Annoy others and sound like you're working hard; reg.
Slam away with quietness and sound like you're doing nothing; type-S.
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #16 on: Wed, 06 May 2015, 21:40:06 »
If people get annoyed by an HHKB, start typing on clicky switches, they'll be begging for the topre...
« Last Edit: Wed, 06 May 2015, 21:42:19 by Air tree »
Offline exitfire401
« Reply #17 on: Wed, 06 May 2015, 22:04:21 »
That's how I remedied the complaints I was getting at work...Had people *****ing about my Type-S. I brought in my Kingsaver for a day, and they made me swap back to the HHKB after 45 minutes. That'll show them.
Offline clacktalk
  • circa 2015
« Reply #18 on: Wed, 06 May 2015, 22:06:09 »
type s is definitely the way to go between the two. topre is surprisingly loud
diary of a clacktalk
radio_killah: too much frank
Offline gravenshard
  • vagabondage
« Reply #19 on: Wed, 06 May 2015, 22:20:05 »
Type-S.
Offline KeypressGraphics
  • Dare to Dream
    • Keypress Graphics
« Reply #20 on: Wed, 06 May 2015, 23:12:49 »
I say go the Type-S, I regret not saving up the extra for one. Not because the HHKB is particularly loud but because buying the Type-S means you own the holy grail of Topre boards and upgratitis can be put to rest. Buying one direct from Japan via a proxy seems to be the way to do it.
May all your key presses strike true.
  Choc Mini         HHKB
Offline appleonama
  • Trollo en USA
« Reply #21 on: Wed, 06 May 2015, 23:21:54 »
type-s
non s is too loud I had to dental band my regular black hhkb
Offline rsadek
« Reply #22 on: Thu, 07 May 2015, 01:09:13 »
So I just got my standard opened just now. It is a delight and I love it.
Verdict: it really isn't that loud. Louder than the S, yes. But no louder than my officemate's Microsoft Natural 4000. The  sound has two parts : a very nice "thock" on the way down. On the way up (sometimes, but not all) there's a bit of a "clack" as the key reaches the end of the stroke. It's not loud at all, but might be more intrusive than the thock.
Here's my reasoning: First, you'll want Hasu's mod; save the money for that. Then if you love HHKB (like me) you'll probably end up with both eventually. If it's not for you, GH is an easy place to sell it.
Second, the dark grey/black keys are gorgeous. Esp w/ the red/blue Ctrl/Esc color pack. It just makes it for me. See pix:
99724-0
99725-1
Finally, most offices I've worked in are loud: people talk, type, phone calls, etc. My gentle typing on this thing is within the thresholds of office politesse I've experienced; doubtless others have experienced officepsaces with lower noise thresholds, which seems like a good problem to have. YMMV.
I'm going to try my luck with the standard first; yet look forward to the inevitable day when I also buy the Type-S...just for the joy of it. Let us know what you decide and how it works out :)
-R
❤️Keeboardz
