Author Topic: How did this happen...  (Read 1777 times)
« on: Tue, 19 May 2015, 14:20:33 »
My 6570 htpc graphics card    degraded.
Used to hold 835mhz OC
Now it only holds 780..  that's 55mhz difference, HUGE... only 3 Years
It's never ran any 3D games,  only Madvr, ~60% load tops..
And it's not even overvolted...
Offline Oobly
Re: How did this happen...
« Reply #1 on: Tue, 19 May 2015, 15:25:21 »
Dust clogging the cooling fins perhaps? Or maybe the thermal paste has degraded. May be worth dismantling and repasting. Or it could just be fading with old age and long term heating...
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #2 on: Tue, 19 May 2015, 16:04:27 »
definitely not dust or paste,
It won't hold the clock "at all".
I wouldn't have thought degradation would be this bad in such a short amount of time.
Offline Oobly
« Reply #3 on: Thu, 21 May 2015, 02:54:55 »
:( Sorry, buddy. I don't like to hear sad OC stories..
Offline Jokrik
« Reply #4 on: Thu, 21 May 2015, 03:53:39 »
how about temp?
« Reply #5 on: Thu, 02 July 2015, 23:56:17 »
Finally fixed the problem..
It seems to be VRM-  wear
It began crashing even at 780mhz.
I put on some old Mosfet heasinks I had left over on the open air Vrms,  now it holds 790 without any issue..   still, no more 835..
