Author Topic: [Computex 2015] Zeal's picture dump thread  (Read 26531 times)
Offline Zeal
    • Zeal Generation Inc.
« on: Tue, 02 June 2015, 17:42:40 »
A few keyboard related pictures I took while at Computex! Got to chat with some keyboard booth reps. :)
Bloody
Infrared MX Compatible switch.
Glossy white plastic case.
The switch travel felt shorter for some reason. It also felt really plasticky while typing. The IR switches felt a bit scratchy, like semi-worn in MX Reds. I didn't like the feeling of the switch, but according to their live demo, it actuated around 10-40ms faster than "standard" mechanical switches.
Cherry
Cherry thought they could keep me away from taking proper pictures of their MX 6.0...
So I whipped out my polarized filter!
...and after all that effort, I realized they had an engineering model on display
MX 6.0 came with a magnetic, silky matte and soft rubberized wrist rest with "MX" engraved diagonally along the rest.
A Cherry logo hologram sticker to prove its authenticity?
Who wouldn't take a picture of a Cherry box? :P
Ducky
Ducky Year of the Sheep
Ducky Shine 5 - Cherry RGB
Dual mounted PCB. Secondary "SMD LED" PCB is thin, probably less than 1mm. Ducky used a larger SMD LED to light the Cherry housing as opposed to fitting the SMD LED into the switch bottom housing. They're still deciding about TKL, price not set yet.
The other guy's flash went off at a bad time. :(
Doubleshot ABS on new Shine 5s
Ducky One
Ducky Secret
Ducky Flipper
iOne
1800 Layout + trackball
The clickiest keyboard I've ever touched. Actuation was literally at the very top with no pre-travel (as far as I could feel) before the tactile point. Seemed like some form of ALPS switch (couldn't pull a keycap off as it was at the display side window.
KB Paradise
Prototype 100% board featuring medium thick doubleshot ABS keycaps
V60 Engineer samples featuring three different ALPS type switches: From top to bottom - Datacomp, Fukka, Matias. Datacomp switches had the highest tactile/actuation point of all 3, whereas Fukka had a nice mechanical clickity-clack sound to them. It was nice to be able to type on all 3 and feel the differences!
A few upcoming V60 keyboards that come with aftermarket keycaps will be released in the near future. Prototype white case is also being designed.
V60 with Matias quiet linears (red stem)
I've read about the smoothness on these switches, and can attest that they are indeed very smooth linears. As others have reported, these linear switches have a small "tactile bump" towards the end of the keystroke. Would work out nicely if you prefer a linear feel, but don't want the harsh feeling of "bottoming" out. Nice quiet & compact keyboard.
The rep at KBParadise was also handing out some new Gateron RGB switches!
You can see the top housing cover opened up for 4pin RGB LEDs.
Got to chat and interview Daniel at KB Paradise -- It went something along the lines of this (in Chinese):
Q: What led you to jump right into the 60% market straight away as a new keyboard company?
A: I've been in the keyboard market for over 10 years, selling membranes to scissor to mechanical keyboards. When I entered the mechanical keyboard market, my friend in Japan told me that Filcos were a hot seller, and that they love compact keyboards. That's when I found Vortex, and tested the market by selling their products to Japan. I've sold every edition of the Poker and Race, and found that the 60% market was quite large.
Q: Ah, that's quite an interesting background story. So what made you decide that you wanted to start your own brand?
A: We wanted to expand into other Asian markets, but Vortex already had distributors in those areas. As we sold many Pokers, we knew there was a market for compact keyboards. We always welcome customer feedback, and the biggest complaint was the non-remappable PN button/layer. That's when we decided to test the waters and see if we could improve the 60% layout -- and that's how it all started.
Q: I noticed that your company opted for a more angled case design instead of the generic rectangular block (rear looks like Lamborghini's exhaust). What was the reasoning for that?
A: The indentation from underneath helps with supporting the PCB and reduce flex when typing. It also happened to look unique. Tex Keyboard was one of the main contributors in the design of the keyboard case as we're good friends.
Q: Any particular reason why KB Paradise went for a less standard 5-mount screw mount design? (4 screws from underneath the rubber feet, one in the middle)
A: Our engineers concluded that it would be easier to assemble PCB to the case with our design, and the structural support would be better. Our goal was to reduce flex in the PCB by distributing the screw mount holes evenly.
Q: So technically, there is no "warranty void if punctured/removed" sticker placed anywhere on your case as the 4 screw mounts are hidden under the rubber feet, and one in the middle of the keyboard. Not many companies do that! Was this on purpose?
A: (Laughs) We understand that enthusiasts like to swap keyboard cases/trays, and didn't see a point in making it difficult to do so. Not much harm can be done with swapping aftermarket 60% cases.
Q: Yes, however most aftermarket 60% cases are designed with POKER mounts. I understand that only 3 or 4 screws holes can be mounted to aftermarket cases with your design.
A: That is something we look forward to improve on, perhaps add more screw hole mounts in the future. However even with 3 or 4 screws mounted in aftermarket cases, it still feels pretty sturdy.
Q: Do you have any plans on making bluetooth enabled 60%s? There isn't many on the market with standard layouts
A: That is something we've been thinking about. It's a possibility, however there are also many different BT certificates required around the world.
Q: Any plans on RGB switches? Now that Cherry RGB's exclusive rights is over, lots of keyboard makers are using them. Any plans on using Gateron RGB? How about Matias?
A: RGB lighting is something we'll think about for future editions. We'll have to design the PCB first and do some prototyping!
Solidyear
I found the OEM for MSI's laptop that has a built in mechanical keyboard. Didn't get a chance to take a pic of the actual laptop on display as it was quite crowded.
Tai-Hao
Tai-Hao was demoing a few of their new ALPS clone switches & keyboards.
Red TH Alps - Tactile point at the bottom, noticed at halfpoint of keytravel. (roughly 2mm left of red stem showing above black housing)
Black TH Alps - Tactile & click on the bottom half of the keytravel
Brown TH Alps - Slightly heavier Tactile & click on the bottom half of the keytravel
Transparent TH Alps switch? Tactile as well, felt similar to Matias quiet click. Blue SMD LED lighting up the prototype (felt like 3D printed) keycaps.
An almost 65% layout keyboard. Top half was either plastic that looked like anodized aluminum with chrome sides, or was a thin layer of aluminum.
Topre
Topre Type Heaven RGB - Cherry MX Keycap compatible, Adjustable software based actuation point (1mm, 1.5mm, 2mm, 3mm). Price a bit higher than current Type Heavens, expected release around next year. Clear Topre housing + white plunger + SMD LED. As per Topre's request, no pictures of the MX plunger for now, sorry. Possible that these could end up in Novatouch, still in the talks.
Adjustable actuation is done by calculating the change in electrical capacitance of the switch/spring.
Realforce JP Layout with adjustable actuation point. Can switch between keyboard, Xbox controller, PS3 controller, mouse cursor movement (with adjustable speed based off of pressure/position of key). Expected release before Computex 2016.
Stormtrooper (Black on White & White on Black) Realforces will be distributed by Ducky in the future. They will be 30g uniform.
A few new case colours that will be available with the Type Heaven
And for those wondering about Topre Keycaps, the rep said the production is on hold, as there isn't much demand for them. MOQ is around 1k sets per colour, doesn't matter if blank or dyesub.
Thanks for reading!
« Last Edit: Sat, 06 June 2015, 07:50:20 by Zeal »
Offline Zeal
Re: [Computex 2015] Zeal's picture dump thread
« Reply #1 on: Tue, 02 June 2015, 17:43:16 »
Reserved for "Show Girls"
ADATA
Asus ROG
Avexir
Ducky
FSP
Game Demon
G.Skill
Intel invited "DJ Cookie" to stage
MSI
Newland
Sound Blaster
Team Group
V-Color
This is all you see whenever an event starts at a booth
« Last Edit: Thu, 04 June 2015, 19:41:41 by Zeal »
Offline Zeal
« Reply #2 on: Tue, 02 June 2015, 17:44:04 »
Thanks nvidia for making me walk to the opposite side of the exhibition to collect 3 stamps for this. :rollseyes:
Some cool magnetic spinning bluetooth speaker that won D&I awards
Realforce monitor & keyboard brush, Topre Keychain
« Last Edit: Wed, 03 June 2015, 19:03:33 by Zeal »
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #3 on: Tue, 02 June 2015, 17:44:57 »
Show me da bootay
Offline byker
  • Literally Canada
« Reply #4 on: Tue, 02 June 2015, 17:45:02 »
booth babe hype!  ;D
Offline ghostjuggernaut
« Reply #5 on: Tue, 02 June 2015, 17:46:24 »
Offline Jokrik
« Reply #6 on: Tue, 02 June 2015, 17:53:57 »
Hypeeee
So jelly that you can be there, really wish I can go
Offline Danboard
« Reply #7 on: Tue, 02 June 2015, 18:09:16 »
So this was the business trip you mentioned. Can't wait!
Offline alienman82
« Reply #8 on: Tue, 02 June 2015, 18:49:56 »
removed.
« Last Edit: Thu, 01 March 2018, 17:27:32 by alienman82 »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #9 on: Wed, 03 June 2015, 00:53:59 »
bring me ducky goodies
this thread is already awesome
ok your avi is sic
Offline Zeal
« Reply #10 on: Wed, 03 June 2015, 02:39:11 »
#hype
Details / better photos later, net here is super slow and hard to connect.
Offline Zeal
« Reply #11 on: Wed, 03 June 2015, 02:52:22 »
Mandatory keychain shot too! :D
Offline calvinhousecat
« Reply #12 on: Wed, 03 June 2015, 03:05:07 »
Hype!
Offline alienman82
« Reply #13 on: Wed, 03 June 2015, 07:50:12 »
removed.
« Last Edit: Thu, 01 March 2018, 17:27:29 by alienman82 »
Offline Zeal
« Reply #14 on: Wed, 03 June 2015, 11:57:12 »
Hey guys, sorry about the wait. Had dinner and rested a bit before uploading the pics. Currently uploading ducky/topre. Will post in OP in a few minutes.
Booth babes currently being selected...
Offline luckynet
« Reply #15 on: Wed, 03 June 2015, 12:28:29 »
Thanks zeal for the update! :) +1 Moar topre More!!!
Realforce 104U - HHKB Pro 2 dental band - HHKB Pro 2 Hasu's bluetooth controller - CM novatouch silent mod - Royal Kludge Topre clones
Filco Magestouch 2 Brown - Duckyshine 9008s Brown - QFR white - Plum MX 96 Blue - KBT Race Red - SS 7G Black - Poker blue - ducky shine 69
IBM Model M SSK
Matias quiet pro - V60 matias clicky
Offline Zeal
« Reply #16 on: Wed, 03 June 2015, 13:45:19 »
Ducky & Topre updated with some descriptions, etc.
Offline wlhlm
« Reply #17 on: Wed, 03 June 2015, 13:55:24 »
:eek:
Have they said anything about the software in terms of multi-platform compatibility?
EDIT:
I have a feeling that they will switch to MX sliders across the board (hehe) eventually.
« Last Edit: Wed, 03 June 2015, 13:57:13 by wlhlm »
« Reply #18 on: Wed, 03 June 2015, 13:58:09 »
Really wish the Year of the Sheep followed the Year of the Horse and gone smaller. 60% or TKL please :(
« Reply #19 on: Wed, 03 June 2015, 14:03:35 »
Swag! Grab some for us plebes :p
Offline cheebs
« Reply #20 on: Wed, 03 June 2015, 14:12:49 »
Finally, a Type Heaven people will buy!  Now if they could only understand how terribly cheesy gold text on plastic looks.
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #21 on: Wed, 03 June 2015, 14:49:43 »
I'm pretty excited for the Ducky secret... Although, sizes make me wonder if I'd like it.
Offline Zeal
« Reply #22 on: Wed, 03 June 2015, 14:53:53 »
It's almost 4am... :eek: night!
Tell me if there's any other booth you guys are interested in, I'll try to grab some pics tomorrow ...er in the morning!
« Reply #23 on: Wed, 03 June 2015, 14:54:27 »
I want to see Zeal's booth  :cool:
Offline heedpantsnow
  • Old enough to know better
« Reply #24 on: Wed, 03 June 2015, 14:55:40 »
Wow this thread crashed my phone lol
I'm back.
Offline Johan
« Reply #25 on: Wed, 03 June 2015, 15:42:04 »
Did you play around with the ducky mouse? If so did the shell feel solid and the clicks super crisp?
Uh, stuff.
« Reply #26 on: Wed, 03 June 2015, 15:46:59 »
Blecch.. these girls are ugly..   Disappoint..
Thanks for the coverage Pics Zeal..
Offline cheebs
« Reply #27 on: Wed, 03 June 2015, 15:51:03 »
Love the super-thin, translucent case on the Ducky One!
Offline exitfire401
  • The Force is Re/\l
« Reply #28 on: Wed, 03 June 2015, 15:55:56 »
They have my interest in the type heaven. I'd pick one of those up without hesitation. Kind of a shame that ducky went with the same **** case design for the yots as they have on the shines. That just ruled that board out for me =(
Offline C5Allroad
« Reply #29 on: Wed, 03 June 2015, 16:24:20 »
I'm not fond of the case design either.... Wonder if it would be possible to swap the guts of it into my shine 3... XD
Offline exitfire401
« Reply #30 on: Wed, 03 June 2015, 16:28:30 »
As long as the 2nd pcb doesn't add much thickness, I wouldn't think it would be an issue.
Offline C5Allroad
« Reply #31 on: Wed, 03 June 2015, 16:30:16 »
It's supposed to be very thin, or did I read wrong? Oh well. My concern would be the dip switches.
« Reply #32 on: Wed, 03 June 2015, 16:30:28 »
Confirmed. Exitfire401 doesn't like the thickness.
Offline Zeal
« Reply #33 on: Wed, 03 June 2015, 18:54:49 »
The 2nd pcb is quite thin, so I think there shouldn't be any clearance issues, unless the mounting points are a bit diff.
Offline C5Allroad
« Reply #34 on: Wed, 03 June 2015, 18:59:07 »
I think I might be the first on the forum to try... I'll need a donor shine 2. I'd need some practice opening it...
« Reply #35 on: Thu, 04 June 2015, 00:33:07 »
Rgb. LEDs
Death of topre.
« Reply #36 on: Thu, 04 June 2015, 00:34:38 »
Anyone else dig these translucent cases on the Ducky Ones?
Thanks for the pics btw Zeal!
« Reply #37 on: Thu, 04 June 2015, 00:36:56 »
Also your gold dude has pipes in his pant legs that lock so he can hold that position.
« Reply #38 on: Thu, 04 June 2015, 06:24:38 »
This thread is crashing the version of Chromium that I am using, because the images are too large.
I don't get this problem with the "What you got in the mail" thread.
Offline Karura
  • SKidata life.
« Reply #39 on: Thu, 04 June 2015, 07:07:03 »
After extensive observation and scrutinizing, I've arrived at a conclusion.
This is the one!!! The one on the very right side. Please bring 1x back for me Zeal, ty  ;)
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #40 on: Thu, 04 June 2015, 08:45:33 »
Damn it i want one lol
GON NerD TKL DTA Edition
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #41 on: Thu, 04 June 2015, 08:47:59 »
Offline Zeal
« Reply #42 on: Thu, 04 June 2015, 21:01:29 »
It had a solid click, but not the loudest (to be expected, as it's made of PBT). The mouse buttons weren't too heavy like some other mice I've tried.
Updated OP with some more pictures & an interview with Daniel at KB Paradise.
« Reply #43 on: Thu, 04 June 2015, 21:05:21 »
Yeeeee nice interview! And it's cool to know that Tex and KBParadise worked together.
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #44 on: Thu, 04 June 2015, 21:14:41 »
I love all the pictures. I am sitting here in my dark office saying "whoa" at all the pretty keyboards out loud like some kind of lunatic.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #45 on: Thu, 04 June 2015, 21:16:31 »
Really?
I'm gonna have to go with the 2nd from the left here.
Offline telnet
« Reply #46 on: Fri, 05 June 2015, 00:35:43 »
Really?
One of these things is not like the other.
Sure you want the second one from the left?
QFR Frosty Flake | 7bit Phantom
« Reply #47 on: Fri, 05 June 2015, 00:37:19 »
Really?
ROFLMAO
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #48 on: Fri, 05 June 2015, 00:42:44 »
Really?
Offline azhdar
  • Praise the AZERTY god
  • 65% Enlightened
« Reply #49 on: Fri, 05 June 2015, 01:33:17 »
Really?
And if we're talking about the 2nd girl from the left, be careful, this oesn't look legit yet.
Azerty Propagandiste
