Author Topic: Tested Ergodox Assembly  (Read 1725 times)
Offline exitfire401
  • The Force is Re/\l
« on: Tue, 09 June 2015, 02:03:04 »
Decided to catch up with the Tested channel since I'm about 3 months behind and ended my night on this video. I was cracking up quite a bit.
Offline henz
  • What?
Re: Tested Ergodox Assembly
« Reply #1 on: Tue, 09 June 2015, 02:35:19 »
you should just link your video instead. cant click it, it seems this site has some embedding issues.
« Reply #2 on: Tue, 09 June 2015, 02:42:35 »
Deez guys have no soldering efficiency.. it might be the studio setting ofcourse..
But you're suppose to put solder on the left side of all diode solder points..  then put diodes on ,  THEN solder the other side.
That way you don't have to hold anything.
Offline Data
« Reply #3 on: Wed, 10 June 2015, 13:11:21 »
Damn, even I know that.
