Author Topic: Ugly keyboards  (Read 34289 times)
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Ugly keyboards
« Reply #50 on: Thu, 18 February 2016, 17:28:19 »
For real? You're messing with me right? G80-3500
Re: Ugly keyboards
« Reply #51 on: Thu, 18 February 2016, 17:30:19 »
That arrow pad is horrible.
But the rest is classy. But all cherry boards are ugly by default. #srynotsry
Re: Ugly keyboards
« Reply #52 on: Sat, 05 October 2019, 18:17:00 »
Only because I couldn't find a fresher thread...
This had found its way into my Youtube feed:
Barbie - branded. Official.
Chiclet
Shift keys on both sides of .. the space bar
No Return key, or lever
Pink
Bulbous case.
The manufacturer produced four designs of the typewriter with similar innards and keyboard module, but this one is the worst IMHO.
It also has a substitution cipher function for coding and decoding secret messages which you could enable with a key combination of Shift + Lock + number key. While all models included the cipher, apparently only the user manual for the first iteration mentions the function: That would be just awesome if you had one of the latter models and happened to press Shift+Lock+Number key by mistake...
« Last Edit: Sat, 05 October 2019, 18:38:02 by Findecanor »
Re: Ugly keyboards
« Reply #53 on: Sat, 05 October 2019, 19:46:41 »
anything Maltron makes
Offline appaboy
Re: Ugly keyboards
« Reply #54 on: Sat, 05 October 2019, 19:47:58 »
all of china now knows your location
edit: wow this was an old post, didnt mean to necro  :p
« Last Edit: Sat, 05 October 2019, 19:50:04 by appaboy »
PC Singa, MIR80, TX84se, g80-3314, g80-0427, g80-5000 + 5700, G80-3700, g81-3000 HBU (og wob)
HASRO keycaps
OG POM keycaps
SAI OG Italian dyesubs
Scarface Fn blank
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Ugly keyboards
« Reply #55 on: Sat, 05 October 2019, 20:44:07 »
*waves at China nonchalantly*
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Re: Ugly keyboards
« Reply #56 on: Sun, 06 October 2019, 08:06:18 »
I've found some hideous ones while searching before. I just found this thing.
Type on me Jon... there is no escape - even at work
Just my thoughts
Offline superbia
Re: Ugly keyboards
« Reply #57 on: Sun, 06 October 2019, 09:44:54 »
Not as ugly as an HHKB, but at least something I'd like to try  :)
https://github.com/pseudoku/ErgoWarp
Keebio Iris 2.8 (Alps) X Colemak Mod-DH
Offline mizzoperator
  • "This can't be good for me, but I feel great!"
    • Milk Time: The Mizz Domain
Re: Ugly keyboards
« Reply #58 on: Mon, 07 October 2019, 08:22:56 »
Finally, we have discovered the ultimate ergo keyboard.
Linears are for linear people. No offense if you use linears.
I prefer tactile switches, I'm reluctantly using the AULA SI-859 and my pronouns are she/her.
Offline gingerjack
Re: Ugly keyboards
« Reply #59 on: Thu, 10 October 2019, 22:59:35 »
What about this one?
Re: Ugly keyboards
« Reply #60 on: Thu, 10 October 2019, 23:03:18 »
Not digging the centered font,  but other than that it's alrite..  If the case was a little darker  or a little lighter  that would be better than the middle ground, as is, there's not enough contrast, rendering it stylistically muddy.
ALSO, the artist has a very crude sense of sakura geometry, it's much too uniform, and all units have 5/ 6 petals, complete amateur.
Re: Ugly keyboards
« Reply #61 on: Fri, 11 October 2019, 04:56:17 »
The combination of colours does not work. White keycaps with pastel modifiers need a white case. Dark wood case works best with black keycaps.
Offline Sintpinty
    • My Roblox Profile
Re: Ugly keyboards
« Reply #62 on: Fri, 11 October 2019, 11:21:21 »
The keycaps combination does work though..
have you seen davinci/premiere pro editing keyboards?
Just my thoughts
