Author Topic: Wisdom teeth removal..  (Read 14476 times)
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: Wisdom teeth removal..
« Reply #50 on: Sat, 18 July 2015, 04:46:39 »
I need mine out... But I can't really afford £500 right now. It will probably be worth it, but **** :(
« Reply #51 on: Sat, 18 July 2015, 06:10:53 »
One thing I noticed.. that if I increased my calcium intake for a duration,  it inevitably accelerated impaction..
So if ya'll got an impacted tooth coming.. slow down on the milk.. / calcium supplements..
« Reply #52 on: Sat, 18 July 2015, 10:35:56 »
What if.... what iff....  Wolverine has an impacted wisdom tooth..  He would be completely crippled.. because they'd have to pull it out every 10 seconds..
« Reply #53 on: Sat, 18 July 2015, 11:40:29 »
Tp how high are you bro
« Reply #54 on: Sat, 18 July 2015, 13:25:29 »
Tp4 no do drugs.. y everyone think I do drugs..  I no do drugs.
« Reply #55 on: Sat, 18 July 2015, 19:40:24 »
You know what's really good and easy to eat after removal?
Silken tofu + sesame oil + light soy-sauce dip.
« Reply #56 on: Sat, 18 July 2015, 22:08:03 »
Guys.. my back hurts..   Why does my back hurt..  Is this normal ?
« Reply #57 on: Sat, 18 July 2015, 22:09:51 »
Your kidneys must be shutting down.
« Reply #58 on: Sat, 18 July 2015, 22:10:24 »
is there such a thing as kidney pain?
I've kept my diet pretty simple so far.
Potato bisque, (pureed)
Banana
and Silk Tofu..
« Reply #59 on: Sun, 19 July 2015, 11:53:48 »
I screwed up my calories calculation..  Apparently 5-lbs of potatoes is only ~1550 calories..  Which is what I made my main Soup-of-Wellness out of..
So I've been eating only ~900 calories per day for the past 2 days..    No wonder I'm so tired and dying..
You'd think 5-lbs of potato would be more than 1550...
I was guessing 5000..
Pain_Update:
Still fairly swollen .. left side more so than right .. but both are puffy..
Pain lvl 2 ..
Mild accompanying headache .. Pain lvl, + 0.5
Current Pain-lvl_ 2.5
I tried some other foods today, but I noticed that most foods with oil are quite sticky, and does not dissolve in regular water.. So rinsing is not effective without a "full brushing w/ tooth paste"
« Reply #60 on: Sun, 19 July 2015, 14:11:51 »
God I'd really like some fried chicken now..
All this depression,  and hungri-ness
« Reply #61 on: Sun, 09 May 2021, 10:41:35 »
For what it's worth, I had mine out in 1972.
Abscessed teeth and root canals are far worse.
I don’t give a damn. We’re making a freaking fortune, our country is getting stronger and stronger all the time.
- D Trump 2026-10-24
Offline Marsha11
« Reply #62 on: Mon, 10 May 2021, 04:30:33 »
How are you doing, man? Had implants recently and remembered a time when I was just starting out in dentistry. A few years ago I decided to get my teeth aligned. But their condition was critical. At first, they tried to fix them. But then they decided to just pull them out. All right, I thought. But the pain...it was the worst pain of my life. I didn't want to go back to that clinic again. Found jeffreygrossdds.com online. Went to see them. After the consultation, I continued my treatment. It was painless, and I recently got implants from them. My teeth are fine now.
« Last Edit: Tue, 11 May 2021, 04:48:16 by Marsha11 »
« Reply #63 on: Mon, 10 May 2021, 07:44:07 »
I'm fine, been through it 3 times in about 20 years. Only 1 has required an implant and I waited nearly 3 years before getting a tooth to fill the gap (long story). But it went in fine and I am happy with the result.
Back story - that chain of events started when I cracked a tooth on a piece of bone in a hamburger at Fuddruckers in 1995.
