Author Topic: Wisdom teeth removal..  (Read 9992 times)
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: Wisdom teeth removal..
« Reply #50 on: Sat, 18 July 2015, 04:46:39 »
I need mine out... But I can't really afford £500 right now. It will probably be worth it, but **** :(
Online tp4tissue
« Reply #51 on: Sat, 18 July 2015, 06:10:53 »
One thing I noticed.. that if I increased my calcium intake for a duration,  it inevitably accelerated impaction..
So if ya'll got an impacted tooth coming.. slow down on the milk.. / calcium supplements..
Online tp4tissue
« Reply #52 on: Sat, 18 July 2015, 10:35:56 »
What if.... what iff....  Wolverine has an impacted wisdom tooth..  He would be completely crippled.. because they'd have to pull it out every 10 seconds..
« Reply #53 on: Sat, 18 July 2015, 11:40:29 »
Tp how high are you bro
Online tp4tissue
« Reply #54 on: Sat, 18 July 2015, 13:25:29 »
Tp4 no do drugs.. y everyone think I do drugs..  I no do drugs.
Online tp4tissue
« Reply #55 on: Sat, 18 July 2015, 19:40:24 »
You know what's really good and easy to eat after removal?
Silken tofu + sesame oil + light soy-sauce dip.
Online tp4tissue
« Reply #56 on: Sat, 18 July 2015, 22:08:03 »
Guys.. my back hurts..   Why does my back hurt..  Is this normal ?
« Reply #57 on: Sat, 18 July 2015, 22:09:51 »
Your kidneys must be shutting down.
Online tp4tissue
« Reply #58 on: Sat, 18 July 2015, 22:10:24 »
is there such a thing as kidney pain?
I've kept my diet pretty simple so far.
Potato bisque, (pureed)
Banana
and Silk Tofu..
Online tp4tissue
« Reply #59 on: Sun, 19 July 2015, 11:53:48 »
I screwed up my calories calculation..  Apparently 5-lbs of potatoes is only ~1550 calories..  Which is what I made my main Soup-of-Wellness out of..
So I've been eating only ~900 calories per day for the past 2 days..    No wonder I'm so tired and dying..
You'd think 5-lbs of potato would be more than 1550...
I was guessing 5000..
Pain_Update:
Still fairly swollen .. left side more so than right .. but both are puffy..
Pain lvl 2 ..
Mild accompanying headache .. Pain lvl, + 0.5
Current Pain-lvl_ 2.5
I tried some other foods today, but I noticed that most foods with oil are quite sticky, and does not dissolve in regular water.. So rinsing is not effective without a "full brushing w/ tooth paste"
Online tp4tissue
« Reply #60 on: Sun, 19 July 2015, 14:11:51 »
God I'd really like some fried chicken now..
All this depression,  and hungri-ness
« Reply #61 on: Sun, 09 May 2021, 10:41:35 »
For what it's worth, I had mine out in 1972.
Abscessed teeth and root canals are far worse.
"Starting in 2011, the deficits again started to shrink. During Obama’s term  the deficit was reduced by $900 Billion  before finally in 2015 the GOP managed to wrangle a “reconciliation” bill out of Obama where he again cut corporate taxes, as well as made permanent some of George W. Bush’s original tax cuts. This is the year everything reversed. Before this, under Clinton, Bush and Obama the deficit in almost every year was gradually decreasing. The balance we had of taxes and the economy was bringing the deficit down, the money coming in was slowly catching up with the money going out until 2015. Trump’s subsequent tax cut has continued the new trend even after the rest of Bush’s cuts have since expired. Obama had an average GDP of 2.3%, with 11.6 million jobs created and unemployment peaking at 10% in 2009, then falling to 4.3% in 2016. If we had continued on that downward deficit track, we would have again reached balance and another surplus in 2017-2018.
– Frank V Walton 2025-07-01
Offline Marsha11
« Reply #62 on: Mon, 10 May 2021, 04:30:33 »
How are you doing, man? Had implants recently and remembered a time when I was just starting out in dentistry. A few years ago I decided to get my teeth aligned. But their condition was critical. At first, they tried to fix them. But then they decided to just pull them out. All right, I thought. But the pain...it was the worst pain of my life. I didn't want to go back to that clinic again. Found jeffreygrossdds.com online. Went to see them. After the consultation, I continued my treatment. It was painless, and I recently got implants from them. My teeth are fine now.
« Last Edit: Tue, 11 May 2021, 04:48:16 by Marsha11 »
« Reply #63 on: Mon, 10 May 2021, 07:44:07 »
I'm fine, been through it 3 times in about 20 years. Only 1 has required an implant and I waited nearly 3 years before getting a tooth to fill the gap (long story). But it went in fine and I am happy with the result.
Back story - that chain of events started when I cracked a tooth on a piece of bone in a hamburger at Fuddruckers in 1995.
