Author Topic: Macrium Reflect  (Read 2392 times)
Macrium Reflect
« on: Thu, 06 August 2015, 22:50:08 »
Why the hell did I pay for Acronis..
This reflect thing work perfect..
Offline heedpantsnow
  • Old enough to know better
Re: Macrium Reflect
« Reply #1 on: Fri, 07 August 2015, 01:06:31 »
Well I guess you pay when you want support and use free versions when you don't?  Frankly I don't know. So it works well?
I'm back.
Re: Macrium Reflect
« Reply #2 on: Fri, 07 August 2015, 01:36:18 »
it work good, very.
It's got all the most useful stuff covered under the free version.
Clone,  Image,  Create USB bootable (this is important)
Offline KaminKevCrew
Re: Macrium Reflect
« Reply #3 on: Sat, 08 August 2015, 09:55:40 »
I've used maricum to bring a laptop with a failed raid array back up. It works really, really well, and the software is pretty easy to understand. The only thing I don't like is that I couldn't figure out how to clone to a partition on a drive, instead of cloning over the whole drive, but that may have to do with cloning, and not maricum specifically.
Re: Macrium Reflect
« Reply #4 on: Sat, 08 August 2015, 10:16:38 »
I think you need to click restore partition parameter during the cloning menu process to either make, shrink, or enlarge a partition.
It's the part where you select your destination drive..
Re: Macrium Reflect
« Reply #5 on: Sat, 08 August 2015, 10:19:58 »
Ah, I never saw that option! I'll keep it in mind next time I need to make a backup!
Offline Leslieann
Re: Macrium Reflect
« Reply #6 on: Sat, 08 August 2015, 16:01:10 »
It's not as intuitive as Active@ or Acronis (which are dead simple), but it does work well.
The one place it shines is on creating the disk, Macreum will automatically format as GPT if necessary.
There are other free alternatives as well, but those are even less intuitive.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Re: Macrium Reflect
« Reply #7 on: Sat, 08 August 2015, 16:28:45 »
Intuitive is for N00bs..
We all Pr0z here at GH...
Offline digi
  • elite af tbh
  • keyboard game on fleek
Re: Macrium Reflect
« Reply #8 on: Sat, 08 August 2015, 16:29:44 »
You use ESX? If so veeam is good.
Offline Leslieann
Re: Macrium Reflect
« Reply #9 on: Sat, 08 August 2015, 16:57:58 »
Of course we are, sweetie...
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
