Author Topic: What Geekhack theme do you use?  (Read 4726 times)
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« on: Thu, 13 August 2015, 23:18:56 »
As of late, I noticed that a lot of people use the white Geekhack theme, and honestly, I thought the Nice black and orange theme was more used...
SO, what theme do you use?
I use Frenir's simplistic geekhack theme
(https://geekhack.org/index.php?topic=60016.0)
Offline nmur
  • ಠ_ಠ
Re: What Geekhack theme do you use?
« Reply #1 on: Thu, 13 August 2015, 23:22:59 »
I'm using Austere (one of the default options).
Mostly because it looks nice, but also because the white background doesn't make it as obvious that I'm slacking off at work..
« Reply #2 on: Thu, 13 August 2015, 23:24:42 »
Austere, the easiest to read for me.
Offline KnivesM
« Reply #3 on: Thu, 13 August 2015, 23:28:12 »
Black and orange default
Others
« Reply #4 on: Thu, 13 August 2015, 23:29:02 »
Nostalgia.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #5 on: Fri, 14 August 2015, 00:10:46 »
Frenrir w/ Oranje
Offline eddie
« Reply #6 on: Fri, 14 August 2015, 00:47:17 »
default
« Reply #7 on: Fri, 14 August 2015, 00:53:30 »
Nostalgia.
Are there other themes?
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #8 on: Fri, 14 August 2015, 11:53:22 »
23,567 use Austere (what I use)
21,567 use Nostalgia
566 use Thoriated
124 use Oranje
« Reply #9 on: Fri, 14 August 2015, 11:54:25 »
I use Nostalgia. Switched from Thoriated. Austere ruins my eyeballs.
  • Live long and prosper
« Reply #10 on: Fri, 14 August 2015, 11:57:11 »
Thoriated.
tp thread is tp thread
Offline ghostjuggernaut
« Reply #11 on: Fri, 14 August 2015, 11:59:13 »
Thoriated as well.
Offline Coreda
« Reply #12 on: Fri, 14 August 2015, 12:01:26 »
Another fan of Frenir's dark theme userstyle. Also the non-nested quotes userstyle in my sig is a necessity I can't browse without.
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #13 on: Fri, 14 August 2015, 12:15:07 »
I use Austere. I was using Nostalgia for a while, but then people at working started picking up that it was non-work related site. Switching to a lighter theme seemed to get people off my back. They probably also don't realize it is the same site, so that helps too.
Offline Nai_Calus
  • CLACK
« Reply #14 on: Fri, 14 August 2015, 14:59:27 »
There are themes?
- IBM 4704 Model F 107-key "Bertha"
Other boards: Kinesis Essential, Infinity(G.Clears), Ergodox(MX Blues), Monoprice 9433
Eternally searching for Celestial Blue BS V2 and blue/purple Bros.
Offline Lurch
« Reply #15 on: Fri, 14 August 2015, 15:00:20 »
Quote from: Flyersfan1
« Reply #16 on: Fri, 14 August 2015, 15:14:22 »
Tp4 sees the world only through Darkness. !
Offline Fire Brand
  • Keeper of Rainbows
  • BISCUITS!
« Reply #17 on: Fri, 14 August 2015, 15:28:47 »
That really lovely white one ^~^
My Youtube Channel ~
Keyboards owned
My classified thread :3
Offline Ramage
« Reply #18 on: Fri, 14 August 2015, 15:45:21 »
I found the white one to be easier on my eyes.
Offline Dr. Drats
« Reply #19 on: Fri, 14 August 2015, 17:50:26 »
Nostalgia with Hacker Vision (A Chrome add-on). White & Sky Blue. Gorgeous.
« Reply #20 on: Fri, 14 August 2015, 20:46:18 »
How does anyone actually use oranje?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #21 on: Fri, 14 August 2015, 21:18:39 »
IDK, I like the colors of jt
« Reply #22 on: Fri, 14 August 2015, 21:51:10 »
My eyes bled just from the preview.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #23 on: Fri, 14 August 2015, 21:59:52 »
trying fenrir's solarized right now.  Not too bad.
Offline Bomble
« Reply #24 on: Fri, 14 August 2015, 22:09:07 »
I didn't know about fenrir's themes until this thread, but I'm now using the simplified theme, previously used nostalgia though.
Offline maxpegasus
  • The search goes ever on and on...
« Reply #25 on: Fri, 14 August 2015, 22:11:32 »
Huh just found out about thoriated and i'm trying it out now... so far so good. Used Austere before
« Reply #26 on: Fri, 14 August 2015, 23:29:40 »
what's throated?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #27 on: Fri, 14 August 2015, 23:31:05 »
I like it because it isn't too harsh on the eyes in daylight or nighttime. I use f.lux though so orange tint has kind of grown on me
Offline wlhlm
« Reply #28 on: Sat, 15 August 2015, 02:15:37 »
