Author Topic: So, First Night Ronery, new apartment  (Read 2992 times)
« on: Mon, 14 September 2015, 11:01:03 »
I locked myself out of my own bedroom TWICE in one night.
Not used to living in this type of room that needs a key with no outside handle.
The fact that I could break back into my own room by picking the window locks only prove that the security detail is needlessly tedious, and worthless..
I will be installing all new locks and window locks once I get settled..
Offline azhdar
  • Praise the AZERTY god
Re: So, First Night Ronery, new apartment
« Reply #1 on: Mon, 14 September 2015, 11:03:22 »
Only thing important in this thread is the return of onion head.
Azerty Propagandiste
Offline Jokrik
« Reply #2 on: Mon, 14 September 2015, 11:05:32 »
advice: kensington lock on your ergo dox first
take everything but not your dox right?
« Reply #3 on: Mon, 14 September 2015, 11:05:53 »
I can't promise mucho onion in the future..
Because I only have access, when the VPN works..
Alas,  it doesn't always work.
« Reply #4 on: Mon, 14 September 2015, 11:08:23 »
Well, that is certainly how I feel about my Egdx..
But, overall, I don't think the robbers would pass up a laptop over some keyboard they've never seen before.
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #5 on: Mon, 14 September 2015, 16:01:15 »
Onion head is mucho importante, tp4.  You must find a solution.
« Reply #6 on: Mon, 14 September 2015, 16:10:05 »
Re-host them all on imgur or something.  Whatever it takes.
Offline Lanx
« Reply #7 on: Mon, 14 September 2015, 17:54:58 »
security window issues? try these
window wedge
i have em on all my windows, especially great when you have a window AC (i mean they could just lift up the window and enter, wtf! The velcro might look silly, but it's also a good way to install something w/o drilling holes into the frame (landlord issues). You only need 1 per window. It feels pretty impossible to HULK your way opening this window w/o basically breaking the glass.
Think about installing new screws too if you want your door to protect you. Most doors are screwed in w/ 2in screws (door jamb/bolt) which only really just does the door jamb, the 3in screws will get you into the frame/stud at least.
« Reply #8 on: Tue, 15 September 2015, 08:07:22 »
window wedge
http://www.msgking.com/wp-content/uploads/2009/02/onion-head-dp-animated04.gif
I could make these out of wood, and just buy some velcro no?
Offline TheO-RingGuys
  • Hey, my name is Fernand and I sell o-rings. B)
« Reply #9 on: Tue, 15 September 2015, 22:21:19 »
Correct me if I'm wrong but isn't it against most leases to replace the locks?
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #10 on: Wed, 16 September 2015, 01:10:03 »
I'll dedicate my time to getting those onion heads hosted elsewhere that you can use them readily. Just tell me where to start tp.  :-*
Offline azhdar
« Reply #11 on: Wed, 16 September 2015, 01:12:58 »
The onion head Db: http://emoticoner.com/emoticons/onion-head
Just make a big imgur album.
Offline Air tree
« Reply #12 on: Wed, 16 September 2015, 01:46:09 »
Annnnd, done!   ^-^
http://imgur.com/a/CFUYp
I might have missed one or two, just let me know.  :)
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #13 on: Wed, 16 September 2015, 01:53:00 »
Moved into my own place last week too. After a decade of living with house-mates or girlfriends it's very weird being on my own. I like it, just takes some getting used to.
« Reply #14 on: Wed, 16 September 2015, 08:03:42 »
Annnnd, done!   ^-^
Many thxx  Tree of Air
Would you also happen to possess the ability to absorb moisture.. It's so humid in China..
