Author Topic: Anyone ever have to deal with ghosts? I have a predicament.  (Read 2477 times)
Offline grav3serker
  • graves + berserker = grav3serker
« on: Fri, 30 October 2015, 22:32:57 »
So my girlfriend, daughter, and I just moved out of state back to her parents house a few days ago, and whenever my 11 month old daughter is sleeping in either our room in the guest house, or in one of the bedrooms at the main house, the lights will randomly turn on. The light switches on the walls need to be pressed, instead of switched on like normal lights. This only happens shortly after we put her down, either for a nap, or to bed for the night.
The house was rebuilt from the ground up. My father in law is a contractor, so electrical wiring isn't anything new to him, but it wasn't until we moved here that things started happening. We have never had any prior experiences like this, and it isn't scary per se, but I just want to figure out what exactly is going on.
An uncle of mine has had ghosts in his houses when I was growing up, so they don't bother me, but it's just weird how I or my in-laws haven't had any experiences like this until we moved here 3 days ago.
Does anyone have any thoughts or inputs on this? Cheers!
Edit: https://imgur.com/TLAXDvC Here is a picture of the light switch. The top two are the light switches, the bottom part is for the fan.
Edit 2: This happened 3 times within 15 or so minutes tonight and apparently my mother in law has had to turn off the guest bedroom light twice in the last 45 minutes. She is in the main house, we are in the guest house.
Offline Belfong
Re: Anyone ever have to deal with ghosts? I have a predicament.
« Reply #1 on: Fri, 30 October 2015, 22:37:54 »
I might have been reading too much King but do you think it’s telekinesis instead? Your daughter might have a strong will. I mean if you think there’s ghost and all as a possibility, I’d think telekinesis is a more likely possibility.
« Reply #2 on: Fri, 30 October 2015, 22:38:57 »
No, I've never had to deal with something that isn't real.
Offline grav3serker
« Reply #3 on: Fri, 30 October 2015, 22:44:07 »
It's possible, but who knows at this point haha. I think it's too early to tell, but I'll keep that idea in mind!
Fair enough!
Offline njbair
    • nickbair.net
« Reply #4 on: Fri, 30 October 2015, 22:44:38 »
Avatar checks out.
My boards:
Offline grav3serker
« Reply #5 on: Fri, 30 October 2015, 22:51:50 »
Avatar checks out.
 This made me laugh pretty hard haha :p
« Reply #6 on: Sat, 31 October 2015, 00:29:31 »
How Can Mirrors Be Real If Our Avatars Aren't Real?
Offline fanpeople
« Reply #7 on: Sat, 31 October 2015, 03:18:17 »
Does the light system have a sensor/timer feature. You may need to look up some documentation and check.
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #8 on: Sat, 31 October 2015, 03:42:55 »
The simplest first step is to try replacing the switch.
« Reply #9 on: Sat, 31 October 2015, 03:52:40 »
The ghosts should probably leave you alone if you would stop serking grav3s. ;)
Yeah, I also think it is probable that your "smart" wall switch could be dumb. Either that, or a physical switch inside it is faulty.
I also have an annoyance: some guy who calls himself "Snooze" keeps calling me on my cell phone every five minutes ...
« Last Edit: Sat, 31 October 2015, 03:59:23 by Findecanor »
« Reply #10 on: Sat, 31 October 2015, 09:08:13 »
If I had ghostly powers..  hanging around "People" would not be on my to-do list..
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #11 on: Sat, 31 October 2015, 09:09:18 »
You already don't hang around people.
