Author Topic: MX Blacks too stiff, MX Reds too light, which switch to try next?  (Read 25092 times)
Offline Geroximo
Hi guys,
I'm having trouble finding the perfect linear switch for me.
I began with MX Blacks, but soon realised, that they are too stiff for longer typing sessions.
Next came the MX Reds. At first, the lighter keypress was comfortable, but now I find them too light.
I also tried Kailh Reds. The 50g actuation force felt quite good, but I don't like the built quality of the switches.
So I'm asking you:
Which linear switch should I try next?
Offline slickmamba
Re: MX Blacks too stiff, MX Reds too light, which switch to try next?
« Reply #1 on: Fri, 01 January 2016, 15:03:24 »
Hi guys,
So I'm asking you:
Hey bud, there is nothing really inbetween, you're going to have to mod some switches yourself.  MX red falls around 58g, and MX black falls around 68ish, so 60, 62, 65 will be your next logical places to check out.
edit: the two systems (MX vs korean) use different rating system btw.
« Last Edit: Fri, 01 January 2016, 15:05:18 by slickmamba »
Hi :)
Offline falkentyne
« Reply #2 on: Fri, 01 January 2016, 15:16:58 »
Hi guys,
So I'm asking you:
This?
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1487
Offline ideus
  • Björkö.
« Reply #3 on: Fri, 01 January 2016, 15:20:41 »
There is nothing in between blacks and reds, but if you are open to try tactile switches, I'd say that probably browns or clears may fit your typing style.
Offline slickmamba
« Reply #4 on: Fri, 01 January 2016, 15:28:49 »
If you can afford it, I'd highly suggest getting some linear zealios in the range I suggested earlier as well.
https://zealpc.net/collections/accessories/products/zealioclear
Hi :)
Offline Geroximo
« Reply #5 on: Fri, 01 January 2016, 16:04:08 »
Thank you for the replies.
I'm looking for a linear switch, because I don't like gaming on tactiles.
What about Gateron Blacks?
They are rated with a 50g actuation force, which would be slightly heavier than Mx Red, right?
The Zealios are a bit expensive, but I'll keep an eye open for Korean springs. Modding switches is not a problem.
Offline jerue
  • (Whenever that happens :P)
« Reply #6 on: Fri, 01 January 2016, 16:35:37 »
That makes this easier
Lubed Gateron Blacks
or some 62g lubed blacks (mind that the weight is bottoming out, not actuation) - you can go heavier or lighter depending on your preferences, you probably don't want lighter than 55g.
Offline slickmamba
« Reply #7 on: Fri, 01 January 2016, 16:50:49 »
I thought Gateron black was the same as mx black?  I might be wrong though.  Ask around to be sure if they are lighter
Hi :)
Offline bocahgundul
  • a seal
« Reply #8 on: Fri, 01 January 2016, 16:53:22 »
Gateron black is smoother. You shoul try zeal clear too
Offline fuzzybaffy
« Reply #9 on: Fri, 01 January 2016, 16:56:47 »
Like someone else mentioned... the MX Nature White is a linear switch, that's between the MX Black and MX Red - at 55g.
Offline slickmamba
« Reply #10 on: Fri, 01 January 2016, 16:58:40 »
I'm talking about the spring actuation weight
Hi :)
Offline jerue
« Reply #11 on: Fri, 01 January 2016, 17:06:02 »
Deskthority rates MX Blacks 10cn heavier than the Gaterons (at 60g vs 50g)
Offline bocahgundul
  • a seal
« Reply #12 on: Fri, 01 January 2016, 17:08:20 »
oh yes but it definitely feel smoother also
Offline 1deeg
« Reply #13 on: Fri, 01 January 2016, 21:25:23 »
The new Cherry MX Nature White is a linear switch with actuation force in between MX red and blacks. It's currently only available in the Ducky Shine 5.
Gateron Yellows are also linear and require less bottom-out force than MX & Gateron Blacks.
http://imgur.com/a/g1f0A
Offline ideus
  • Björkö.
« Reply #14 on: Fri, 01 January 2016, 21:57:10 »
But Gateron blacks are even lighter than Cherry reds.
Offline Vittra
  • Airflow Optimizer
« Reply #15 on: Fri, 01 January 2016, 22:31:14 »
Based on my understanding - the only Gateron switch lighter than Cherry MX Red in terms of actuation force would be Gateron clear - most likely bottom out force too.
I think when people reference force, it should be mentioned if it is actuation force or total force/resistance when the switch is bottomed out.
Since OP is mentioning gaming, bottom out force may actually matter more here. I know that's what made me switch from MX Black to MX Red ~4 years ago. Based on that criteria, the newer Gateron Black, Gateron Yellows and Cherry MX Nature White are all possible candidates.
Force graph comparisons:
http://www.wasdkeyboards.com/mechanical-keyboard-guide#best (Cherry MX Switches)
http://www.cherry.de/PDF/EN_CHERRY_MX_RGB_NATURE_WHITE.pdf (Cherry MX Nature White)
http://imgur.com/a/g1f0A (Previously linked by 1deeg - various comparisons, of note is Gateron Yellow)
Filco MJ Linear R LE TKL
Offline Den441
« Reply #16 on: Sat, 02 January 2016, 02:57:59 »
Typing on 62g Korean spring reds now. I think it is the perfect linear switch. Definitely feels like something between reds and blacks. To me, reds don't have any springy-ness to them, and blacks can feel too heavy during long sessions. The 62s bring that springy-ness and it feels great. I think it is worth the trouble of modding them.
Custom Wrist Rests, Artisan Keycaps, and more - http://battlestation.io
Sales Thread - https://geekhack.org/index.php?topic=74835.0
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #17 on: Sat, 02 January 2016, 06:19:22 »
Ha! These are very familiar symptoms to me. I find the exact same; reds too light and blacks too heavy. Here's what I've found so far.
The truth is; blacks feel too heavy not because they're too heavy, but because they are a terrible switch. They're very scratchy and this makes them feel heavier than they actually are. In my video reviews I use MX black as a kind of benchmark switch and almost always they lose against the alternative (iirc the one time they came out on top was against Cherry MY).
I'm in the process of obtaining a green Alps board, which are lighter and smoother than MX black. They're probably rather legacy for your purposes, but my point is; there are many alternatives to Cherry MX you might not even have heard of.
I've only tried a few test switches, but Gateron blacks feel smoother and lighter than MX black to me, much nicer really. Nixdorfs are also better, but not so easy to get.
Offline bocahgundul
  • a seal
« Reply #18 on: Sat, 02 January 2016, 06:45:02 »
Nixdorf are really rare and really expensive if you see somone sells it. My opinion is to get gateron black or zeal clear linear switch  :thumb:
Offline Coreda
« Reply #19 on: Sat, 02 January 2016, 06:51:26 »
Was going to make a joke that Cherry should produce a Goldilocks switch before discovering that such a switch actually exists.
Offline chyros
  • a.k.a. Thomas
« Reply #20 on: Sat, 02 January 2016, 08:05:43 »
Yeah, they're damn expensive. I got lucky, someone gave me a bunch of cool switches for free and it included three Nixdorfs. They remind me a bit of Gaterons, but not as oily.
Gateron blacks are way better than MX blacks, though, IMO. I think you should really check out those :thumb: .
« Reply #21 on: Sat, 02 January 2016, 08:09:00 »
No, ur all wrong..
what you should do , is stick with MX-black, until you break it in.
The spring softens up a bit, and in general, the slider will also smooth up due to friction,
Both- of those factors will make the mx-black feel much much lighter..
Offline chyros
  • a.k.a. Thomas
« Reply #22 on: Sat, 02 January 2016, 08:52:25 »
No, ur all wrong..
Doesn't testify of a good switch design though, does it? :/
Besides, I've had MX blacks used and almost unused, still didn't like any of them. All too rough and too stiff. But that's just me, of course.
« Reply #23 on: Sat, 02 January 2016, 08:57:30 »
No, ur all wrong..
If you find ANY of the mx-switches 'rough"
it's simply because you're well below the break in point..
This is the case with many of the kids around here, because they don't actually use the keyboard that much..  minus wasd, hahahaha
Smoothness is Significantly improved over time.  It has more to do with the material used in the Mx switch housing.
The slider plastic is pretty smooth right off the bat.
However, the black housing where the slider comes in contact with it is quite rough.
Something around 10,000 keypresses is where it reaches smoothness.
If you're just "TRYING" out the keyboard, you will Not even come close to 10,000
Offline chyros
  • a.k.a. Thomas
« Reply #24 on: Sat, 02 January 2016, 09:22:22 »
No, ur all wrong..
I don't know about you, but I've had over a dozen MX black keyboards, all of them second-hand, and some of them POS boards so well-used the legends were barely even legible. I've had so many of them I'm even done salvaging them for parts, they're not worth the money to sell or the time needed to salvage even more switches (I already have hundreds) :P .
Regardless, if it takes 10k presses for the switch to be remotely usable, why don't Cherry spare us the trouble and break them in for us? Why do we have to use sub-par equipment for a considerable amount of time before the product supposedly becomes halfway competitive? I'm sure everyone knows the answer to that one xD .
« Reply #25 on: Sat, 02 January 2016, 09:26:58 »
THey gotta make money and breaking them in would cost too much money..
Honestly, Yea, if I were them, I would consider changing the housing plastic to be smoother from the get-go..
But the issue is.. this is not a 'technology' in dire need of innovation.
We here at Geekhack are the too 'few' people who gives a damn about how the keyboard looks and feels..
The majority of the keyboard users out there do not..
Offline jcoffin1981
« Reply #26 on: Sat, 02 January 2016, 15:54:30 »
I don't k now these switches personally, but have you looked into Gateron or Matias?  They may have a linear switch more suited for your needs.
Offline x9Memoriez
« Reply #27 on: Mon, 04 January 2016, 17:35:35 »
If you can try to find a keyboard that has Gateron Blacks, you might enjoy those.
Slightly heavier than reds, but not as heavy as MX Blacks, theyre about the mid point, they're also arguably much smoother than their cherry brothers.
You're sadly either going to have to build a keybord yourself or find some deal off Massdrop where Gateron switches are an option, as theyre not all that common, but very well regarded.
Matrix 1.2OG | Constellation | Rukia | TMO50 | HHKB
Offline MeltingTeeth
« Reply #28 on: Mon, 04 January 2016, 17:59:28 »
No.  Not correct.
Offline Giorgio
« Reply #29 on: Thu, 07 January 2016, 16:35:58 »
the cherry silent switches are been reds and blacks
Currently available on the corsair strafe silent.
Offline Geroximo
« Reply #30 on: Tue, 23 February 2016, 09:07:16 »
Hi,
want to give a little status update.
Meanwhile I layed hands on some vintage MX Blacks and Gateron Blacks.
Vintage Blacks:
Nice switch, smoother and a tiny bit lighter than modern MX Blacks. They still feel a bit too heavy for my taste. I will try to get some 65g springs for them.
Gateron Blacks:
Wow. This was what I was looking for. Smoother than modern MX Blacks and right between MX Red and MX Black in actuation force. I am very happy with this purchase.
Offline merlin64
    • MechMerlin
« Reply #31 on: Tue, 23 February 2016, 10:01:25 »
Thanks for the update.
In terms of actuation force, do you feel they are closer to Cherry MX Reds, or to Cherry MX Blacks?
Offline crickclackman
« Reply #32 on: Tue, 23 February 2016, 10:06:58 »
Gaterons are in between.
http://www.imgur.com/a/MjDTX
Offline lootbag
« Reply #33 on: Tue, 23 February 2016, 10:35:13 »
Vintage Blacks:
Gateron Blacks:
Interesting to hear!
I have krytox lubed vintage blacks with 68g springs and find them a tad bit heavy as well.
Considering a spring swap for the vintage blacks as well, 62 or 65g.
Recently ordered some Gateron Yellows and hoping I will like them.
That being said I don't see how they can be even smoother than the vintage blacks.
Used to daily MX reds when they were first released and found them a bit light (a little scratchy too), which resulted in too much clackiness on the bottom out.
Maybe I need to expand to the tactile territory again with some zealios...
Offline Geroximo
« Reply #34 on: Tue, 23 February 2016, 12:45:56 »
To me they feel like they are exactly in the middle between MX Reds and MX Blacks.
I actually tried the 62g vintage blacks already. I found 62g to be too light for me. That's why I want to trade my 62g gold plated springs for some heavier springs. Would you like to trade?
I don't think Gaterons are smoother than vintage MX Black, but they are very close.
Offline lootbag
« Reply #35 on: Tue, 23 February 2016, 19:30:43 »
I would consider trading but my 68g springs are currently in my Duck Viper and too busy to desolder everything right now.
Interesting info about the Gaterons and vintage MX Blacks; I guess I will find out when my Gateron Yellows arrive.
Offline clacktalk
  • circa 2015
« Reply #36 on: Tue, 23 February 2016, 19:44:33 »
tldr
55g vintage blacks or nono
diary of a clacktalk
radio_killah: too much frank
Offline bocahgundul
  • a seal
« Reply #37 on: Tue, 23 February 2016, 20:02:27 »
tldr
What springs? Korean SS or gold springs legitballin?
Offline clacktalk
  • circa 2015
« Reply #38 on: Tue, 23 February 2016, 20:06:10 »
tldr
korean gold only choice of course
Offline bocahgundul
  • a seal
« Reply #39 on: Tue, 23 February 2016, 20:10:46 »
tldr
Where u buy your springs clacks?
Offline OTD
« Reply #40 on: Tue, 23 February 2016, 20:13:30 »
Getting custom springs from a GB participant or from a re seller and lube modding an mx red or black will be your best option sir.
Offline TalkingTree
    • My projects
« Reply #41 on: Wed, 24 February 2016, 04:53:51 »
I have experience with either Cherry MX Blacks, Cherry MX Reds and Gateron Blacks. I can vouch for Gateron Blacks being intermediate between aforementioned Cherry MXs.
I bought 250 units for € 55 on Aliexpress. PM me for details, I'll point you to the vendor.
Offline appleonama
  • Trollo en USA
« Reply #42 on: Wed, 24 February 2016, 05:20:03 »
Try some Gaterons or linear zeals
you can also try modding some switches with different spirngs
Offline Sku
« Reply #43 on: Wed, 24 February 2016, 06:03:52 »
Gateron Yellows.
They are stiffer than Reds, lighter than Blacks, smoothest of all.
By far the best switches available out there, in my humble opinion.
SPECS:
They activate at 55g (same as Gateron Blacks) and bottom out at 65g (Gateron Blacks @ 70g).
http://m.imgur.com/a/g1f0A
Credits to Ripster and MiTo.
Offline Sku
« Reply #44 on: Wed, 24 February 2016, 06:06:33 »
Just realized you already went for Gateron Blacks, wonderful choice!
Offline yomammary
« Reply #45 on: Wed, 24 February 2016, 14:09:16 »
Edit: Nevermind.
RF 87u 55g | Leeku 1800
Offline klennkellon
  • I like bottoming out
« Reply #46 on: Wed, 24 February 2016, 17:34:57 »
Try Kailh Reds or Kailh Yellows.
I measured around 50g actuation, which is right between MX Black and MX red
Offline jacobolus
« Reply #47 on: Wed, 24 February 2016, 18:21:19 »
Some good choices:
* Green Alps
* White Hi-Tek “space invaders” (might be a bit too stiff for your preference though)
* Black Gateron
* Spring-modded linear Cherry MX
* Red Matias using the springs from clicky Matias (swapping the springs improves both switches)
* Alps or Alps-inspired switches (e.g. SMK or Omron) with the click leaf removed
If you’re willing to use stuff from the 70s (especially if you’re willing to mod it), there are a lot of great old linear switches. Most of them are about as stiff as black MX or stiffer though, and only come on keyboards with older funky layouts. Some might be tough to get working with modern computers.
Has anyone ever seen “Cherry MX RGB Nature White” switches in the wild? https://www.cherry.de/PDF/EN_CHERRY_MX_RGB_NATURE_WHITE.pdf
Geekhack discussion: https://geekhack.org/index.php?topic=76240.0
« Last Edit: Wed, 24 February 2016, 18:29:16 by jacobolus »
Offline Hyde
  • White Tofu Extraordinaire
« Reply #49 on: Wed, 24 February 2016, 19:24:51 »
Hi guys,
So I'm asking you:
This?
The Nature White is shipping.
https://mechanicalkeyboards.com/shop/index.php?l=product_list&c=277
https://www.reddit.com/r/MechanicalKeyboards/comments/441n2d/review_ducky_shine_5_cherry_mx_rgb_nature_white/
^ What they said.
The Linear Nature White was designed to go between MX Black and MX Red.
Currently Ducky owns the exclusive right to use them.
