Author Topic: Has anyone seen these?  (Read 9165 times)
Offline 1391406
« on: Sun, 31 January 2016, 20:17:57 »
I ran across these on Taobao (scroll down the page for pics) and I'm wondering if these are fairly well-known? I've never heard of or seen them before. It's a capacitive membrane based board (a la Topre) but I don't recognize the keycaps, domes, or anything else. Is it a knockoff of something or ... ? I don't know. Just wondering.
« Last Edit: Sun, 31 January 2016, 20:19:28 by 1391406 »
Offline kekman
  • quit life
Re: Has anyone seen these?
« Reply #1 on: Sun, 31 January 2016, 22:15:41 »
I'll ask my friend to translate tonight, but so far all he's said is that the RGB version comes in white, non-rgb comes in white/grey, with TKL and 100% variants, they're compatible with MX Keycaps, overall VERY interested in this board, I might pick one up if I end up going to China around April
Offline nmur
  • ಠ_ಠ
« Reply #2 on: Sun, 31 January 2016, 22:19:00 »
if it's cheap I'd consider buying it just for the sliders
Offline 1391406
« Reply #3 on: Sun, 31 January 2016, 22:31:50 »
These are obviously Topre knock-offs. They used the Realforce name for a couple of them:
I don't know what the weighting is on those, but the 108 black or white RGB is 45g.
« Last Edit: Sun, 31 January 2016, 22:33:27 by 1391406 »
« Reply #4 on: Sun, 31 January 2016, 23:40:58 »
saw one about a month ago.. a kid had one on the bus..
Felt like topre.. a bit softer.. but that could just be maybe he games alot.
« Reply #5 on: Sun, 31 January 2016, 23:45:33 »
You asked to feel a strangers keyboard on the bus?
Offline Macsmasher
« Reply #6 on: Sun, 31 January 2016, 23:57:57 »
Hey, can I borrow your toothbrush?
« Reply #7 on: Mon, 01 February 2016, 00:02:35 »
Only if I can use your deodorant!
Offline klennkellon
  • I like bottoming out
« Reply #8 on: Mon, 01 February 2016, 01:12:06 »
I thought the Thailand made Dell Quietkeys were the best "ratchet topre"? Interesting.
Offline jaffers
« Reply #9 on: Mon, 01 February 2016, 02:35:37 »
« Reply #10 on: Mon, 01 February 2016, 02:59:38 »
There are surprisingly few mechanical keyboard folks here..
He was the only person I've met thus far , i figured he'd be ok with it, since the rest of us like to feel each other's keyboards in 'murica..
I'm serious though, not just making this up. i saw that exact board..
« Reply #11 on: Mon, 01 February 2016, 03:01:00 »
I'm just surprised you asked! You're so outgoing now :)
Offline Macsmasher
« Reply #12 on: Mon, 01 February 2016, 03:43:29 »
Sure, if I can borrow your underwear.
« Reply #13 on: Mon, 01 February 2016, 04:03:15 »
Sure, if I can borrow your dildo
Offline 3K
« Reply #14 on: Mon, 01 February 2016, 04:29:06 »
If anyone gets himself this thing, I'd like one too. Like could we IC this?
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #15 on: Mon, 01 February 2016, 04:37:04 »
I've got the 55g model delivered to me...... Not bad at all.
Offline kekman
  • quit life
« Reply #16 on: Mon, 01 February 2016, 05:04:11 »
Comparisons to actual topre? and can we get confirmation that it is possible to swap out topre sliders for these sliders?
Offline Macsmasher
« Reply #17 on: Mon, 01 February 2016, 14:49:34 »
Absolutely not. Sorry, but I have to draw the line somewhere.
Offline Elrick
  • Hype Master
« Reply #18 on: Mon, 01 February 2016, 17:12:15 »
Surprisingly similar because they have used a thick metal plate in which they've attached the thorpie switches to and it's tough.  Have furiously hammered the keys and no ping or any other noises can be heard.  Nice to actually type with a 55g resistance, please don't ask me to measure it since I don't have any specialized tools for that task but I know it's definitely firmer to press compared to the standard RF 104 keyboards.
The weight of this keyboard is somewhat heavier than the standard RF so that's good, plus the lasered keys associated with this purchase are okay to me but to the enthusiast at large that loves their BSP keys, there's no comparison.  Even though this keyboard is made by Hansung in China, it has delivered a very usable keyboard and with the CherryMX sliders could definitely use any type of SA or Cherry profiled keys with this keyboard.
Another thing of note here, it looks like the keyboard casing is made out of PBT along with the keys because they have a similar texture and feel to each other.  You also get the spacer key which is all PBT as well, imagine a Chinese company offering an all PBT key-set yet the Japs refused to use any PBT spacers on any of their models.
Just surprised to be singing the praises here for a "Made in China" product but considering this is thus far the ONLY 55g thorpie keyboard currently available I had to buy it to see what's it's like, it's now connected permanently to one of my PC's.
« Last Edit: Mon, 01 February 2016, 18:02:00 by Elrick »
Offline kekman
  • quit life
« Reply #19 on: Mon, 01 February 2016, 18:01:11 »
very interesting, thanks for the reply. what material is the case made of and is it of good strength?
Offline Elrick
  • Hype Master
« Reply #20 on: Mon, 01 February 2016, 18:05:09 »
The casing looks to be made out of PBT because it doesn't flex at all when stressed.  I usually twist each casing I buy to see how it squeaks and normally all ABS casings squeak when twisted.
The keyboard is quite solid compared to most others being sold today, definitely surprised with it's quality since we've all purchased keyboards from them (China) over the years that left us feeling cheap and nasty after using them but not this one.
Offline Vimto
« Reply #21 on: Tue, 02 February 2016, 08:14:25 »
Can the sliders be swapped into a legit Topre board so that we can use Cherry keysets?
HHKB Pro 2    HHKB Pro 2   Realforce 87U       WhiteFox        Keyboardio
   BT Hasu                              55g 10th      The True Fox        Model 01
  Controller                        Anniversary Ed.     On Order         On Order
Offline xJudas
« Reply #22 on: Tue, 02 February 2016, 08:30:29 »
( ͡° ͜ʖ ͡°)
You guys have me laughing my ass off in class. How do I explain I'm laughing at keyboards and dildos?
« Reply #23 on: Tue, 02 February 2016, 08:32:46 »
( ͡° ͜ʖ ͡°)
Lol! Just ask the class if they've ever heard of the elusive Fildo
Offline thatllbeme
« Reply #24 on: Tue, 02 February 2016, 09:00:53 »
I'd be very interested in getting myself one of these if the sliders are Topre->MX compatible. Quite a nice price, too - $70-ish according to current exchange rates.
Offline 1391406
« Reply #25 on: Tue, 02 February 2016, 09:57:09 »
I'd be willing to wager they are. They look almost identical to the Royal Kludge sliders:
Offline tronbeaver
« Reply #26 on: Tue, 02 February 2016, 10:04:47 »
PBT?  I thought only keys were made of PBT.
What other cases are made of PBT?
Offline Elrick
  • Hype Master
« Reply #27 on: Tue, 02 February 2016, 17:02:28 »
They have their keys made from PBT which are lasered so nothing to be excited about BUT the casing is unique because that same rough texture in the keys is mimicked on the casing.
Usually I try moving the side of the casing with my heavy set thumb and I can make a normal ABS case twist and stretch or until I break it but this casing won't flex at all.  Surprisingly strong but it's definitely not ABS or Acrylic and it isn't aluminum either, hence it's still a type of plastic compound hence it just might be PBT.
Only way to tell that it is PBT is to pour some lacquer thinner onto it and see how it degrades but I won't be doing that.  ABS would immediately start deforming before your eyes but PBT will retain it's shape for a while.
This is the first keyboard I've bought that looks to be made form PBT hence I can't point to another manufacturer doing any right now.
Another thing of note here, this keyboard has Co-star stabilizers which are greased with some top quality lube plus all the keys can be replaced with any CherryMX type of key-set.
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #28 on: Tue, 02 February 2016, 17:03:54 »
Case can probably be dyed too then.
Offline Bromono
  • Wanabe Cicerone
« Reply #29 on: Tue, 02 February 2016, 17:05:12 »
Also they look more similar to Topres Purple Silent Sliders.
THey look just a little longer allowing to put a silencer on it.
Offline Elrick
  • Hype Master
« Reply #30 on: Tue, 02 February 2016, 17:20:49 »
Ahhhh you youngster's, always wanting to make something unusual out of your keyboards.  Also remember this keyboard doesn't come with all RGB leds at all it only has the standard three, Caps Lock, Scroll Lock and Numpad blue leds.
Also remember that dying is a very risky art form because it can go wrong easily when applied, I've seen real fvck-ups in dying when keys are coloured wrongly but keyboards is another level of pain to consider.
Offline 1391406
« Reply #31 on: Tue, 02 February 2016, 17:30:38 »
These appear to have silencing rings:
