Author Topic: Is mx cherry black generally more expensive than other switches?  (Read 18542 times)
Offline soundtester
I'm considering a mx black switch but it's $170, I will buy it but i just don't want to overpay if I don't have to but what do you think?
Offline bocahgundul
  • a seal
Re: Is mx cherry black generally more expensive than other switches?
« Reply #1 on: Mon, 28 March 2016, 18:21:24 »
no.......
what keyboard are you eyeing?
Offline soundtester
Offline bocahgundul
  • a seal
« Reply #3 on: Mon, 28 March 2016, 18:30:19 »
http://www.amazon.com/Filco-Majestouch-2-Keyboard-FKBN104ML-EB2/dp/B0053U3Z8G
Thanks for the quick response.
no.......
nah don't get that keyboard
just get kul es 87 for probably much more cheaper. but its a tkl instead of fullsize
Offline KnivesM
Others
Offline soundtester
« Reply #6 on: Mon, 28 March 2016, 18:37:56 »
No offense but I have no idea what you just said.
no.......
Offline bocahgundul
  • a seal
« Reply #7 on: Mon, 28 March 2016, 18:47:27 »
no.......
You mean tkl? Tkl = tenkeyless = no number pad
Offline jcoffin1981
« Reply #8 on: Mon, 28 March 2016, 18:48:46 »
The cost per switch is slightly more than say  a Gateron or Kaihl and I'm sure that that is factored into the  cost, but I think that the  quality of the board components play a big role in the cost of the board.  With that said, you won't find many for say $85 with Cherry MX switches.
If you are willing to get the TKL you  will pay less      http://www.amazon.com/Filco-Majestouch-2-Tenkeyless-FKBN87ML-EB2/dp/B0053U3YA0/ref=sr_1_6?s=pc&ie=UTF8&qid=1459208823&sr=1-6&keywords=majestouch++keyboard
Offline soundtester
« Reply #9 on: Mon, 28 March 2016, 19:24:59 »
I"m getting the Filco with numberpad because I need it for work/excel work.
Offline soundtester
« Reply #10 on: Mon, 28 March 2016, 19:25:42 »
strange, why do people prefer keyboard without numberpad? Don't they need it for work?
no.......
Offline bocahgundul
  • a seal
« Reply #11 on: Mon, 28 March 2016, 20:17:04 »
no.......
We could always get an extension number pad cause most of us prefer numberpads on the left side instead of right side
And TKL looks more appealing
Offline soundtester
« Reply #12 on: Tue, 29 March 2016, 10:28:41 »
True, but it feels really weird how there are two parts...less uniform but whatever suits you.
no.......
Offline Bownagles
« Reply #13 on: Tue, 29 March 2016, 12:24:39 »
Why do you keep putting what you're replying to underneath your reply? It makes it annoying to read
Offline phosphoric
« Reply #14 on: Tue, 29 March 2016, 15:12:08 »
let him live lol
Let's get this straight. There is nothing cool about keyboards we're all lame as fk.
speak for yourself
« Reply #15 on: Tue, 29 March 2016, 15:53:46 »
how sure are you about getting mx BLACK.
it's pretty rough if you're gonna be pwning newbs for extended periods.
But maybe you lift bro, and like it' don' evn matter.
Offline TalkingTree
    • My projects
« Reply #16 on: Tue, 29 March 2016, 16:56:19 »
I own a fullsize Filco Majestouch 2 with Black MX switches and I can vouch for it being a very nice keyboard, although stock keycaps are really poor.
Albeit, if it's gonna be your first mechanical keyboard and if you've never tried any MX switch before, you might wanna go for a cheaper solution.
It's easy to get ahold of used Cherry G80-3000s.
Offline losing_ctrl
« Reply #17 on: Wed, 30 March 2016, 07:48:35 »
That looks like a real fine keyboard, sounds like you are definitely going to get it, so since you know you want it, try not to worry too much about spending a few extra bucks. Another option that cost a bit less if you're interested is a WASD V2 with doubleshot PBT keycaps:
http://www.wasdkeyboards.com/index.php/products/mechanical-keyboard/wasd-104-key-doubleshot-pbt-black-slate-mechanical-keyboard.html
I have one with MX Greens and it has a nice premium feel to it, and it looks the way I want a kb to look.
This thread is interesting to me because if you look at the switch options for the WASD linked above, you can see that some switch choices are extra $$ and some are not. In this case the MX Blacks do not cost extra, but browns, clears and greens do. I do wonder why that is???
Enjoy your new keyboard.
« Last Edit: Wed, 30 March 2016, 07:51:13 by losing_ctrl »
Offline jerue
  • (Whenever that happens :P)
« Reply #18 on: Wed, 30 March 2016, 08:17:49 »
Filcos are very nice keyboards to type on, moreso than WASD or KUL. MX Black keyboards aren't more or less expensive than others, you're mostly paying for Filco quality.
That said, I would get the cheaper one (the caps with side printing), and use the extra money to buy or start saving up for a nice PBT keycap set.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #19 on: Wed, 30 March 2016, 08:47:09 »
Don' worry bout' it
What do you lift?
Whatever I want.
#foodnetwork
If you decide to get the best cherry mx black it might cost you a bit. Vintage mx blacks are worth it from what I understand.
« Reply #20 on: Wed, 30 March 2016, 08:58:37 »
I think this keyboard would be better than the filco
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1401
It's a great price has nice keycaps and while mine doesn't have mx blacks, it has mx reds, it has been one of the best keyboards I've had.
Offline Mad_Maxx
« Reply #21 on: Wed, 30 March 2016, 11:13:51 »
Don' worry bout' it
What do you lift?
Whatever I want.
#foodnetwork
I think gaterons have more or less overrode that in a lot of peoples opinions.
Might as well just get readily available and much cheaper switches, rather than combing classifieds hoping for a decent deal.
Bad switches is the only thing that I like
Offline Keycap
« Reply #22 on: Wed, 30 March 2016, 18:13:07 »
Cherry MX Black switches are actually the cheapest and most abundant of the series. Cherry MX Blues are also somewhat common, but Cherry MX Blacks are easily the most common. They show up in mass-produced keyboards like the TG3 touchpad keyboard that can be purchased for ~$25 shipped on eBay.
Offline soundtester
« Reply #23 on: Wed, 30 March 2016, 20:59:08 »
Then why did my filco mx black cost 170?
Offline bocahgundul
  • a seal
« Reply #24 on: Wed, 30 March 2016, 21:00:20 »
Cause ur buying a wrong priced keyboard
Offline soundtester
« Reply #25 on: Wed, 30 March 2016, 21:00:46 »
Oh, I had no idea. I just cicked "quote" and type above it as if I'm writing an email.
Offline soundtester
« Reply #26 on: Wed, 30 March 2016, 21:01:26 »
You talk like i'm broke. I am not broke. Oh man, I have tons :)
Offline soundtester
« Reply #27 on: Wed, 30 March 2016, 21:02:41 »
I already have browns and blues and i didn't really like either one. MX black will give me a new experience. If I really don't like it, then I'll return it for mx cherry reds. I hope they don't charge you for repackaging fee though.
Offline soundtester
« Reply #28 on: Wed, 30 March 2016, 21:03:18 »
And also, I'm getting this specific keyboard because Martin Shrekli uses it.
Offline soundtester
« Reply #29 on: Wed, 30 March 2016, 21:04:57 »
Yeah I wish I had seen this sooner but I've already placed my order and it's coming tomorrow.
Offline soundtester
« Reply #30 on: Wed, 30 March 2016, 21:06:56 »
Oh I'm typing on my Noopoo Mx cherry brown right now. The reason why i wanted a full size keyboard because i wanted the numberpad and also because martin shrekli uses it. I thought mx black sounded damn good on his stream
Offline jcoffin1981
« Reply #31 on: Wed, 30 March 2016, 21:16:11 »
no.......
If you have to type a string of numbers the numberpad is slightly easier, but when you learn to type with the numbers in the top row you can be fairly fast.   It takes practice.  I'm happy  to sacrifice the numberpad for deskspace.  Some people have a seperate usb numberpad, so if they are I don't know doing their taxes or something they can use that.
Offline soundtester
« Reply #32 on: Wed, 30 March 2016, 21:17:55 »
I appreciate this comment. It's the first "encouraging" and "positive" comment thus far about my purchase. I've listened to this keyboard over and over it just sounds so amazing here are some videos
Offline clacktalk
  • circa 2015
« Reply #33 on: Wed, 30 March 2016, 21:21:32 »
is this joke
diary of a clacktalk
radio_killah: too much frank
Offline soundtester
« Reply #34 on: Wed, 30 March 2016, 21:21:36 »
Yeah I agree. I'm currently typing on a browns that don't have numberpad. I have been using the top number row and only recently discovered that entering number on numberpad is way more efficient. I don't think table space is an issue either. Also, I've had topre HHP2 before and i thought that keyboard wasn't functional.
Offline biscuits
« Reply #35 on: Wed, 30 March 2016, 22:24:53 »
Are MX Blacks better than MX Reds? I'm having a hard time deciding on what switch color to get when I get my new keyboard, I plan on getting a Ducky... it's just that I used to use MX Blacks on a Steelseries 6gv2... and I'm using Reds on a Corsair K95 now that I'm selling... I like both linear switches but I really just can't tell which one I liked better for consistency/double tapping etc... I feel like I should go back to Blacks.... :P
« Reply #36 on: Wed, 30 March 2016, 22:37:03 »
both are ****. if you're getting an MX switch get blues or greens. or better yet, get the superior topre switch.
Offline biscuits
« Reply #37 on: Wed, 30 March 2016, 22:41:09 »
I don't like tactile clicks lol...... I like linear, what's so much better about Topre than Cherry ?
Offline soundtester
« Reply #38 on: Wed, 30 March 2016, 22:43:02 »
Already have brown, blue and topre and none of them are any good.
Offline biscuits
« Reply #39 on: Wed, 30 March 2016, 22:45:48 »
Browns and Blue's are outta the question. I'm just debating if I should get Blacks or Reds on my Ducky... I like my reds now but I hate this Corsair keyboard...
Offline bocahgundul
  • a seal
« Reply #40 on: Wed, 30 March 2016, 22:49:23 »
1 thing u guys have to remember :
Its all about your own preference
Offline soundtester
« Reply #41 on: Wed, 30 March 2016, 22:55:56 »
Yeah, I learned the hard way that you can't always take someone's suggestion because of preference. I am excited about my keyboard coming in tomorrow though:) btw are you a navy seal or just a seal from the ocean?
Offline bocahgundul
  • a seal
« Reply #42 on: Wed, 30 March 2016, 22:56:55 »
I'm a land seal ffs
U guys spreading lies about me being a water seal
Offline soundtester
« Reply #43 on: Wed, 30 March 2016, 22:57:19 »
I'm going linear after being with brown/blues for so long. After I try black, i'm going for reds.
Offline soundtester
« Reply #44 on: Wed, 30 March 2016, 22:58:35 »
I'm a land seal ffs
That's because it's hard to not say you're a water seal considering your avatar... :D
Offline biscuits
« Reply #45 on: Wed, 30 March 2016, 23:13:40 »
Yeah, reds are definitely nice. Same thing as blacks just lighter... think I'll stay on reds hehe, I just absolutely dislike my Corsair keyboard... need a Ducky, lol
« Reply #46 on: Wed, 30 March 2016, 23:26:24 »
so buy a 5 dollar keyboard from staples, same feeling as linear
Offline biscuits
« Reply #47 on: Wed, 30 March 2016, 23:27:29 »
Sorry but I use my keyboard for gaming ;) $5 would cause some issues :)
Offline Keycap
« Reply #48 on: Wed, 30 March 2016, 23:49:49 »
I've never had a rubber dome feel completely linear. Even the worst, most mushy rubber domes that I've tried have had some form of tactility. If I'm getting a linear keyboard, I want it to be totally linear, not inconsistent.
Offline biscuits
« Reply #49 on: Thu, 31 March 2016, 00:05:46 »
Keycap: Would you suggest MX reds or MX blacks? I play some games that require quick reactions and controls on just the arrow keys and spacebar (double taps)... wouldn't it be better to have a switch that rebounds faster? I use reds now I just can't decide if I should stay on them, I mean I really like reds to be honest but maybe it's just the way my corsair k95 is made? does ducky have way better build quality?
