Author Topic: A Man's Gotta Solder....  (Read 3689 times)
Online tp4tissue
« on: Tue, 05 April 2016, 21:08:07 »
The G400 Weeaboo-Edition, 5x Omron D2F-01F
133486-0
In order to solder Omrons onto the mouse, you have to either Glue-it in place, or Tie-it with something to make sure it's flush with the board.... This is necessary on ALL 5 switches of the G400...
133488-1
(Twist-tie)
Otherwise it might go in slightly askew, which may affect the durability (of the solder-joint) and more importantly worsen Switch Feel..
133490-2
Button Flap Modification
133496-3
Depending on how worn-in your button flaps are, you MAY or MAY NOT need to file the contact surface where the flap hits the switches.
The reason is.. the D2F-01F mounted is about 0.2-0.3mm taller than the D2FC..
So, what happens is, if it's too tight, it will engage on it's own, or refuse to disengage all together.
Generally, it's quite safe to remove ~0.15-0.25mm of material off the button flap contact surface, they're the little H looking pegs on the bottom.
To remove material simply scratch the middle of the H-peg with a flat head screw driver..No need to remove the top plate.. No need to remove material off the Sides of the H peg, as they do not touch the button.
You have to scratch pretty-hard,  but remain cognizant enough not to hurt yourself..
You can not fully tell if the switches are too tight without putting the screws back on..  This will be a short trial and error process.
Re: A Man's Gotta Solder....
« Reply #1 on: Tue, 05 April 2016, 23:45:06 »
tp, fix that ****ty color man. i can't actively ignore it if i can't see it
Online tp4tissue
« Reply #2 on: Wed, 06 April 2016, 00:01:41 »
Maybe I should write an LCD calibration Guide..
Offline appleonama
  • Trollo en USA
« Reply #3 on: Wed, 06 April 2016, 00:11:11 »
DAM! :)) even I felt the heat from that burn.
« Reply #4 on: Wed, 06 April 2016, 00:12:55 »
teal or w/e the **** that color is on black on a 7 year old monitor is not fun to read
Online tp4tissue
« Reply #5 on: Wed, 06 April 2016, 00:22:24 »
Nawh.. it wasn't meant as an insult..
I really think many kidz out there don't got their monitors tuned right..
Accurate calibration is impossible without a probe..
But I can talk you through at least making it LOOK good..
« Reply #6 on: Wed, 06 April 2016, 00:23:28 »
tp im getting a new monitor soon, then i'll make u proud and u dont have to be snarky with me OnO
Online tp4tissue
« Reply #7 on: Wed, 06 April 2016, 00:24:28 »
Are you getting a photo editing monitor or a gaming monitor.
« Reply #8 on: Wed, 06 April 2016, 00:26:00 »
for the vidya games.
i dont do any type of photo editing so no need
Offline appleonama
  • Trollo en USA
« Reply #9 on: Wed, 06 April 2016, 00:34:49 »
So now calling demik a kid? the disrespect here I didn't know tp was the burn master
« Reply #10 on: Wed, 06 April 2016, 00:35:59 »
hey ass, stop egging him on :(
Online tp4tissue
« Reply #11 on: Wed, 06 April 2016, 00:38:47 »
What games do you play, what vidya card are you running.
Offline appleonama
  • Trollo en USA
« Reply #12 on: Wed, 06 April 2016, 00:44:40 »
tp is so innocent he wont insult a fly thats why hes the least toxic gh user
« Reply #13 on: Wed, 06 April 2016, 00:48:46 »
FPS, mainly CSGO and i have a 970
Online tp4tissue
« Reply #14 on: Wed, 06 April 2016, 00:51:15 »
Do you plan to play it in the competitive sense, 1024x768, minimum graphics settings,
Or,   are you trying to play with all the fidelity settings on @ 4K resolution.
« Reply #15 on: Wed, 06 April 2016, 00:52:57 »
nah, not competitive just to have fun.
don't really need 4k. 1440 is fine
Online tp4tissue
« Reply #16 on: Wed, 06 April 2016, 00:55:27 »
4k blurays incoming at the end of the year..
So if you're gonna buy a monitor TODAY,  I highly recommend going 4K..
I see 65" LG brand TVs 4K for ~ $1000 ...
That's a pretty good buy..
The only real difference between one of those, and a smaller monitor @ the same price, would be "Wide Color Gamut 10-bit processing)"..
I don't know how much you care about that..  but I personally think 65" is a better buy..
« Reply #17 on: Wed, 06 April 2016, 00:59:40 »
i dont want a 65" tv monitor. 27 at the most.
also i dont watch tv really.
