Author Topic: Remember SD ?  (Read 3721 times)
Online tp4tissue
Remember SD ?
« on: Wed, 13 April 2016, 20:04:05 »
Check out this Overlay from a movie PRE-Bluray proliferation..
It's all blurry even though it's screenshoted from the full Bluray version.
Makes one thankful everything is today made for HD...
134334-0
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Remember SD ?
« Reply #1 on: Wed, 13 April 2016, 20:51:04 »
Hehe, back when most movie downloads would fit on a 700mb disc. I think I maxed the overburn at 712mb before I noticed quality issues :))
Online tp4tissue
Re: Remember SD ?
« Reply #2 on: Wed, 13 April 2016, 20:51:50 »
hahaha  overburn..
Had to Get what was it.. NERO, I think..  hahahaha....
Offline appleonama
  • Trollo en USA
Re: Remember SD ?
« Reply #3 on: Wed, 13 April 2016, 20:54:14 »
what is sd? I was born in the year 2005
Offline rurushu
Re: Remember SD ?
« Reply #4 on: Wed, 13 April 2016, 23:08:56 »
hahaha  overburn..
this i know... NERO dvd burner software i think, did used last time.
I think it stands for Standard Definition, should be 320 * 240 if not mistaken... because dvd is 640 * 480...
Offline gain
Re: Remember SD ?
« Reply #5 on: Wed, 13 April 2016, 23:18:26 »
I think he's just being cheeky but SD is generally considered 480i and 576i, I dunno about 240p pretty sure it's LDTV (low definition), 480p is considered EDTV, the rest idk off to wikipedia I guess :V Most of those CRT"s we all grew up with couldn't do 480p anyway, so it'd do 480i or whatever, depends on region (PAL/NTSC, etc).
I could be wrong and if someone wants to correct me pls do, I'm a little woozy from medication from a cold I caught
I love me some low res, 240p for life (I may have a financially unhealthy obsession with aging arcade games)
also 640x480 on a PC CRT looks so comfy, just the right scanline intensity
« Last Edit: Wed, 13 April 2016, 23:20:04 by gain »
Offline rurushu
Re: Remember SD ?
« Reply #6 on: Wed, 13 April 2016, 23:20:54 »
o.O
Like that.... i always thought that VCD reso is 240p because last time used to play VCDs on PC and the reso is 320 x 240...
Offline gain
Re: Remember SD ?
« Reply #7 on: Wed, 13 April 2016, 23:23:08 »
o.O
I never had experience with video CD's short of seeing thousands of them at dodgy markets but wiki seems to say the following
Resolution:
    NTSC: 352x240
    PAL/SECAM: 352x288
The 352x240 and 352x288 (or SIF) resolutions were chosen because it is half the horizontal and vertical resolution of NTSC video, and half the horizontal resolution of PAL (the vertical resolution of PAL already being half of the 576 active lines). This is approximately half the resolution of an analog VHS tape which is ~330 horizontal and 480 vertical (NTSC) or 330x576 (PAL).
Neat!
Offline rurushu
Re: Remember SD ?
« Reply #8 on: Wed, 13 April 2016, 23:26:21 »
o.O
Resolution:
    NTSC: 352x240
    PAL/SECAM: 352x288
Neat!
OuO learnt new things today, guess I should google more often.
Last time VCD on PC is still doable because that time my PC's CRT monitor can only go 800 * 600.
Playing DVD that time on PC is satisfactory enough, but now... reso < 480p is damn hard to "see"
Offline gain
Re: Remember SD ?
« Reply #9 on: Wed, 13 April 2016, 23:35:10 »
I used to be really picky and still sort of am. If I have to settle for 480p so be it :P
Online tp4tissue
Re: Remember SD ?
« Reply #10 on: Wed, 13 April 2016, 23:39:26 »
I remember VCDs
I used to rent them @ the bootleg video rental places..
Offline rurushu
Re: Remember SD ?
« Reply #11 on: Thu, 14 April 2016, 01:04:21 »
I remember VCDs
o.O I never rent VCDs myself... coz that time I still young and no pennies...
Usually just watch whatever is rent by my cousins...
Online tp4tissue
Re: Remember SD ?
« Reply #12 on: Thu, 14 April 2016, 02:19:29 »
I remember VCDs
VCD was mostly PRE- broadband.. after broadband.. there was kazaa..
