Author Topic: Omg guyz.. Slither.io (Scoreboard) Geekhack Official  (Read 61106 times)
Offline alexjd99
  • oozing through the cells of one's own construction
Re: Omg guyz.. .Sliter.io
« Reply #50 on: Fri, 22 April 2016, 18:29:53 »
It's a lot like Agar.io but much better :))
« Reply #51 on: Fri, 22 April 2016, 19:08:35 »
Well,
Not better or worse..   but now that Agar has been hacked... it's not as good as it used to be.
« Reply #52 on: Fri, 22 April 2016, 22:14:02 »
Key Strategy  ...
BE Aggressive...
Offline FLFisherman
  • I'd rather be fishing.
« Reply #53 on: Fri, 22 April 2016, 22:38:42 »
My first game on my home computer. I love my mouse. And this script is awesome, TP.
Final score:
Climb to the top:
« Last Edit: Fri, 22 April 2016, 22:42:15 by FLFisherman »
« Reply #54 on: Fri, 22 April 2016, 22:38:58 »
Sigh..............................
Offline FLFisherman
« Reply #55 on: Fri, 22 April 2016, 22:43:03 »
When are you starting up the Slither team?  :))
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #56 on: Fri, 22 April 2016, 22:58:08 »
I could be down for such a thing.
As long as we host the voice com on a different service than skype, we could use the geekhack mumble server.
Offline alienman82
« Reply #57 on: Fri, 22 April 2016, 23:37:16 »
removed.
« Last Edit: Thu, 01 March 2018, 15:27:07 by alienman82 »
« Reply #58 on: Fri, 22 April 2016, 23:40:50 »
team play is going to be a bit difficult, because of the controls..
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #59 on: Sat, 23 April 2016, 00:19:36 »
Ugh, I am also addicted :(
« Reply #60 on: Sat, 23 April 2016, 02:36:15 »
My Biggest Death Loop Yet..
26000 after eating the snakes inside.
135201-0
Offline Moistgun
  • Slippery When Wet
« Reply #62 on: Sat, 23 April 2016, 17:25:09 »
on my mbp it runs so smooth, on my home pc that has a dedicated graphics card, its choppy and lags more. What the heck
« Reply #63 on: Sat, 23 April 2016, 17:26:20 »
Use Chrome..
It doesn't run very good on Firefox..
I have not tried IE.
Offline Moistgun
  • Slippery When Wet
« Reply #64 on: Sat, 23 April 2016, 17:31:25 »
Use Chrome..
Good call, Ill use chrome and use that malware script
« Reply #65 on: Sat, 23 April 2016, 18:40:17 »
Use Chrome..
You don't need the script..
There is a chrome extension
https://chrome.google.com/webstore/detail/slitherio-mods/cnlenmmkifnhllnjfoangnjokeadhbbk?hl=en-US
Offline LXXXIX
  • Just remember all caps when you spell the man name
« Reply #66 on: Sun, 24 April 2016, 11:16:11 »
I'm not as good as some of ya'll. :(
« Reply #67 on: Sun, 24 April 2016, 12:08:26 »
Use my strategy guide..
Very basically, Rush to the middle of the map right away to pick up big dead snakes..
Then when you're bigger 10,000-20,000 move to the outside of the map and eat medium size snakes..
It's not very safe to stay on the inside for too long.
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #68 on: Sun, 24 April 2016, 13:01:37 »
new best
Offline alienman82
« Reply #69 on: Sun, 24 April 2016, 14:17:35 »
removed.
« Last Edit: Thu, 01 March 2018, 15:26:29 by alienman82 »
« Reply #70 on: Sun, 24 April 2016, 15:04:03 »
Something's up with the Chrome Slither extension, It says permission to modify all sites..
Weird,, anyway, disable for now..
The developer says they're updating it though to remove the extra permissions.
Good thing I only use chrome to play slither and nothing else.
« Reply #71 on: Sun, 24 April 2016, 17:36:05 »
The Slither.io Chrome extension is all fixed guys..
Good to Go..  ssssssssssssssssssssssss..........
« Reply #72 on: Mon, 25 April 2016, 13:25:33 »
Slithering Monday
This catch is worth 12,000 mass
135432-0135434-1
Offline Moistgun
  • Slippery When Wet
« Reply #73 on: Mon, 25 April 2016, 13:28:47 »
I cannot play this game without the chrome extension now  :rolleyes:
Im dependent on having that upper hand. Cutting those off who cannot see it coming.
« Reply #74 on: Mon, 25 April 2016, 13:32:42 »
I am 100% certain all the 30K+ people use it.. or a variant of it like the tampermonkey script..
You just can't CONSISTENTLY get those larger catches without seeing the bigger picture.
So, without the mod,  it's mostly LUCK, when you get bigger..
Also,  you can tell, because many guys see you coming a mile away...
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #75 on: Mon, 25 April 2016, 13:33:27 »
My record so far
Offline Waateva
« Reply #77 on: Mon, 25 April 2016, 13:46:33 »
I JUST installed the script maybe 10 minutes ago and can definitely see how much of an advantage it gives you.  That said, I have gotten over 30k a few times (with my personal best being 39K) and over 20k quite consistently so while the script definitely helps, I don't know if you need it, although I can't dispute that it probably is more based on luck without it.
« Reply #78 on: Mon, 25 April 2016, 14:07:53 »
Try the chrome extensions.
It runs better in CHrome.
Offline alienman82
« Reply #79 on: Mon, 25 April 2016, 14:09:44 »
removed.
« Last Edit: Thu, 01 March 2018, 15:25:57 by alienman82 »
« Reply #80 on: Mon, 25 April 2016, 14:10:48 »
mine isn't working T_T  was yesterday.  404 error :(
Yea, they updated to 2.0.6,   uninstall the extension, and go to the chrome store, and install the new one..
Offline Moistgun
  • Slippery When Wet
« Reply #81 on: Mon, 25 April 2016, 14:11:43 »
Another thing that should be mentioned is using the mouse to control
It's much better than using the arrow keys.  You have more accuracy of course with the mouse, but it takes a bit of time to get used to. Mouse is definitely better.
« Last Edit: Mon, 25 April 2016, 14:24:28 by Moistgun »
Offline Waateva
« Reply #82 on: Mon, 25 April 2016, 14:13:12 »
But I am using Chrome tp!
Offline FLFisherman
« Reply #83 on: Mon, 25 April 2016, 14:17:32 »
TP, can you change your thread title to the actual name of the game?
It's "Slither.io", not "Sliter.io."
« Reply #84 on: Mon, 25 April 2016, 14:21:14 »
It much better that using the arrow keys.  you have more accuracy of course, but it takes a bit of time to get used to.
Hrrrmmmmmm....  I don't think this is true....
You can not input the precise angle to get out of tight spots using the arrow keys..
Re: Omg guyz.. .Slither.io
« Reply #85 on: Mon, 25 April 2016, 14:22:18 »
/fixed
I didn't even notice.. hahahahaha
I've been too busy playing the game...
Offline Moistgun
  • Slippery When Wet
« Reply #86 on: Mon, 25 April 2016, 14:25:26 »
Sorry, my english is bad. I was trying to say that using the mouse is better than arrow keys but takes some time to get comfortable with.
« Reply #87 on: Mon, 25 April 2016, 14:30:50 »
Hahahahah..
I c..
Is anyone here using the keyboard for this ?
Offline Waateva
« Reply #88 on: Mon, 25 April 2016, 14:46:12 »
Hahahahah..
I c..
Not me, I didn't even know you could.
Offline FLFisherman
« Reply #89 on: Mon, 25 April 2016, 14:49:40 »
Hahahahah..
I c..
Just the spacebar to boost.
Offline KatzenKinder
« Reply #90 on: Mon, 25 April 2016, 16:31:18 »
Got onto the leaderboard for the first time! :v
Offline scubaste
« Reply #91 on: Mon, 25 April 2016, 16:37:22 »
Offline Moistgun
  • Slippery When Wet
« Reply #92 on: Mon, 25 April 2016, 16:40:10 »
Nice 1 dude.
My average is like 5 k hahaha
« Reply #95 on: Mon, 25 April 2016, 19:29:58 »
Geekhack Scoreboard Added to OP...  Check it out ...
Offline scubaste
« Reply #96 on: Mon, 25 April 2016, 19:58:39 »
Offline Moistgun
  • Slippery When Wet
Re: Omg guyz.. Slither.io (Scoreboard) Geekhack Official
« Reply #97 on: Mon, 25 April 2016, 20:03:41 »
 my best today
« Reply #98 on: Mon, 25 April 2016, 23:38:06 »
My first time at #1!
« Reply #99 on: Tue, 26 April 2016, 02:29:28 »
KatzenKinder, Movin' up the Ladder with snakes...
