Author Topic: GTX 1080 specs. :O  (Read 41173 times)
Offline cmadrid
Re: GTX 1080 specs. :O
« Reply #100 on: Wed, 06 July 2016, 15:31:58 »
CPU wise too.. Intels latest high end cpu is $1700 :-o
Offline SBJ
  • Tactile pls
« Reply #101 on: Thu, 07 July 2016, 01:43:51 »
Everything's getting more expensive. And I seem to be getting poorer for some reason.  :eek:
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #102 on: Thu, 07 July 2016, 06:30:15 »
RX480 seems to be all good so far..
Even unlockable from 4gb version to 8gb..
That's pretty beast...
It's worse in benchmarks than a 980ti which you can buy for less than a new RX480.
It's not even a response.
« Reply #103 on: Thu, 07 July 2016, 10:24:35 »
Um..
The RX 480 is not really available right now, mostly not in stock.. but 4gb unlockable to 8gb version is $200
But where are you seeing 980ti @ $200..
Even if that were the case..  You still wouldn't buy a 980ti..
980ti and 970 are all obsolete cards at this point because they DO NOT support HEVC (H265) decoding..
WHICH MEANS all high resolution video content of the future, after the end of THIS year will be unavailable to you..
Even if you have a 4.8ghz 4970 cpu, you Can not CPU software decode High resolution H265..  it's too demanding and must have GPU specific decoding hardware..
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #104 on: Thu, 07 July 2016, 16:00:26 »
You can't even get a gtx 970 off of amazon for $200...
Offline katushkin
  • Just the guy
« Reply #105 on: Fri, 08 July 2016, 04:02:29 »
OK, my bad, I thought the price points were the same.
Offline TacticalCoder
« Reply #106 on: Fri, 08 July 2016, 07:08:55 »
A 4.8 Ghz Haswell CPU may not do it, but even "slow and cheap" entry-level Skylake / 6th gen Intel CPUs do all have hardware H.265 decoding right!? (or only some of them: I don't know) Another option would be to re-encode to a slightly lower resolution.
« Reply #107 on: Fri, 08 July 2016, 08:23:48 »
You would reencode every movie before you watch it?   Do you know how long that will take ?
Offline dgneo
  • Supervillain
« Reply #108 on: Fri, 08 July 2016, 08:26:57 »
Um..
Funny enough the 960 does support it, however.
Dafuq nvidia
Also, GTX 1060 announced yesterday. Supposedly performance equal to 980, for $250.
http://www.anandtech.com/show/10474/nvidia-announces-geforce-gtx-1060-july-19
  • Live long and prosper
« Reply #109 on: Fri, 08 July 2016, 08:43:53 »
Um..
Dafuq nvidia
nvidia is ****ting all over AMD right now
tp thread is tp thread
« Reply #110 on: Fri, 08 July 2016, 09:01:41 »
Dafuq nvidia
Yes 960 is a go..
I'm am considering between the rx480 and 1080 right now..
But need 490 to finally decide..
« Reply #111 on: Fri, 08 July 2016, 09:14:42 »
Dafuq nvidia
Yes 960 is a go..
what are you running now, tp?
Offline Moistgun
  • Slippery When Wet
« Reply #112 on: Fri, 08 July 2016, 09:21:28 »
Dafuq nvidia
Yes 960 is a go..
Whats the point in comparing the differences between a $200 card and a $700 card?
any benchmarks are going to clearly be on one sided...
Whats the need to say Nvidia > AMD in a thread about the 1080?
We're talking about the performance differences between Mercedes vs KIA here people.
Stop trying to justify your crazy spends by trashing something irrelevant. XD
« Reply #113 on: Fri, 08 July 2016, 09:56:56 »
i'd hardly consider comparing AMD to nvidia irrelevant
i am merely acknowledging that AMD needs to step up it's game if it has any hopes of maintaining itself as nvidia's only competition
the fact that the 1060 is projected to outperform the rx480 using less power and being only $20-$50 more doesn't look good for AMD
nvidia is proving they can capture the enthusiast and mainstream markets, where as AMD is focusing at mainstream and failing IMO
Offline katushkin
  • Just the guy
« Reply #114 on: Fri, 08 July 2016, 15:39:36 »
It definitely isn't irrelevant. The fact that we haven't got a thread dedicated to how incredible the RX480 specs are means we are p much guaranteed to talk about it in here.
I have always been an AMD fanboy, but now it makes no sense to be one.
Offline Moistgun
  • Slippery When Wet
« Reply #115 on: Fri, 08 July 2016, 15:46:41 »
https://geekhack.org/index.php?topic=82972.0#lastPost
There is a thread for the 480. do you even know TP?
Im only teasing, I get what your saying.
Offline katushkin
  • Just the guy
« Reply #116 on: Fri, 08 July 2016, 17:13:14 »
Lol, I am not very attentive today...
« Reply #117 on: Fri, 08 July 2016, 18:48:25 »
Price to performance RATIO..
And certain features which I think are relevant to the future.
Offline NewbieOneKenobi
« Reply #118 on: Fri, 08 July 2016, 19:17:21 »
Dafuq nvidia
Yes 960 is a go..
Between those two IMNSVHO the 1080 is obviously the stronger card, but price-to-performance very clearly favours the 480. For the price of a 1080 right now you could buy three 480s, and I'm pretty sure a single 1080 can't beat three-way Crossfire on the 480s — except in power efficiency, of course. :D
http://www.benchmark.pl/ranking/porownanie/amd-radeon-rx-480-vs-nvidia-geforce-gtx-1080-founders-edition
Wydajność w grach = Performance in games.
Judging by what I see here, the 490 would have to a different-generation processor in order to make a huge difference. Even 1070 beats 480 handily. However, 1070 is twice cheaper than 1080 but certainly not nearly twice slower.
I think UserBenchmark kinda sums it up nicely (vs 390x but anyway, 72% faster and >100% more expensive).
http://gpu.userbenchmark.com/Compare/Nvidia-GTX-1080-vs-AMD-R9-390X/3603vs3497
The 1060 will probably still be able to beat the 480 to both performance and performance-per-dollar, though, as well as performance-per-Watt. However, forget SLI, at least with Founder's Edition. Not sure vendors will be able to implement SLI/bridge if nVidia explicitly chose to not support it on its own cards. But if they find a way (they might have enough pull), then, if 1060 draws even less power than 960, SLI could be a nice upgrade path too. Obviously not from the get-go, but anyway.
If we are already considering price-to-performance, IMO we can't stop at ongoing performance & static purchase price. It makes more sense to consider ongoing price vs ongoing performance. The 480 isn't horrible about power draw, but the 1060 is quite likely to end up having some advantage, making it the cheaper card even if it costs a bit more to buy.
Defo. Ideally, that'd be something ground-breaking, a paradigm shift. Something like vertically stacked memory. Or cheap, low-power, high-performance multi-core GPU (not that unlikely considering their plans for a 32-core CPU).
At a minimum it will beg for a meaningful response, yeah, but AMD will have two ways of dealing with the problem: 1) just cut prices vs nVidia (been done before), 2) leverage CF capability of 480 vs no SLI on 1060 (at least the founder's edition explicitly is going to not support SLI).
What works in favour of AMD here is that CF boards are cheaper to certify than SLI boards.
However, people who build their new computers around the 1060 may decide to buy cheaper non-SLI mobos, saving them even up to $30 on the lack of SLI support alone, judging from what I've just seen when choosing a mobo for me this month. Giving up on SLI automatically means you don't need full ATX mobo or chassis, especially given how cheap DDR4 is now for a nice two-stick set, and normal Z170 doesn't support quad-channel anyway, so two banks instead of four isn't going to be a problem. And that means a cheap-ass B150 mini-ATX mobo from a better-than-no-name manufacturer at around $50 will cover it for many people. Smaller power draw on the card will make cheaper mobos safer. And cheap PSUs all the more viable.
For example: B150 mini ATX mobo + low-TDP locked PCU + just 2 sticks of (possibly cheap-ass non-XMP) memory + HDD/SSD + 1060 = any random noname PSU included with the chassis will do.
Thus, nVidia may still get to win the cheapo market. Paradoxically, cutting SLI from 1060 may help it achieve this purpose simply through getting people to think along the money-saving lines I set out above.
I tend to agree. I have a lot of respect and sentiment for AMD for modelling their price-wise mid-end –80 cards on the high end rather than the low end. That's old-school, and it shows respect for the game and customer, versus nVidia apparently trying to pull off a gimmick with some of those 128-bit flimsy-built high-performers. However, powerful architectures are not conducive to either affordable production costs or affordable ownership costs, which makes nVidia win the cheap segment too, I guess.
I wonder why nVidia isn't playing the low-voltage card more strongly in its marketing, especially given the low-voltage mentality of the European Union, which is a huge, unified market. (Perhaps legislative trends have little resonance in gaming, little wonder.)
« Last Edit: Fri, 08 July 2016, 19:50:31 by NewbieOneKenobi »
« Reply #119 on: Sat, 09 July 2016, 04:41:10 »
also we gotta take into account the dx12 performance is much higher on AMD for whatever reason.
Offline nugglets
« Reply #120 on: Sat, 09 July 2016, 21:16:31 »
Much higher is a bit of a stretch, but yes AMD has seemingly decided to adopt DX12 fully while nvidia has not.
I honestly don't blame nvidia for this decision, though, as the number of DX12 games is still low and seriously unimpressive at the moment. If it weren't for the fact they were DX12 games, most people would be ignoring them. You also can't really take AOTS benchmarks seriously at this point, that game is all kinds of ****ed up and takes many runs to establish any kind of realistic baseline even on AMD hardware.
The biggest reason to stick with nvidia at this point, IMO, is driver support. AMD has a terrible history when it comes to game performance at launch. Even worse, since the "CF 480's are cheaper than a 1080!" argument is so common these days, has been their CF support for games. It has often taken months for them to get CF worked out for major release titles. I build a good number of systems for friends and family every year and I haven't been able to recommend an AMD graphics card in several years for this reason alone. It's a shame, really, because AMD is pretty good at undercutting nvidia which leads to some solidly priced budget cards that I would otherwise be happy to install for people.
edit: Here's a CF 480 benchmark posted today. As you can see, the driver support means the results are either great or terrible. And even some of the best average FPS titles show really poor 1% and 0.1% times, which can mean a jarring experience when the frames drop dramatically. http://www.gamersnexus.net/guides/2507-crossfire-rx-480-benchmark-vs-1070-and-1080-power-temperatures-fps
« Last Edit: Sat, 09 July 2016, 21:30:22 by nugglets »
« Reply #121 on: Sat, 09 July 2016, 21:45:41 »
Crossfire / SLI isn't part of consideration..
Almost no one double up on mid-range cards..
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #122 on: Sat, 09 July 2016, 23:07:05 »
I think u should wait for 1080 Ti....
Also far better to wait for the NON-referenced Cards to be released, they will have far better designed cooling and power adjustment features than the current ones that are being sold.
When it comes to Graphic Cards, always wait for the last newly designed card off the production line because it will be their best ever model made thus far.
