Author Topic: List of laptops with trackpoint IV  (Read 15866 times)
Offline alkozu
« on: Wed, 11 May 2016, 17:35:42 »
Hi, I would like to get a trackpoint for a custom project. I found out that it is easy to get an old thinkpad or a keyboard with a trackpoint but I have no idea which thinkpad versions or keyboard versions ship with the latest version of the trackpoint. Is there any list of models that come with trackpoint IV?
Re: List of laptops with trackpoint IV
« Reply #1 on: Wed, 11 May 2016, 18:45:50 »
just get the newest laptop thinkpad keyboard which has a trackpoint..
Offline nipplemouse
« Reply #2 on: Wed, 09 November 2016, 20:27:43 »
The trackpoint IV was introduced in 1997 so anything made before then surely doesn't have what you want.
Thinkwiki has a page that might help you out http://www.thinkwiki.org/wiki/TrackPoint
Offline Leslieann
« Reply #3 on: Thu, 10 November 2016, 05:49:31 »
Trackpoint Iv basically comes on any Lenove X, t, and W series dating way back.
Trackpoints typically are not found on just any Thinkpad, they usually need to be a corporate/business grade laptop, hence the X, T and W. I wouldn't go older than an X200/T400, anything older is just useless today, and would recommend a 220/420 simply because the memory is so much cheaper that they can balance out on cost, and you still end up with a faster processor with more ram.
You can often get other corporate/business class laptops with them as well such as Dell or the  HP Elitebooks, however I can't find any info as to the trackpoint version, however I can't imagine them continuing to use a version several years out of production. Some Sonys also had them (again, not sure what brand or version), but with how Sonys hold their value and repair costs I hate to recommend them.
If you just want cheap with a trackpad IV, look for a T420, you can find them dirt cheap missing hard drives and/or memory, I once got one for under $50, just needed a drive and power supply, both of which I had. If you want a mini-monster system, get an X220 (look for the IPS screen), toss in an SSD or two (yes it can have two) and 16gb of ram, if you get the I7 you even get USB 3. The X230 is similar but all models have usb 3. Any of these will keep up with modern ultrabook as they used full voltage processors, and they handle Linux incredibly well. I was getting 5 hours out of my X220 on Mint on the 6cell (flush)  battery and 9 on the extended, just shy of the battery life in Windows.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
