Author Topic: What is this covering on this old keyboard ?  (Read 1790 times)
Offline Squalljericho
« on: Sat, 21 May 2016, 18:33:56 »
Hello ,
I was wondering if anyone could tell me the type of covering that is ok this keyboard . It is an old keyboard I picked up from a thrift store. The covering feels like the the coverings that were on the old keypads back in my elementary school' s cafeteria.
Thank you all .
Re: What is this covering on this old keyboard ?
« Reply #1 on: Sat, 21 May 2016, 19:14:36 »
that looks like hard plastic.
they also have silicone cover which is meant to be typed on..
« Reply #2 on: Sat, 21 May 2016, 19:22:13 »
Thank you for the reply , I think it's silicone , it's soft and flexible. Do you know where I might get something like that ? Also would a heat gun work ?
« Reply #3 on: Sat, 21 May 2016, 19:31:38 »
I don't think it's safe to heatgun or blowdry a flat piece on a keyboard.
Keyboards plastics are quite sensitive to heat and warp easily..
« Reply #4 on: Sat, 21 May 2016, 19:36:11 »
Do you have any ideas as to how a cover like that could be made for a modern keyboard ?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #5 on: Sat, 21 May 2016, 19:42:53 »
Unicomp sells covers for various mechanical keyboards. If you want one for a modern keyboard Mechanicalkeyboards sells a cover made for Ducky keyboards that might work. Shoot MK an email and they'll tell you if it'll fit on your current keyboard. The Ducky one is silicone based
« Reply #6 on: Sat, 21 May 2016, 20:25:05 »
Thank you very much I will give it a shot.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #7 on: Sat, 21 May 2016, 20:30:37 »
Sure thing. Oh, and if you want a keyboard roof Elitekeyboards have some atm for 87/88 key keyboards. Just a few examples off the top of my head. I'm sure there are more out there especially if you search for them on taobao or ebay
