Author Topic: Any other Deck Hassium/Francium owner with peeling keycaps?  (Read 4341 times)
Offline BucklingSpring
« on: Sat, 25 June 2016, 18:46:21 »
Hello,
After a while my Enter and backspace caps started to "peel". I called Deck and they were ultra nice and sent a replacement Enter key.
I thought it might have been an isolated problem. But the replacement key starting to peel as well...  :'(
Any other users experiencing the same?
140760-0
Boards I own, click ->
Re: Any other Deck Hassium/Francium owner with peeling keycaps?
« Reply #1 on: Mon, 27 June 2016, 18:53:46 »
100+ views no response... Hmmm...
Let me rephrase the question - Anyone with Deck Hassium or Francium out there?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2 on: Mon, 27 June 2016, 19:05:38 »
Are the ABS keycaps with normal type legends or PBT with the really funky font? If I was to take a guess my guess would be that they're ABS with UV or maybe anti-biosis coating. Why would they put anti-biosis or UV coating on the PBT doubleshots? For those reading ahead, I doubt that Deck would coat their doubleshot PBT keycaps; that would be ridiculous. Although, there are some companies that coat doubleshot PBT keycaps so..
Offline inosint
« Reply #3 on: Mon, 27 June 2016, 22:40:33 »
Sorry you're having to deal with crummy keys, curious if it's their abs or pbt set as I think the boards ship with either depending on region. I've got a Hassium pro I've been using and enjoying since December.  It's the one with back-lit pbt funky font caps. I picked up a matching pbt spacebar when I got it and none of the caps show any noticeable wear at all really. Hope they get a solid set out to you.
« Reply #4 on: Wed, 29 June 2016, 16:44:46 »
They said they were PBT... Anyway to tell?
Those are NOT the PBT ones used in their previous generation...
I have a couple of old Decks and the caps are indestructible with funky fonts.
« Last Edit: Wed, 29 June 2016, 16:50:56 by BucklingSpring »
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #5 on: Wed, 29 June 2016, 17:49:06 »
Deskthority has some info about the subject. AFAIK if you were to drop a keycap of PBT, ABS, and POM into a glass a water the ABS keycap will take a second or two to sink, but the PBT/POM keycap will sink immediately.
I would think that if they are PBT they would have the same texture as your other Deck PBT keycaps... Maybe they had some left over UV protection coating from their police days and decided to slather that on to a few of their keysets for some reason?
« Reply #6 on: Thu, 30 June 2016, 16:45:20 »
Still a mystery. I asked the Deck rep what they sent me.
Should work too. According to their end, no others reported this issue.
Too bad the Deck forum is now a dump of useless spam. So much garbage there, I think it qualifies for an award.
http://deckkeyboards.com/forum/viewforum.php?f=6
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #7 on: Thu, 30 June 2016, 16:53:52 »
The color scheme of that forum probably makes all the users angry. Good god that hurts my eyeballs :eek:
Offline x9Memoriez
« Reply #8 on: Wed, 20 July 2016, 19:18:13 »
Own and love my Deck Francium, i replaced the keys outright since i had the ABS ones through, they suck. Unsure about the 'new' PBT? I thought they only sold the PBT ones with that awful font..
Matrix 1.2OG | Constellation | Rukia | TMO50 | HHKB
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #9 on: Wed, 20 July 2016, 19:45:50 »
Seems that way. The only normal looking keycaps I've seen on the nets are made of ABS
Offline Screwdriver
« Reply #11 on: Mon, 25 July 2016, 18:52:13 »
I have a Hassium Pro with the PBT caps and they look almost as good as new. This after a year of continuous use.
Realforce 87U/55g, Deck Hassium Pro-MX Browns, MK Disco TKL - KBT Browns, Code 87-MX Clears, KUL-87 MX Reds.
