Author Topic: Need some expert TV advice..  (Read 4041 times)
Offline digi
  • elite af tbh
  • keyboard game on fleek
« on: Fri, 29 July 2016, 20:30:01 »
So why are so many 4k TV's w/ 120hz so cheap now? Walmart has a Samsung 55" 4k, 120hz for $698...Feel like I need to stick it out a bit longer...
Re: Need some expert TV advice..
« Reply #1 on: Fri, 29 July 2016, 23:47:04 »
They're not UHD,  which is the new enhanced color space..
Offline digi
  • elite af tbh
« Reply #2 on: Fri, 05 August 2016, 10:08:26 »
Curved or not curved? Is it safe to buy 120Hz? Or drop more $$$ for 240hz? Help me out Tp..
« Reply #3 on: Fri, 05 August 2016, 10:09:03 »
Just get a Diamondtron.
Offline digi
  • elite af tbh
« Reply #5 on: Fri, 05 August 2016, 14:19:01 »
The only drawback to  TVs has been the lack of ULMB..
Sony has that gaming mode blinking mode which is similar, only flashes the backlight at 60hz, and not 120hz like Gaming monitors..
I am patiently waiting for a 120hz ULMB big screen.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #6 on: Fri, 05 August 2016, 15:07:46 »
Just don't fall for buying a curved TV. They are such a gimmick. While curved monitors make sense, curved TVs are just pointless IMO.
« Reply #7 on: Fri, 05 August 2016, 15:11:46 »
I was actually curious about that. Why are they good for monitors but not for TVs?
Offline katushkin
  • Just the guy
« Reply #8 on: Fri, 05 August 2016, 15:16:29 »
In my non-expert opinion, they are good for monitors because you can't usually fit your whole monitor in your main field of vision. The curve ensures that everything stays in focus throughout your peripheral vision. With a TV, you should be able to fit pretty much all of the screen in your main field of vision (provided you buy the right size TV for your room size, a factor a LOT of people overlook) and the curve can even be detrimental to your viewing experience, especially if you have people spread throughout the room watching it.
The idea of a curved TV stems from watching films at the cinema, where the screens have been curved for a while.
Offline mike52787
  • Alps Aficionado
« Reply #9 on: Fri, 05 August 2016, 15:17:17 »
The problem with curved displays is they only have one really good viewing angle, straight on. The reason that wouldnt really work in a living room or TV room is not all people in the room/all the seating in the room can look at the display at its best viewing angle.
Offline Badwrench
  • ummmm.....I forgot
« Reply #10 on: Fri, 05 August 2016, 16:37:58 »
Don't waste your time and money on a regular led.  Oled is the way to go if you want everyone that sees your tv to gasp in awe.  The tech is changing so fast right now that I would suggest getting what you can afford and enjoy.  If you want to use it for any gaming, take note of the response times.  I bought a Sharp 4k a little bit ago and the thing had so much lag that it was impossible to game on.  Had to take it right back the next day.  I ended up with a 1080p since it was in my budget (the Sharp was over half off on Black Friday and was the only 4k even close to my budget).
https://www.amazon.com/LG-Electronics-OLED55B6P-55-Inch-Ultra/dp/B01CDF9S1G/ref=sr_1_2?ie=UTF8&qid=1470430386&sr=8-2&keywords=4k+oled+tv
The 6E model is more upscale but uses the same screen.  These do require a bit of calibration, but the final results are mind blowing!  Also, this model doesn't support 3D if you are into that.
« Reply #11 on: Fri, 05 August 2016, 17:17:14 »
OLED is just as blurry as LCDs without ULMB..
and OLED will NEVER match LCDs in motion clarity because they simply do not produce enough light to be Blinked quickly..
Offline domoaligato
« Reply #12 on: Fri, 05 August 2016, 17:27:08 »
« Reply #13 on: Fri, 05 August 2016, 17:31:21 »
For Science...
http://www.blurbusters.com/faq/oled-motion-blur/
Exactly..
We are at least 20 years away from OLEDs matching the Motion clarity of backlit blinked LCDs..
People simply don't understand the technology think OLED is the future..
OLED makes a better picture frame...  That's about it...
Offline digi
  • elite af tbh
« Reply #14 on: Fri, 05 August 2016, 17:54:19 »
Ok now I'm confused....so is 4k 120hz cool for gaming? Would i need 240hz for 4k gaming?
« Reply #15 on: Fri, 05 August 2016, 18:16:03 »
The LG Ultra HD 4k models are what we use for testing 4k applications. They are OK, but don't have enough inputs in the back imo.
Never ever had any issues with them breaking though, which is quite good for a pool of a few hundred.
Offline domoaligato
« Reply #16 on: Fri, 05 August 2016, 19:47:45 »
here is the deal with t.v.'s
240 is really a 120 hertz with overscan blur reduction.
120 is really a 60 hertz with overscan blur reduction.
get a 240 hertz t.v. and use it in game mode. never use any of the other modes.
game mode reduces input lag.
Also unless the t.v. supports hdmi 2.0b(http://www.hdmi.org/manufacturer/hdmi_2_0/) or display port, it will never be a as good for gaming as a comparable monitor.
Also check your graphics card to make sure it supports the newer hdmi and displayport modes.
unless you are talking about console gaming... and then none of this matters because you are really stuck at 30-60fps regardless of the t.v.
Offline domoaligato
« Reply #17 on: Fri, 05 August 2016, 19:49:59 »
If this is for pc gaming I would suggest you just get a 144hertz monitor.
PC Gaming on big screens makes me a little sick because I have to move my head around so much.
also you will never be competitive in csgo or dota or lol playing on a t.v. because of the time it takes you to move your head when you normally would not have to.
Offline digi
  • elite af tbh
« Reply #18 on: Fri, 05 August 2016, 19:50:51 »
thanks for the pro-advice...i want to stream Steam to my tv from my pc, my video card is pretty good.
Offline Badwrench
« Reply #19 on: Fri, 05 August 2016, 20:12:20 »
Disregard my oled advice then and look for a 240hz with low response time and hdmi 2.0 as said above.  I was advising for the best movie experience.
Offline digi
  • elite af tbh
« Reply #20 on: Fri, 05 August 2016, 20:13:13 »
10-4 good buddy
Offline domoaligato
« Reply #21 on: Fri, 05 August 2016, 20:54:34 »
I have a steam link....
60 fps on streaming. no higher.
I would still buy a 240 hertz for future proofing.
« Reply #22 on: Sat, 06 August 2016, 00:20:15 »
That's fine for Dota, and Starcraft,  but for CSGO,  it would be detrimental not to play with ULMB 144hz on a computer monitor..
It's so much faster and more clear..
Even the best TVs right now are quite blurry when it comes to fast motion.
Offline domoaligato
« Reply #23 on: Sat, 06 August 2016, 00:30:25 »
yep... that is basically what I already said.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #24 on: Sat, 06 August 2016, 01:24:36 »
Literally went through this a few days ago and ended up hanging http://www.sony.com/electronics/televisions/xbr-x850d-series on my wall.
I still haven't got the colors calibrated quite right, I don't think; but I'm happy so far.
http://www.samsung.com/us/televisions-home-theater/tvs/4k-suhd-tvs/65-class-ks8000-8-series-4k-suhd-tv-2016-model-un65ks8000fxza/ This was what I was looking at as well.  I ultimately chose sony because I got it for $250 cheaper when I lucked into an open box return.
Offline domoaligato
« Reply #25 on: Sat, 06 August 2016, 03:08:12 »
try this...
http://www.avsforum.com/forum/166-lcd-flat-panel-displays/2389146-official-2016-xbr-x850d-sony-series-tv-thread-2.html#post43841874
if that is not to your liking those guys on avsforum know there stuff.
