Author Topic: Cup Noodlez  (Read 12952 times)
Cup Noodlez
« on: Sat, 03 September 2016, 16:52:55 »
Never could handle this convenient size ..
Bought a case this morning..
Tp4 has already eaten 5x...
It's like those Fun-Size candy bars.. you just keep popping um'
147314-0
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: Cup Noodlez
« Reply #1 on: Sat, 03 September 2016, 16:55:30 »
You need to get your hands on some of these TP;
Re: Cup Noodlez
« Reply #2 on: Sat, 03 September 2016, 17:32:55 »
Does it come with Drugs. ?
Offline katushkin
  • Just the guy
Re: Cup Noodlez
« Reply #3 on: Sat, 03 September 2016, 17:36:34 »
It doesn't need to. It is the drug.
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
Re: Cup Noodlez
« Reply #4 on: Sat, 03 September 2016, 17:38:45 »
the level of sodium is too damn high.
Re: Cup Noodlez
« Reply #5 on: Sat, 03 September 2016, 17:43:36 »
Dat what I keep telling people, But they no Believe
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
Re: Cup Noodlez
« Reply #6 on: Sat, 03 September 2016, 17:48:44 »
But how do I soft boil the egg in that?
Re: Cup Noodlez
« Reply #7 on: Sat, 03 September 2016, 17:49:12 »
cup or bowl tastes objectively better than the packets
Re: Cup Noodlez
« Reply #8 on: Sat, 03 September 2016, 18:16:30 »
If that's been ur xperience, then it's possible the noodle has been over hydrated.
Packet Noodles: Thicker noodles, designed for stove-top cooking 5 to 7 minutes maximum
Bowl/Cup Noodles:
Thinner noodles (0.5-0.75 diameter (thickness) of packet variant), designed for Steeping, 3 to 8.5 minutes maximum
With the Packet noodles, you get a bouncier chew-texture due to the increased thickness, (assuming proper preparation)
With the Cup/Bowl noodles, you get the fun factor from the Noodles Ritual.. Boiling water, pour, cover, wait, pray to noodle gods.
Re: Cup Noodlez
« Reply #9 on: Sat, 03 September 2016, 18:30:48 »
Bowl/Cup Noodles:
no i always under hydrate i prefer al dente
Offline alienman82
Re: Cup Noodlez
« Reply #10 on: Sat, 03 September 2016, 18:59:47 »
removed.
« Last Edit: Thu, 01 March 2018, 14:13:26 by alienman82 »
Re: Cup Noodlez
« Reply #11 on: Sat, 03 September 2016, 20:01:36 »
Under-Hydrate may cause un-even texture --Within-- the strand of noodle..
It's a preference,  not better or worse.
However, if we think about how a noodle is cooked,  from the outside in..
Assuming that an IDEAL cooked point exists,  then by the time the theoretical center of the noodle converges upon it,  ALL of the noodle surrounding that axis has gone OVER.
My method to counter this phenomenon, is to cook the noodle thoroughly (5-7 minutes), but, Then Rinse the completed noodle in Ice-water to reduce the noodle's gelatinous entropy.   This also requires using osmotic pressure to increase concentration of flavoring inside the noodles, due to the rinsing, which removes the external coating of soup syrup.
There can be no perfection,  but I believe my method to be optimal in preserving the concentration of flavor AND bounce-texture..
Under-hydration would not work with my optimization, because if the noodle center has not crossed the fully cooked point, then we simply can not alter the center in any way, as there is no access to it, if the assumption is that it would stay- under-hydrated.
Re: Cup Noodlez
« Reply #12 on: Sat, 03 September 2016, 20:59:16 »
I'm not a scientist TP, I would probably set water on fire if I stepped into a kitchen.
Re: Cup Noodlez
« Reply #13 on: Sat, 03 September 2016, 21:12:24 »
Hahaha.. I'm just trying to impart some noodle..  It's all preference in the end..
When we look at the noodle.. we come head first against just what constitutes philosophical ideal..
Ideals, as perceptions go, is fluid, and indeterminate.  So, it is an affront to itself..
The perfect noodle should not exist because each noodle is unique, and therefore incomparable to any other noodle..
Most Generally, idealism in practical applications is merely an outline of our intellectual limit..
In that way,  Tp4 supposes, if we had a nano-assembler, to create Highly-Uniform strands of noodles,  then that would meet any criteria our intellect can judge.
But, Life is insatiable, that fervor extends to our comprehension, and thus even achieving HUN (highly-uniform-noodle) would eventually not be enough..
Once man, has tasted this novelty, man would move on to ponder, Does electron spin affect these strands..
Then, another complexity is created.
---Most probably nothing short of black holes can maintain uniform electron spin..
But hey,, take solace in the fact that the Noodle-Dream is a process..
Re: Cup Noodlez
« Reply #14 on: Sun, 04 September 2016, 05:18:12 »
I remember those, although I don't know if they were the same down here as you had.
I used to quite like them.
Offline raymogi
Re: Cup Noodlez
« Reply #15 on: Sun, 04 September 2016, 05:19:49 »
Indomie is bez.
Please feed my addiction.
Re: Cup Noodlez
« Reply #16 on: Sun, 04 September 2016, 09:31:29 »
I've softboiled a -roomtemp- egg inside the Bowl-Size containers with just the hot water..
But I don't think it's do-able in the Cup-Size.
Re: Cup Noodlez
« Reply #17 on: Sun, 04 September 2016, 21:07:42 »
Gah..
Told myself that I wouldn't eat no more cups today....  But it's that time of the evening.. and Tp4 is stricken with Ramen Withdrawal..
Got the sniffles and a headache and everything..
Re: Cup Noodlez
« Reply #18 on: Sun, 04 September 2016, 21:22:50 »
Shin Black.
All other cups are just foreplay.
Re: Cup Noodlez
« Reply #19 on: Sun, 04 September 2016, 22:02:48 »
Shin Black.
mmmmmmmmmmmm................ Shin black is....   it's very.....   I've always felt that shin black is trying too hard,  because it's not very different from the regular, they just made it more fungus-ee
Offline Adgar
    • Pheilcia
Re: Cup Noodlez
« Reply #20 on: Sun, 04 September 2016, 22:37:59 »
Hi,boy,have a try this one. This taste more healthy.
Offline yomammary
Re: Cup Noodlez
« Reply #21 on: Mon, 05 September 2016, 09:15:06 »
Shin Black.
This.
RF 87u 55g | Leeku 1800
Offline WarCommand
Re: Cup Noodlez
« Reply #22 on: Tue, 06 September 2016, 07:48:51 »
My college diet all in one post  :cool:
Offline LiquidEvilGaming
    • LiquidEvilGaming Youtube
Re: Cup Noodlez
« Reply #23 on: Tue, 06 September 2016, 17:05:39 »
FRESH RAMEN > All.
That will be all
Current Daily Driver/s
White Leopold 750R MX Reds
Head of LiquidEvilGaming on Youtube
i7 4790k/16GB DDR3/GTX 1060 6GB SSC/256GB Samsung SSD/2TB SSHD/W10
Re: Cup Noodlez
« Reply #24 on: Tue, 06 September 2016, 19:22:18 »
FRESH RAMEN > All.
That will be all
fresh ramen is very different..  it's really nothing like instant-ramen..
Instant ramen is good because it's FRIED,  regular ramen usually isn't fried.
  • Live long and prosper
Re: Cup Noodlez
« Reply #25 on: Tue, 06 September 2016, 19:40:23 »
I drain off ~75% of the broth after steeping, mix remaining 25% with noodles well enough to keep them hydrated and not sticky-icky.
Am I doing it wrong?
tp thread is tp thread
Re: Cup Noodlez
« Reply #26 on: Tue, 06 September 2016, 19:42:26 »
I was just telling inanis my new ramen recipe.. Ramen w/ Cheetos
Make the ramen normally, with only HALF of the seasoning packet.
After it's cooked..  Rinse with ice water and drain like pasta.
Then sprinkle the rest of the seasoning packet on the ramen,  ALONG with Crushed Cheetos..
Offline clankgy1
  • Formerly digifiend
Re: Cup Noodlez
« Reply #27 on: Tue, 06 September 2016, 19:46:56 »
After looking at this thread, I really only have one question.  How are you still alive?
RF87U 55g (damaged)  |  AV3 w/POM Plate  |  Thermal (to be built)  |  ID80v1 (to be rebuilt)  |  Tokyo60
Re: Cup Noodlez
« Reply #28 on: Tue, 06 September 2016, 19:48:02 »
I'm Fat..
Re: Cup Noodlez
« Reply #29 on: Tue, 06 September 2016, 19:48:11 »
See, if you're going to use those kinds of ingredients, I'd argue Cheez-Its over Cheetos.
Alternatively, you could use REAL cheese, which is marginally better for you than processed snack foods.
Although being that it's an instant-ramen recipe, that point is almost moot.
I literally typed out the same thing at first... it's a miracle of science.
Re: Cup Noodlez
« Reply #30 on: Tue, 06 September 2016, 19:49:33 »
Um, yea u could put crushed anything ,
But cheetos/ cheese puffs is good because they don't break into sharp edges, whereas many other chips do..
since you'll eat this with ramen,  that's why you'd avoid the sharp edge breaking chips.
Cheezits WILL break into sharp edges btw..
Re: Cup Noodlez
« Reply #31 on: Tue, 06 September 2016, 19:51:58 »
Food processed (i.e. ground to a powder) Cheez-Its I feel like would have a better flavor, closer to that of cheese, where as the Cheetos are mostly starches and less imitation cheese flavor.
Alternatively, leave in 10-15% water to soften the edges of said sharp Cheez-It bits.
« Last Edit: Tue, 06 September 2016, 19:53:32 by Computer-Lab in Basement »
Re: Cup Noodlez
« Reply #32 on: Tue, 06 September 2016, 20:00:32 »
mmmmmmmmmmmmmm .... i'd argue that watering it kind of defeats the purpose of the dry mix noodle..
but, psssh,, it's up to you,  there's no wrong way to make this..
Offline clankgy1
Re: Cup Noodlez
« Reply #33 on: Tue, 06 September 2016, 20:10:08 »
I'm Fat..
I believe you mistook my post of amazement for one of judgement.
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
Re: Cup Noodlez
« Reply #34 on: Tue, 06 September 2016, 20:17:43 »
Damn TP, now I'm craving  ??? ???
Didn't notice my personal messages have been disabled for those thinking you have been blocked - to contact please reach out through Facebook messages or support email!
WEB: https://rama.works/
STORE: https://ramaworks.store/
INSTA: @ramaworks
FB: ramaworks
Offline neverused
Re: Cup Noodlez
« Reply #36 on: Tue, 06 September 2016, 20:33:05 »
I can't handle these tp4 complete sentences...
Also I would say that the perfect noodle should not have one consistent texture all the way to the center, though I do love the ice cold rinse idea.
Sent from my Nexus 6P using Tapatalk
Re: Cup Noodlez
« Reply #37 on: Tue, 06 September 2016, 21:10:51 »
Yea.. the ice-water adds alot of bounce texture..  it also rinses away the food wax which is affixed to most ramen..
Offline digi
  • elite af tbh
  • keyboard game on fleek
Re: Cup Noodlez
« Reply #38 on: Tue, 06 September 2016, 21:23:33 »
Slightly off-topic but I heard that there hasn't been any scientific tests to prove that MSG is actually bad for you...since I heard that I've been binge-eating more instant-type noodles loaded with MSG and I feel wonderful.
Re: Cup Noodlez
« Reply #39 on: Tue, 06 September 2016, 21:26:21 »
Slightly off-topic but I heard that there have been no scientific tests to prove that MSG is actually bad for you...since I heard that I've been binge-eating more instant-type noodles loaded with MSG and I feel wonderful.
Well, I certainly hope you're not actually binge-eating..
but, you are correct,  Glutamate is a natural neurotransmitter in high quantity within the body,
There is NO conclusive evidence that eating MSG is bad..
It is a naturally occuring umami conductor to indicate Protein consumption to the body, telling us to eat more of that food..
Now, of course,  there is SOME harm in that it makes nearly any Food Delicious,   it is something abused by the snakefood/fast-food industry to get people to OVER EAT and Over BUY..
Offline digi
  • elite af tbh
Re: Cup Noodlez
« Reply #40 on: Tue, 06 September 2016, 21:27:56 »
Totally makes sense now, just like salt on fries eh?
Re: Cup Noodlez
« Reply #41 on: Tue, 06 September 2016, 21:31:17 »
/Ramen..
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Cup Noodlez
« Reply #42 on: Wed, 07 September 2016, 04:39:14 »
Eh, that's partly true, MSG isn't bad for you, or at least, not that we know. The rest of your description is kinda rubbish :p . The problem is more that stuff with lots of MSG is probably just ****ty food because it needs MSG in there to help it.
Re: Cup Noodlez
« Reply #43 on: Wed, 07 September 2016, 04:56:42 »
anyone else like to put a Kraft single on top of their ramen sometimes?
Re: Cup Noodlez
« Reply #44 on: Wed, 07 September 2016, 06:05:52 »
Don't get him started on watermelon ...
Re: Cup Noodlez
« Reply #45 on: Wed, 07 September 2016, 09:55:40 »
It's like a mini salt-blanket..
Offline bazh
Re: Cup Noodlez
« Reply #46 on: Fri, 09 September 2016, 11:54:01 »
Get a packaged one and cook it properly, don't eat plain instant noodles please, it's too much salt and heat.
HHKB Pro2 white
Newbie again
Offline ntw
Re: Cup Noodlez
« Reply #47 on: Fri, 09 September 2016, 12:04:49 »
try this and send your bottom on a trip trough fiery hell :fire: :fire:
Offline WarCommand
Re: Cup Noodlez
« Reply #48 on: Fri, 09 September 2016, 12:20:22 »
Can confirm, extremely unpleasant.
You're cruel for even recommending someone try this.
Re: Cup Noodlez
« Reply #49 on: Fri, 09 September 2016, 13:52:30 »
What is plain instant ___vs instant
