Author Topic: Would we be more or less efficient with 4 arms?  (Read 20880 times)
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: Would we be more or less efficient with 4 arms?
« Reply #50 on: Sun, 11 September 2016, 10:21:50 »
I think it depends what job you do. Workers on a production line would ALL be 4 armed if you could get them. Working in IT, I can't think how they would be more beneficial and they would probably spend a large amount of time doing nothing unless my brain could type and use a phone at the same.
Also I sleep on my front so that wouldn't be effected.
Offline ideus
  • Björkö.
« Reply #51 on: Sun, 11 September 2016, 10:26:27 »
Are Octopuses more efficient than men?
« Reply #52 on: Sun, 11 September 2016, 11:03:21 »
They're more efficient underwater for sure...
Michael phelps is only 4.4mph underwater..
an Octopus can go as fast as 25 mph...
« Reply #53 on: Sun, 11 September 2016, 11:08:07 »
You know what'd be super interesting..  Octopus LANDSPEED  racing..   I'd watch that over turtle racing.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #54 on: Sun, 11 September 2016, 12:37:54 »
Yes.
Offline bazh
« Reply #55 on: Sun, 11 September 2016, 14:32:36 »
at least they don't go 2 trips
And they run underwater quite fast too
« Last Edit: Sun, 11 September 2016, 14:34:30 by bazh »
HHKB Pro2 white
Newbie again
« Reply #56 on: Sun, 11 September 2016, 14:47:25 »
How has no one brought up the main issue: With our current torso design the arms would have no 'resting state' and would therefore constantly be exerting energy while our bodies were upright causing constant fatigue.
One pair would have to come from our sholderblades, able to rest them over the shoulders and out of the way while not in use, freeing the lower pair to be used.
If you think about human physiology this makes the most sense for adaptation, since having the arms come from on high would allow for intricate work right in from of our faces. More suited to human adaptation, whereas a second pair of arms coming from the lower torso would have evolved from sheer workhorse adaptation.
I believe it would come down to having a weaker but more dexterous pair of arms from above our current set, or stronger force-centric arms below our current pair which also could cause potential fatigue.
« Reply #57 on: Sun, 11 September 2016, 14:55:33 »
It'd probably be like a double shoulder,
We'd have a second set of clavicle and acromion which protrude from behind our current one.
Possibly a little lower or a little higher, doesn't matter, but it would still be hanging at rest.
« Reply #58 on: Sun, 11 September 2016, 21:53:02 »
I was thinking that the existing shoulders would be wider, and then have a second set of shoulders underneath.
It could be possible to have just the two shoulders, and one pair of arms primarily front-focussed and another pair of arms primarily back-focussed, but you'd literally need a pair of eyes in the back of your head to make any real use of them.
Offline tacnificent
« Reply #59 on: Mon, 12 September 2016, 12:05:52 »
You could just use a tray for all those you carry for breakfast couldn't you?
« Reply #60 on: Mon, 12 September 2016, 21:26:14 »
As an American..   I would like to be able to hold 4 guns.. Quad wield.. pew pew.
« Reply #61 on: Tue, 13 September 2016, 21:58:51 »
Nice idea, but the distance from storage to table is about 2 metres, which is about 2 steps.  To involve a tray in the procedure would add another item to be carried there and back, plus loading and unloading times.
Actually I could probably stand in the middle of the floor, lean towards the kitchen counter to grab bowl, spoon and drink bottle, then lean the other way to put them on the table.  Except that would increase the possibility of dropping one or more of the items to an unacceptable level.  Plus that early in the morning I'd probably keep falling over which would add to even more delays.
Offline xondat
  • i'm not a star
« Reply #62 on: Wed, 14 September 2016, 04:59:52 »
you're American?
Surprised you didn't realise you can eat 2x quicker.
« Reply #63 on: Wed, 14 September 2016, 06:02:44 »
you're American?
You'd still only have one mouth.
But you could queue up 4 spoonfuls of food at a time, instead of just two.
« Reply #64 on: Wed, 14 September 2016, 10:02:09 »
you're American?
4 real cores,  with hyperthreading ,  = 8 spoonfulls..
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #65 on: Wed, 14 September 2016, 10:34:29 »
you're American?
44 real cores, with hyperthreading , = tp IoT army
« Reply #66 on: Wed, 14 September 2016, 11:05:01 »
you're American?
Tp4 only use abilities for good.
« Reply #67 on: Thu, 15 September 2016, 06:10:57 »
We have hyper-threaded brains.
Left and right hemisphere.
amirite?
Offline xondat
  • i'm not a star
« Reply #68 on: Thu, 15 September 2016, 06:39:11 »
amirite?
So brains are just 1 core 2 threads?
« Reply #69 on: Thu, 15 September 2016, 13:00:20 »
amirite?
Ummmmmmm,   we have 2 cores, 1 cpu, and the system bus is the Corpus callosum, the interconnect between brains..  or maybe the l2 cache is.. hrrrm not sure.
Offline bazh
« Reply #70 on: Thu, 15 September 2016, 15:06:40 »
But can we agree that we have ****ty memories? Even our RAM crashes sometimes.
HHKB Pro2 white
Newbie again
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #71 on: Thu, 15 September 2016, 15:32:43 »
Now that you mention it--a few minutes ago Chrome ate all my available memory and refused to give it back :(
« Reply #72 on: Sat, 01 October 2016, 06:20:27 »
I've found Chrome release memory better that most other browsers.
But I use Firefox to browse GH as the smooth scrolling is better.
With one arm too!  Well, for most of the last two weeks anyway.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #73 on: Sat, 01 October 2016, 06:44:25 »
I switched to Mint and Chromium. Seems to work pretty well. I learned a few display priority tweaks that smoothed out most of it :thumb:
« Reply #74 on: Sat, 01 October 2016, 09:42:49 »
Two hands for keyboard, one for mouse and one spare to move papers, sign things, answer the phone...  Can't see any argument against bonus arms in an office environment.  Would be great for soldering too - two hands to hold parts, one to hold the iron and one for the solder.
My only hesitation is could we make maximum use of them with only one set of eyes?
  • Even more awkward to sleep
This makes it sound like you already have problems sleeping and blame them on having arms?!
I just had a bout with solder demons..
Would've honestly liked 6 hands..
4 soldering irons in 4 hands,    and 2 other hands to hold the workpiece at an angle..
« Reply #75 on: Sun, 02 October 2016, 03:42:27 »
Using 4 soldering irons at once would be dangerous.  You'd need extra eyes to watch all the joints you are soldering.
Does anyone even use 2 soldering irons at once?
« Reply #76 on: Sun, 02 October 2016, 04:43:14 »
I've used 3 at a time, with only the 2 hands that I have..
2 in right hand like chopsticks, and one in the left.
« Reply #77 on: Sun, 02 October 2016, 05:02:33 »
Wasn't that awkward?
Were you more productive that way, than you would have been using one at a time?
« Reply #78 on: Sun, 02 October 2016, 08:35:53 »
It was the only way to desolder multiple things simultaneously because they were glued together on one end.
My most elaborate scheme was when I also had a string tied to the pcb which I'd pull with my teeth as I was desoldering with 3 irons.
hahahahhahahaha..  that worked,  but it's quite dangerous..
Offline Moistgun
  • Slippery When Wet
« Reply #79 on: Sun, 02 October 2016, 08:47:58 »
Two irons in one hand?  Feet?
« Reply #80 on: Mon, 03 October 2016, 05:11:58 »
I'm trying to picture that but my mind keeps shutting down.
« Reply #81 on: Mon, 03 October 2016, 14:53:45 »
Drew a picture
« Reply #82 on: Tue, 04 October 2016, 05:09:58 »
Drew a picture
Looks like drinking through a straw while eating dots with chopsticks.
« Reply #83 on: Tue, 04 October 2016, 09:43:20 »
Drew a picture
Tp4 = best @ drawing
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #84 on: Tue, 04 October 2016, 14:58:04 »
Drew a picture
I thought I saw a dolphin in that drawing. Is there a dolphin?
« Reply #85 on: Tue, 04 October 2016, 20:58:49 »
Drew a picture
Also your left arm seems way longer than your right arm.
« Reply #86 on: Tue, 04 October 2016, 21:21:05 »
Drew a picture
That's because given that photo's perspective my left arm is closer to the viewer,  therefore...... I drew it larger..
Tis' Rudimentary Watson, rudimentary
« Reply #87 on: Wed, 05 October 2016, 04:13:12 »
Drew a picture
Actually I did take that into account.
Allowing for perspective, your left arm still seems longer.
« Reply #88 on: Wed, 05 October 2016, 04:39:36 »
Drew a picture
But did you also take into account lens distortion..
« Reply #89 on: Wed, 05 October 2016, 05:03:10 »
Drew a picture
What lens?
« Reply #90 on: Wed, 05 October 2016, 12:03:15 »
Drew a picture
What lens?
Have compensated for the lens as viewed through a human eye (which has a lens_
That is the correct length as it should be..
