Author Topic: Anyone know how to straighten nylon tubing ?  (Read 3818 times)
« on: Wed, 12 October 2016, 13:43:19 »
I need it to not affect the diameter as much as possible.
It's sold in rolls.
And, google says heat it..   so I know heat would soften it, but, then there's diameter..
Offline dgneo
  • Supervillain
Re: Anyone know how to straighten nylon tubing ?
« Reply #1 on: Wed, 12 October 2016, 13:45:44 »
It's sold in rolls.
Could try soaking it in hot water
« Reply #2 on: Wed, 12 October 2016, 13:59:29 »
It's sold in rolls.
Would it just return to straightness,  or do i need to apply pressure..
The problem I'm having is ,  I don't know of a way to apply Even pressure, which may cause odd formations.
