Author Topic: The cable on my Realforce 87uw is too..oo long  (Read 2913 times)
Offline cong314159
« on: Fri, 28 October 2016, 14:42:43 »
So I did this: :thumb:
Re: The cable on my Realforce 87uw is too..oo long
« Reply #1 on: Fri, 28 October 2016, 14:45:31 »
Nice non permanent modification but I'd be careful bending the cable too sharp or you might have some internal breakage.
Offline sony
  • Formerly ultraidiot
« Reply #2 on: Fri, 28 October 2016, 14:46:43 »
That's an interesting solution. I didn't like the length of the cable or the fact it was attached, so I made some realforce cables that end in mini USB so it's like a semi detached cable. Mimic cables does them if you ask. That's another option I guess. You'd need another cable though. The convenience of it having a mini USB break is pretty nice though especially I'd you have many boards.
Offline cong314159
« Reply #3 on: Fri, 28 October 2016, 14:50:01 »
Yes, I would be careful. Thanks!
« Reply #4 on: Fri, 28 October 2016, 15:09:20 »
Interesting solution, but like Ray said, it's probably better to just buy a shorter cable.
Offline E3E
« Reply #5 on: Fri, 28 October 2016, 15:52:44 »
I'm thinking of buying a micro USB breakout board and using one of those magnetic connectors to make my Realforce's cable removable.
That's for a little bit more down the line, but I think it'd be an elegant solution.
« Reply #6 on: Sat, 29 October 2016, 21:09:13 »
If it has to be that short,   I'd just cut it.. hahahaha..
There's nothing worth saving about that cable,  it's just a cable..
Offline jcoffin1981
« Reply #7 on: Wed, 02 November 2016, 12:44:11 »
I dislike when the usb cable is fixed to the board.
What is that handsome little board behind it?  I love it.
Offline yomammary
« Reply #8 on: Thu, 03 November 2016, 07:59:51 »
You can also buy custom Realforce cables from Pexon.
RF 87u 55g | Leeku 1800
