Author Topic: Only one thing keeping me from Novatouch'n my RF87U  (Read 2499 times)
Offline dracoNiiC
« on: Sat, 10 December 2016, 11:16:15 »
So, I have a barebones Novatouch. And I have an 87U. And I really want to swap everything out and get a nice set of keycaps but... what do I do about the spacebar?
My dilemma is a can't seem to find a 6u mx stem spacebar that has the stem centered. I don't know if I'm just not looking hard enough or if it just doesn't exist.
I'm almost tempted to scrap my plans for a novatouch'd RF all together and just get rid of the RF and keep the Novatouch. Or I guess the only other option would be to buy a Topre stem spacebar and not switch sliders on the RF. Halp.
Offline need
Re: Only one thing keeping me from Novatouch'n my RF87U
« Reply #1 on: Sat, 10 December 2016, 11:30:30 »
I would keep the RF if I were you, as the rattling noise is unbearable on the novatouch. Everything feels loose compared to the real deal.
Offline fublamchu
  • ㅋㅋㅋ
« Reply #2 on: Sat, 10 December 2016, 12:00:29 »
Unless your planned keycap set disagrees with it, can't you just get a Topre PBT spacebar and use it with other Novatouch'd keys?
LZ-CE VBlacks
910-CE
Offline dracoNiiC
« Reply #3 on: Sat, 10 December 2016, 12:17:25 »
I assume I'd have to leave the spacebar Topre slider in, because Novatouch and Topre stem don't agree with each other from what I've read.
Which is what I guess is the route I'll be going. But the key kit that I want won't really look right (or in my head it doesn't) with a pbt spacebar.
Offline dracoNiiC
« Reply #4 on: Sat, 10 December 2016, 12:18:01 »
It's in the mail.. so I haven't gotten my hands on it yet. Is it really that bad?
Offline zslane
« Reply #5 on: Sat, 10 December 2016, 13:05:59 »
The NovaTouch doesn't rattle per se, as in stabilizer rattle, but it does suffer from noticeable upstroke clack, as does the RealForce RGB. However, a set of silencing rings dampens that noise very nicely.
If your plans are to put Dasher on Topre switches, then I recommend installing silencing rings on the NovaTouch and keep the RF for something else.
Offline dracoNiiC
« Reply #6 on: Sat, 10 December 2016, 13:24:35 »
Are youuuuu stalking me haha
... for real though
Offline dracoNiiC
« Reply #8 on: Sat, 10 December 2016, 17:38:20 »
Sometimes it's easier just to have 2 keyboards..
Good thing this is only number four...
« Reply #9 on: Sun, 11 December 2016, 08:27:53 »
I mean't
Sometimes it's easier to just have 4 keyboards...
