Author Topic: which 1080 gtx  (Read 9939 times)
which 1080 gtx
« on: Thu, 22 December 2016, 09:29:55 »
which one do i get o-O
unlimited budget
Offline FLFisherman
  • I'd rather be fishing.
Re: which 1080 gtx
« Reply #1 on: Thu, 22 December 2016, 09:36:49 »
I think EVGA has the best one. It's really, really close though.
I've also heard good things about Galax and Palit.
« Last Edit: Thu, 22 December 2016, 09:39:33 by FLFisherman »
Re: which 1080 gtx
« Reply #3 on: Thu, 22 December 2016, 09:44:41 »
Not now..
wait for Ti...
but boxing dayzzzz and bitcoin is peaking
Offline cmd
Re: which 1080 gtx
« Reply #4 on: Thu, 22 December 2016, 10:07:17 »
evga as always  :thumb:
best support NA
Re: which 1080 gtx
« Reply #5 on: Thu, 22 December 2016, 10:08:15 »
really? I used to have one of EVGA's older cards always thought they were one of the ****tier ones.
EVGA one with the watercooler?
Offline cmd
Re: which 1080 gtx
« Reply #6 on: Thu, 22 December 2016, 10:09:39 »
I haven't left the EVGA world. I would argue that they are one of the best (if not the best).
Hydro??? Yeah it is good. EK water block one??
Re: which 1080 gtx
« Reply #7 on: Thu, 22 December 2016, 10:11:12 »
hmmm.. i wonder when Ti will come out.
btw it has to be on newegg.com cuz they're the only ppl i know who take bit coin
Offline cmd
Re: which 1080 gtx
« Reply #8 on: Thu, 22 December 2016, 10:15:34 »
personally i'd go with this http://www.newegg.com/Product/Product.aspx?Item=N82E16814487243
I have the EVGA 1070 FE and it is fantastic
Offline Flyersfan1
  • Hi!
Re: which 1080 gtx
« Reply #9 on: Thu, 22 December 2016, 10:17:26 »
It might be unveiled at CES, but you could always utilize EVGA's step up program should you feel inclined to upgrade down the road. As far as current models go, I would recommend EVGA's Superclocked 1080. They do have amazing support as others have mentioned.
Quote from: Photekq
Re: which 1080 gtx
« Reply #10 on: Thu, 22 December 2016, 10:24:46 »
what's the difference with the founder's edition? there's a $200 cad difference but i can't find any details on the actual specs
oh is it the cooler?
Offline cmd
Re: which 1080 gtx
« Reply #11 on: Thu, 22 December 2016, 10:28:02 »
yep it is the cooler - FE has the nvidia cooler (reference cooler).
Re: which 1080 gtx
« Reply #12 on: Thu, 22 December 2016, 10:49:37 »
hmm i do live in canada i probably don't worry too much about cooling. but then again i did say i'd go all out.
1080 Ti SLi here I come keepo
Offline ReverbSlush
  • 16/52 RNG score
Re: which 1080 gtx
« Reply #13 on: Thu, 22 December 2016, 11:13:26 »
 :-\ BTC is still undervalued! maybe...
Offline absyrd
  • CPT HYPE PADAWAN
Re: which 1080 gtx
« Reply #14 on: Thu, 22 December 2016, 11:55:02 »
Isn't that stock cooler loud af?
I'm a major EVGA supporter.
Offline YoungMichael88
  • HHKB Wannabe
Re: which 1080 gtx
« Reply #15 on: Thu, 22 December 2016, 12:13:01 »
Offline TalkingTree
    • My projects
Re: which 1080 gtx
« Reply #16 on: Thu, 22 December 2016, 12:15:52 »
Zotac AMP! Extreme Core.
Re: which 1080 gtx
« Reply #17 on: Thu, 22 December 2016, 14:55:57 »
Yes, but it has the advantage of performing well regardless of the airflow quality of the case..
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: which 1080 gtx
« Reply #18 on: Sat, 24 December 2016, 15:45:23 »
Zotac. My friend bought (not joking) four different 1080s to try and find a good one and he settled on the Zotac. Low noise, no tearing, good temperatures, and not a huge power draw really.
I'm going for the Zotac mini 1070 for my next build.
Re: which 1080 gtx
« Reply #19 on: Sat, 24 December 2016, 17:09:27 »
tearing ?
Re: which 1080 gtx
« Reply #20 on: Sat, 24 December 2016, 17:36:00 »
wait for ti
  • HHKB Wannabe
Re: which 1080 gtx
« Reply #21 on: Sat, 24 December 2016, 17:39:52 »
wait for ti
I'm still happy with my 970 for now. I'll be waiting until the next batch. GTX 1180?!
Re: which 1080 gtx
« Reply #22 on: Sat, 24 December 2016, 17:42:11 »
Buy a potato
Offline katushkin
  • Just the guy
Re: which 1080 gtx
« Reply #23 on: Sat, 24 December 2016, 20:15:44 »
tearing ?
Screen tearing brooooo
Offline Sterenke
Re: which 1080 gtx
« Reply #24 on: Sat, 24 December 2016, 22:16:10 »
Asus ROG 1080 strix (OC) works great with the EK cooling blocks in sli config!
200fps in most graphically demanding games at 1440p with maxed graphics settings!
« Last Edit: Sat, 24 December 2016, 22:18:05 by Sterenke »
Offline happylacquer
  • BS Apologist
    • BHOBuds
Re: which 1080 gtx
« Reply #25 on: Sat, 24 December 2016, 22:21:27 »
How far superior is a 1080 gtx to the 1060 in real life usability? I can play Street Fighter 5 or CS:GO at 1440p but I still get below 60fps at times.
Offline Sterenke
Re: which 1080 gtx
« Reply #26 on: Sat, 24 December 2016, 22:26:49 »
You can have a single reference (1080) card and depending on your bottleneck in other components, you should get at a bare minimum of 100fps at 1440p in cs:go with maximum graphics settings.
Sent from my SHIELD Tablet using Tapatalk
Re: which 1080 gtx
« Reply #27 on: Sat, 24 December 2016, 23:13:28 »
There's something very wrong there..
No way you should get under 200fps with a 1060 in CS GO ,  even with max settings..
The only way that could possibly happen, might be 4x-8x super sampling..  which i don't think is an option in the default csgo menu
Offline Sterenke
Re: which 1080 gtx
« Reply #28 on: Sun, 25 December 2016, 05:48:08 »
The solution for most gen 10 Nvidia graphic cards due to lower fps I found:
Go to your bios-- advanced menu-- pci latency--change the value from 32 to 64.
However, not changing this value with a gtx 1080 will get you ~120fps in 4k, ~150fps in 1440p I found.
Re: which 1080 gtx
« Reply #29 on: Sun, 25 December 2016, 07:04:04 »
I've never heard of this..  what is happening behind the scenes with the Latency ?
I use TimerResolution app to keeps fps more consistent, and cpu-unpark  (both reduces cpu latency)
Offline rabbitfire
Re: which 1080 gtx
« Reply #30 on: Sun, 25 December 2016, 10:33:29 »
Vote for EVGA
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
Re: which 1080 gtx
« Reply #31 on: Sun, 25 December 2016, 11:02:15 »
Definitely EVGA. Either the SC or the HydroCopper
Offline rabbitfire
Re: which 1080 gtx
« Reply #32 on: Sun, 25 December 2016, 11:14:06 »
Re: which 1080 gtx
« Reply #33 on: Mon, 26 December 2016, 02:15:08 »
went with the evga SC. cost me like 1.07 bitcoin? i also bought an ssd and a harddrive.
appreciate the help guys!
« Last Edit: Mon, 26 December 2016, 03:21:13 by Sifo »
