Author Topic: What does Leeku-tuned switch mean?  (Read 1947 times)
Offline iwantatrophy
« on: Sun, 22 January 2017, 05:30:06 »
I am quite new to MK community, and I have seen the terms Leeku-tuned browns, leeku-tuned Vintage Blacks being used frequently. Can anybody specify what they mean? Also, assuming it is a type of tuning to an existing switch, what exactly is the procedure and how much difference does it make?
Offline joey
Re: What does Leeku-tuned switch mean?
« Reply #1 on: Sun, 22 January 2017, 05:53:08 »
Leeku is a person. So leeku-tuned means.. tuned by Leeku :P
« Reply #2 on: Sun, 22 January 2017, 05:54:27 »
I prefer Ripster-tuned..   who's this leeeku...
Offline E3E
« Reply #3 on: Sun, 22 January 2017, 05:59:36 »
It just means that the switches were customized by Leeku. It's a typical job, when one is doing assembly services, to "tune" up the switches using aftermarket (lighter or heavier) springs, lubricating friction points and springs, and applying switch stickers and SIP sockets and so on.
Leeku is also a PCB designer from South Korea, so his name carries that weight. He's known for the PCBs found in various Korean customs, particularly the TX-series, TGR, Mira, some LZ boards I believe, the L3 Alphas PCB (Alps TKL PCB that's a.87 spec), and others.
