Author Topic: Tesoro Lobera Spectrum or Motospeed CK108/K92  (Read 2126 times)
Offline sebacote
« on: Wed, 25 January 2017, 13:45:15 »
FINALLY, my Logitech G15 2nd gen died after nearly 10 years of good services. I'm currently browsing reviews and reading about mechs and switches, and I've learned a lot of things about mechanical keyboards and ready to make the jump.
Here is the specs I'm looking for :
- Ideally brown switches, blue would be okay too;
- RGB, per key illumination;
- Ideally software to configure the colors by game launched;
- Sub 100$ price (I'm in Canada, so I'm looking for sub $75 USD).
Everything else is not really important.
I was first looking at major brands (Logitech, Corsair, Razer, etc) and found nothing under $75 with per key RGB illumination with mechanical switches. After reading a lot of reviews, I found 2 keyboards with all the specs I need, Tesoro Lobera Spectrum and Motospeed CK108/K92.
I'm wondering if any of you have any advice for those keyboards, as I'm not able to decide which one I want more. On one side, the Tesoro has brown switches (I prefer this, quieter) and software to control RGB, but it's really ugly. On the other side, the Motospeed has blue switches (can I O-ring them for quieter typing?), no software (so keypress setting for RGB illumination and manual switching for games), but it's more pretty (and metal, the other one is plastic).
What would you do? Thanks for your advice!
I'm also open to suggestions for another mech who have all the specs I need, but I would prefer a suggestion between the two, because they are the ones who are available in Canada!
Re: Tesoro Lobera Spectrum or Motospeed CK108/K92
« Reply #1 on: Wed, 25 January 2017, 14:19:03 »
Is there something PREVENTING you from saving up a little more money than $75 ?
That's a 1-2 weeks allowance if I remember correctly from childhood.
Offline sebacote
« Reply #2 on: Wed, 25 January 2017, 14:45:06 »
If something justify the need to put more than $75, please tell me because I doesn't see any advantages from what I'm reading.
I just don't wanna spend a lot of money on that because I'm quite tight on budget, but if there is really good advantages about spending more, I could wait longer and use a generic USB keyboard while waiting!
« Reply #3 on: Wed, 25 January 2017, 15:17:16 »
with the bigger brands,  we know what we're dealing with in terms of pcb quality, qc checking, etc,  software side gets a little better support..
With the less popular brands, there are some unknowns...
And since this is a keyboard and you'll be buying it once, the price difference isn't that much relative to the length of use.. so... that's why I'd recommend going with the bigger brand..
Offline sebacote
« Reply #4 on: Wed, 25 January 2017, 15:26:51 »
They are really good arguments!
For my needs, can you suggest me something? (Browns, Per-key RGB, software)
Thanks again!
