Author Topic: Desoldering question  (Read 1668 times)
Offline pixelpusher
« on: Thu, 26 January 2017, 11:33:48 »
What I want to do is desolder all of the cherry red switches from a CM board and replace them with zealios switches.  I've successfully desoldered about 1/2 of a custom board in the past (trying to get to the cherry stabilizers that I forgot to clip) and I didn't have any issues with pads.  However, I have also desolder LEDs on about 20 switches and unfortunately ended up lifting the pads on 4 of them.
Did I just get lucky with the switches the first time, or are the switch pads more durable than the led pads?  Anyone with experience in mass desoldering? Should I try it and risk ruining the board?
« Last Edit: Thu, 26 January 2017, 12:00:22 by reececonrad »
Offline keytohopiness
Re: Desoldering question
« Reply #1 on: Thu, 26 January 2017, 11:37:32 »
LEDs are tough.  Need a good solder sucker.
Online tp4tissue
« Reply #2 on: Thu, 26 January 2017, 15:00:55 »
get the LARGE spring pump style solder sucker..   don't use the small ones.. they don't have as good a suction power.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #3 on: Fri, 27 January 2017, 00:21:17 »
The holes for LED are pretty tight compared to switches. I found that i had to take the LED out while heating the what appears to be clean hole. I would say even after multiple solder sucks and some pushing the wire around till its loose... its still probably holding on somewhere in there.
-Dana
Online tp4tissue
« Reply #4 on: Fri, 27 January 2017, 01:23:43 »
yea, sometimes you get the solder flow to the other side..
Offline jcoffin1981
« Reply #5 on: Wed, 01 February 2017, 13:09:18 »
I've desoldered 2 boards with LED's and I just wont do it again as it's a PITA and not worth the effort.  Even when you learn some some skill LED's can take multiple attempts which can peel up the pads.  It can help to add a little solder to the mound before sucking.  Some boards also have delicate pads.
I've gotten the LED's to work with destroyed pads by sliding a very thin gauge wire down the hole and wiggling it until you find contact (it lights up) and then soldering it in place.  I haven't heard of this as an accepted practice but I don't know of another way.  I don't think you can wire them together like you can switches as it will affect other lights.
