Author Topic: [SOLVED] Exact Audio Copy experts?  (Read 12416 times)
« on: Sat, 04 February 2017, 16:18:00 »
A problem that I have had with EAC for quite a while is that on .MP3 rips from CDs it does not go all the way to the quality level that I set.
Even when I move all of the "quality control" settings that I can find all the way to the top, requesting 320 bit rips, the final products almost invariably end up as a mix of readings in the low-mid-200 bit range. My tired old ears may not be able to hear the difference anyway, but I would like to understand it.
I know that EAC is the preferred CD ripper for most people, but it frustrates me when other programs such as CDex give me 320 bits when I ask for it.
« Last Edit: Sun, 05 February 2017, 09:03:39 by fohat.digs »
- D Trump 2026-09-28
Offline logomachy
Re: Are there any EAC Exact Audio Copy experts here?
« Reply #1 on: Sat, 04 February 2017, 16:34:27 »
Are the additional command line options set for 320? The default might be variable bitrate.
Offline ika
« Reply #2 on: Sat, 04 February 2017, 16:39:09 »
Sounds like the mp3 encoder is doing variable bitrate. I haven't used EAC in many years but this should be accurate:
http://www.afterdawn.com/guides/archive/exact_audio_copy_installation_and_configuration_page_5.cfm
What does your config page say in the "additional command line options" section? If you want constant 320 bitrate it should read something like -b 320. Personally I prefer -V 0, smaller file size but still goes up to 320kbps when needed.
Offline clappingcactus
« Reply #3 on: Sat, 04 February 2017, 16:44:17 »
Assuming you're using LAME; in EAC Compression options adding '-b 320' to the beginning of 'additional command-line options' box should fix it.
Take out any '-v' you see.
« Last Edit: Sat, 04 February 2017, 16:45:48 by clappingcactus »
« Reply #4 on: Sat, 04 February 2017, 18:26:03 »
variable bitrate
But you really don't want to rip 320 cbr for mp3, because file sizes are pretty close to flac, and it's way worse quality..
Offline dgneo
  • Supervillain
« Reply #5 on: Sat, 04 February 2017, 18:51:49 »
variable bitrate
This, 256VBR is the highest I'd go, even then 192 is usually sufficient
« Reply #6 on: Sat, 04 February 2017, 18:55:55 »
This where the bulk of my ripping is done anyway, and since I started in .MP3 @ 192 many many years ago and for consistency that is probably OK.
My underlying perplexity was why is this happening?
Offline dgneo
  • Supervillain
« Reply #7 on: Sat, 04 February 2017, 19:00:59 »
My thought was similar to clappingcactus'; Are you using the LAME Encoder? If so, make sure it's setup similar to this:
« Reply #8 on: Sat, 04 February 2017, 19:39:22 »
variable bitrate
I'm not so sure why people are still using mp3s..
They got spotify and pandora.. it's just way way easier if you're willing to accept lossy compression..
And i think they also don't count towards data usage on many carriers..
Offline Coreda
« Reply #9 on: Sun, 05 February 2017, 04:57:07 »
I'd recommend using CUERipper which is included with CUETools. Has the benefits of EAC without the mess. AccurateRip verification, EAC-formatted rip logs, streamlined UI, optional automatic metadata addition from multiple different sources (best implementation I've seen). Excellent program.
Offline kekstee
« Reply #10 on: Sun, 05 February 2017, 06:26:11 »
320 CBR is something I'd only use if I know I need to play those files on weird old hardware.
Either archive to Flac or rip to V2/V0 for listening.
« Reply #11 on: Sun, 05 February 2017, 09:02:49 »
Thanks for the help, guys. The "Additional Command Line Options" made it work properly.
CueRipper looked interesting but being wrapped up in NET framework made me want to ignore it.
I have a gigantic .MP3 collection (the majority of it converted and/or ripped from my physical collection) and I want it all in the same format, as plain-Jane and old-school as possible to be playable on anything.
PS - I don't really understand or care what "playlists" and "libraries" are so these are all in straight files and directory tree structures on a hard drive.
