Author Topic: Looking for Layout like this  (Read 2008 times)
Offline TimDaToaster
« on: Sat, 18 March 2017, 20:46:51 »
So i'm currently looking for a keyboard or even just a compatible switch plate with a layout similar to the following
http://www.keyboard-layout editor.com/##@_css=%3B&@_x:1%3B&=Esc&=F1&=F2&=F3&=F4&=F5&=F6&=F7&=F8&=F9&=F10&=F11&=F12&=F13&=F14&=F15&=PrtSc%3B&@_x:1%3B&=~%0A%60&=!%0A1&=%2F@%0A2&=%23%0A3&=$%0A4&=%25%0A5&=%5E%0A6&=%2F&%0A7&=*%0A8&=(%0A9&=)%0A0&=%2F_%0A-&=+%0A%2F=&_w:2%3B&=Back%20Space&=Delete&=Pause%0ABreak%3B&@_x:1&w:1.5%3B&=Tab&=Q&=W&=E&=R&=T&=Y&=U&=I&=O&=P&=%7B%0A%5B&=%7D%0A%5D&_w:1.5&h:2&w2:2.25&h2:1&x2:-0.75&y2:1%3B&=Enter&=PgUp&=Insert%3B&@_x:1&w:1.75%3B&=Caps%20Lock&=A&=S&=D&_n:true%3B&=F&=G&=H&_n:true%3B&=J&=K&=L&=%2F:%0A%2F%3B&=%22%0A'&_x:2.25%3B&=PgDn&=Home%3B&@_x:1&w:2.25%3B&=Shift&=Z&=X&=C&=V&=B&=N&=M&=%3C%0A,&=%3E%0A.&=%3F%0A%2F%2F&=%7C%0A%5C&_w:1.75%3B&=Shift&=%E2%86%91&=End%3B&@_x:1%3B&=Ctrl&=Win&=Alt&_a:7%3B&=&=&=&_w:4%3B&=&=&=&_a:4%3B&=Fn&_a:7%3B&=Filler&_a:4%3B&=%E2%86%90&=%E2%86%93&=%E2%86%92
Im know a board with this many keys on the bottom row is likely nonexistent, but i want there to atleast be two extra keys flanking the space bar EG korean and japanese keyboards...
other requirements...
TKL or smaller
normal backspace
big ass enter
small right shift to make space for \
need to copy link as it does not work properly... fml
« Last Edit: Sat, 18 March 2017, 20:55:08 by TimDaToaster »
Re: Looking for Layout like this
« Reply #1 on: Sat, 18 March 2017, 20:59:16 »
I fixed your link.
That's a weird layout. The bigass enter makes is especially hard. I don't think it exists.
Offline xondat
  • i'm not a star
« Reply #2 on: Sat, 18 March 2017, 21:08:57 »
« Reply #3 on: Sat, 18 March 2017, 22:07:55 »
You don't need the key printing to match what the keyboard inputs.
You can just change the recognized scan codes through windows, either using the keycode changer from server 2003 ,  OR you can do it in autohotkey.
Offline dantan
« Reply #4 on: Sun, 19 March 2017, 05:41:22 »
The enter is really weird. Surprising that someone would still like that particular type of enter. It is very retro.
